FullBlown
Old 05-15-2014, 12:22 PM   #85
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I'm hoping something cheaper fits. Like an updated r154 out of a newer truck. The v160s might as well be made out of gold where I'm at.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Creole (09-26-2014), derpz86 (06-29-2016)
Old 05-15-2014, 12:32 PM   #86
gramicci101
Off Topic
If you have any adapter plates from an old test pattern or that were flawed during manufacturing, I'd be tempted to buy it from you. I have no need for a Supra transmission, but it would make a nice garage clock or piece of art in a man cave.
Old 05-15-2014, 12:36 PM   #87
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by FAER View Post
So where can i source out the cost of this conversion?!?
Still putting it together but it will be similar to the price of our S2000 kit. This kit uses a few more parts so it will cost slightly more.
S2000 Kit = $995 for converison kit
$2395 for the Custom Twin Disc
FullBlown is offline   Reply With Quote
Old 05-15-2014, 01:50 PM   #88
JerryMichaels7
Drives: Whiteout FRS
The price of the v160 is going to be the real factor. Awesome stuff as useual tho
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 05-15-2014, 02:00 PM   #89
d.liang
Drives: 13 whitout frs
couple quick questions:
1. does it need a custom shifter/
2. is the clutch required of can you run an off the shelf unit for either the supra or frs?
d.liang is offline   Reply With Quote
Old 05-15-2014, 02:02 PM   #90
Reaper
Reaper's Avatar
Drives: violent
that's my problem right now. damn they are pricy.
Old 05-15-2014, 03:18 PM   #91
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by FullBlown View Post
We are in the process of fitting the Totoya Supra V160 Getrag 6-Speed transmission to the FA20 motor.
The Getrag is capable of holding more than 1000hp while providing the comfort of a OEM gear box. We are hoping to wrap this up in a couple of weeks.
Once everything is done and tested, this kit will be available to the public.
How much heavier is this than the OEM transmission? Also, I suspect that this will change the distance between the output shaft of the transmission and the rear differential, so a new driveshaft would be necessary, right?
^GT5 Replay Photo Mode^
Old 05-15-2014, 03:26 PM   #92
SirBrass
SirBrass's Avatar
That don't seem too bad
Have y'all considered putting together a stronger gearset that's able to withstand more torque, and with longer ratios to better suit FI in this car?
Old 05-15-2014, 03:30 PM   #93
Reaper
Reaper's Avatar
Drives: violent
you need to read the whole thread. yes new driveshaft, about 20 pounds heavier, no gearsets, too expensive and not much room in the case.
Old 05-15-2014, 03:38 PM   #94
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes a new driveshaft will be needed to make it work. We have thought about making a gear set but after opening the OEM trans ,we've decided not to go down that path.
A complete 6-speed gearset would of costed $6k plus. Keep in mind, the synchro design on these gear boxes are not the greatest either. Only way to make the OEM box hold is a straight cut dog engagement. I cannot see any other way to make it reliable for big power usage.
The Following User Says Thank You to FullBlown For This Useful Post:
SirBrass (05-15-2014)
Old 05-15-2014, 03:43 PM   #95
Reaper
Reaper's Avatar
Drives: violent
I want a dog box :-(
Old 05-15-2014, 11:57 PM   #96
FAER
Drives: Silver BRZ
3300"ish" plus cost of a new tranny?!?
FAER is offline   Reply With Quote
Old 05-16-2014, 12:00 AM   #97
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
More
Sent from my IBrick
Old 05-16-2014, 12:01 AM   #98
SmsAlSuwaidi
Boosted
I think mvp sells it cheaper
Sent from my IBrick
BEST HID Conversion Kit out there?? VADER Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2017 08:50 AM
E85 conversion ender2664 Engine, Exhaust, Transmission 6 09-15-2013 11:58 PM
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 07:56 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 03:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 09:44 PM
