#85 |
Grip>Slip
So weird. Perhaps it's time for a google forms survey to gather more data in a sortable format to try and discern a pattern?
#86 |
Drives: 2013 Asphalt FR-S
I have a feeling it will come down to ecu part numbers
~Namaste~ |
#87 |
It always resets to the initial value set in the rom on a reflash, i assume your talking about post flash.
~Namaste~ |
#88 |
Drives: 2013 "AVO Orange" FR-S
Yes, in reference to the first post.
#89 |
Drives: Viper, Mustang, FD RX7, FFR GTM
Stock tune, the multiplier always goes to 0.7 after a key cycle.
This is how some of the "before and after flash" dyno sessions looked so "good", new tunes often have the multiplier set to one on start, and you have to knock to see it reduced. |
#90 |
Drives: '13 BRZ Ltd
Maybe this is something that is dependent on the ECU Calibration? 00C vs. 01C? If anyone knows the IAM PID info then anyone with Torque should be able to check...
#91 |
Rom version has already been ruled out. Reading the IAM value requires direct ram access, i do not believe torque can do that.
~Namaste~ |
#92 | |
We already have a number of folks that the IAM does not reset after a drive cycle. So far it seems mostly subarus that the IAM persists on but we do have a few toyota / scions that seem to persist as well.
~Namaste~ |
#93 | |
I use Epifan to log, and it's no software glitch, cause if I make the pull before the multiplier gets to 1, power is significantly down, as is logged timing. I think we even made a video demonstrating this to dispel the myth of giant gains with a tune..... I'll dig it up, or do it again. Also, we are in Canada, if that makes a difference. Last edited by Toma; 10-07-2013 at 07:23 PM. |
#94 |
Drives: 2013 White Out FR-S
stock ROMs its set @.7
#95 | |
It does seem to happen during the cranking cycle. I believe if you connect the logger and check the IAM and fine learning table at key on, the learned value will be there, but the instant you crank the car, it resets. So far it seems to be the push button BRZ's and handfull of scions that keep the learned IAM across drive cycles.
~Namaste~ |
#96 |
Drives: GT86
Why don't you check the switched power to the ECU? I know for a fact it keeps the fuel injectors live for quite a while after you key off. Could be related.
#97 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#98 | ||
I will double check this afternoon when i leave the office. EDIT: confirmed after sitting for 6 hours or so, keyed on, connected logger, refreshed learning view... same values were there from before I shut off the car at work this AM. Left logger connected, started engine, refreshed learning view, fine learning was reset to all zero's. I am back on E85 now and have initial iam set to 1 in the rom so there was no change to notice in the IAM but since fine learning was present prior to cranking i'm 100% sure this has nothing to do with power connections to the ecu. Quote:
~Namaste~ Last edited by mad_sb; 10-09-2013 at 04:15 PM. |
| iPhone plugged in via USB not acknowledged after restart | OnTheFence | Electronics | Audio | NAV | Infotainment | 5 | 08-20-2013 10:47 AM |
| Tein Street Advance 99c NR | 86drift | Australia Classifieds | 0 | 05-23-2013 05:06 AM |
| Help NEEDED ASAP, Thanks in advance! | FR_Soldier_77 | Other Vehicles & General Automotive Discussions | 9 | 03-20-2013 10:10 AM |
| YR-Advance | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 10-31-2012 09:08 AM |
