Old 08-20-2013, 11:10 AM   #85
AkaJabari
Drives: Scion FR-S, Scion tC
You could technically run a ~15 PSI pulley on the Vortech kit and then plumb a wastegate on the inlet side set to 10 PSI. It'll ramp up your power delivery faster allowing you to hit peak at say 4500RPM instead of redline venting off the excess pressure. Either recirculate it or vent to atmosphere. The power curve will look more turbo like but with the instant throttle response of a blower.
Im sure one of these shops/vendors on here could make it work for you. Added expense shouldnt be too great.
I didn't even read the above post. Disregard.
AkaJabari is offline   Reply With Quote
Old 08-20-2013, 11:29 AM   #86
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You are right that is possible to do. My question is why doesn't Vortech do this then? If it is possible to put pulleys on to make more boost sooner, are there downsides other than having to vent that boost in the upper RPM range? So now you have matched one of the pluses of a turbo, but you still have a belt and the parasitic loss of a supercharger.
Old 08-20-2013, 11:34 AM   #87
AkaJabari
My guess is added expense and one more part they'd have to manufacture and warranty. Who knows their reasoning.
I still say for 2.0L displacement, turbo is the best way to go.
Old 08-20-2013, 11:36 AM   #88
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
And at 15 psi you are spinning the blower past its designed RPM range and will kill it sooner rather than later. (Anyone feel free to correct me, this is what I have gathered from Vortech threads).
Old 08-20-2013, 11:44 AM   #89
Sportsguy83
Drives: Limited BRZ
You misunderstood. You utilize the smaller pulley to get it up to speed faster. You're never actually spinning past whatever RPM 10 PSI spins at or wheveter you set the wastegate to open at. Just hope the wastegate doesn't fail.
I did misunderstood, but venting the added PSI to WG will not make the Compressor to spin any slower, it will spin towards 15 psi, you are just venting the extra air out. (I believe )
Old 08-20-2013, 11:45 AM   #90
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by industrial View Post
Yeah I know but they are as close as you are going to get to what the OP wants for around the same price. I guess I could've said Cayman R or Elise but they are 2-4x the money. There is nothing else like our car with just a little more power or everyone would be driving that.
How about our car with a different final drive ratio? Speed things up a little, anyway
If I were hell-bent on having fun and didn't care about mileage I'd likely do headers / exhaust, tune, light flywheel and different rear end gearing. You'll be having fun in no time
most importantly, keep stock tires, or at least wheels. People put 17x9s on it and complain it won't scoot around.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 08-20-2013, 11:45 AM   #91
jamesm
i dont think you understand how superchargers work. superchargers don't use wastegates because they have no exhaust pressure to relieve, and doing so would have no influence on boost pressure. they are mechanically driven off of the crank pulley. the rpm that they spin at is dependent on engine rpm, and compressor rpm rises and falls with it. if the supercharger has a smaller pulley, it's going to be spinning faster, no matter what. venting some of the boost to atmosphere is just stupid, you're just wasting a bunch of work compressing all that air. if you want more boost at low rpm, buy a turbo or pd supercharger.
The Following User Says Thank You to jamesm For This Useful Post:
Sportsguy83 (08-20-2013)
Old 08-20-2013, 11:46 AM   #92
AkaJabari
Wait thats misinformation. You're right. The blower is still spinning at the higher rate. Your just not seeing the added PSi in the motor. If the bearings arent reated to spin at the rate, then you' dhave to upgrade them or risk premature failure.
SORRY!
No I understand. I'm not trying to start a debate or anything. You can repurpose a wastegate to do exactly this and it has been done before. Sportsguy83 was right about the SC spinning faster than w/e it's rated for and I corrected myself. Thought about it as soon as I hit post and realized i was incorrect there. No worries.
The Following User Says Thank You to AkaJabari For This Useful Post:
Old 08-20-2013, 11:55 AM   #93
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So it is decided then. The answer is a turbo or a Cayman R.
The Following User Says Thank You to King Tut For This Useful Post:
ftc~brz (08-20-2013)
Old 08-20-2013, 12:13 PM   #94
s2d4
s2d4's Avatar
Why are the vortech guys so defensive and crap on others going with PD or Turbo?
So what if you don't have as much power as the PD under 5500rpm, just be happy with what you have after 6500rpm even if the right sized turbo has more power from 2300 to red line.
The Following User Says Thank You to s2d4 For This Useful Post:
Old 08-20-2013, 12:20 PM   #95
ftc~brz
Done
Drives: WRB BRZ
Sorry if I am reiterating a point stated in the last 5 pages.
try to drive or at the least ride with people who have kits that you are interested in before you pull the trigger.
just my 2 cents.
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
Old 08-20-2013, 12:22 PM   #96
King Tut
NASA SpecE30 Racer
King Tut's Avatar
just my 2 cents.
I still haven't gotten to ride in a supercharged twin. @charged86 never offered.
Old 08-20-2013, 12:25 PM   #97
ftc~brz
Done
Drives: WRB BRZ
well you are welcome to come up here any time and drive it while I still have it. I really hope someone awesome snags this deal (cough… @OrbitalEllipses…cough)
Old 08-20-2013, 12:50 PM   #98
Dezoris
Dezoris's Avatar
I will have videos and interviews from a dyno day with Vortech Innovate and NA guys coming up the next week hope to show the good, bad, extreme of all these setups and what is involved.
The interesting part of these kits it most of it comes down to who is tuning for it.
If someone drove my car and then Charged86 Vortech I can bet 99% of people would not think it was the same kit.
Supercharger vs Turbo MPG ? LoCo Forced Induction 23 06-27-2015 05:24 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
supercharger or turbo? RussellRockets Forced Induction 137 11-28-2012 06:54 AM
ATTN: Potential FR-S Buyer's in Alberta! Schwieg Scion FR-S / Toyota 86 GT86 General Forum 5 07-21-2012 05:24 PM
Info/comparison for potential buyer. coung1112 Scion FR-S / Toyota 86 GT86 General Forum 14 06-17-2012 10:46 AM
