#85 |
Drives: 2015 Subaru BRZ
- Jonathan Bussard/ IBill4You
- Speed by Design (SBD) kit - 93 octane - 12 psi - Prodrive EBC, 2.5" P&L overpipe, 2.5" catless Motive Front Pipe, 2.5" Nvidia N1 catback Ti, wastegate ported by Neal of The Racer's Line, cheap Spectre air filter, misc heat wrap and turbo blanket. - started 104*F last run 90*F pouring rain, Visconti tuned at Pure Automotive Performance. Currently working on CAI, oil cooler, misc suspension, then clutch before going E85 with injectors. - ![]() ![]() |
The Following User Says Thank You to IBill4You For This Useful Post: | D_Thissen (06-28-2015) |
#86 | |
Sideways and Smiling!
Drives: Scion FR-S
Is this with stock fuel pump?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
#87 |
Drives: 2014 Pearl White BRZ
E85/Flex - Drift Office Tune - AVO Turbo
Map 1 is low boost @7psi - E73 and less Map 2 is high boost @11 PSI - E74 and up Both these pulls are on E85 (Map 1 and 2) ![]() |
#88 |
Drives: gts 86
FI Dyno thread
#89 |
Drives: 2013 Ultramarine FR-S
- Dustin / DustinS
- Speed By Design v1 Turbo Kit - 93 - 7 psi - Motiv Overpipe/Front Pipe w/ Cat, Nameless Muffled Track Pipe - OFT Base Tune, 80F+, Superflow Dyno, First Run without fan - Second with fan - 217whp 206wtq
#90 |
Drives: 2003 Evo GSR TB
Forgive me if this is off topic, but I notice most everyone isn't making more than 200wtq before 4k rpm. Is this a mechanical limitation of the fa20 or tuned purposefully to save the stock block?
Just curious as I'm coming from the Evo world where were looking for 300awtq by then.. |
#91 |
Drives: 2013 FRS
The Following User Says Thank You to sweetfrs For This Useful Post: | civicdrivr (08-23-2015) |
#92 |
Car Makes 150whp stock on these dynos. From what I see, on a dynojet they make about 175, So on a Dynojet the car would make around 250whp. Sound like a better number for you?
The Following User Says Thank You to DustinS For This Useful Post: | sweetfrs (04-19-2016) |
#93 | |
You are used to a platform that uses a very small volume manifold from the factory. PTuning is a perfect exmaple they make wonderful top end but they take a very long time to spool due to the fact they use the OEM exhaust manifold and then install the turbo next to the transmission. This excessive length slows spool time dramatically and as most people run a set load on the dyno by the time the turbo catches up you are half way through the RPM band. If you were to add extra load to the dyno or "pre load" it it would spool it earlier. I typically load it to simulate ~3rd gear pulls on the freeway when I plot. An example of a fast spooling turbo would be Crawfords personal car running a fairly small twin scroll turbo. It makes full boost at something like 2,800RPM. The runners are still fairly long but not excessively long and the turbo is properly sized and maxes out early and the torque falls off up top. This gives more of an "oem like" power band. AVO also uses shorter runners and a properly sized turbo (although it is not a ball bearing turbo so there is some lag) and it makes fair torque at lower RPM. Here is bob's car making well over 200WTQ before 4,000RPM: http://www.ft86club.com/forums/showthread.php?t=71551 I cant find the plot of me and crawfords cars overlayed... But our spool characteristics are substantially different. His car is an absolute fucking blast to drive with its quick response, mine however feels obviously substantially faster once the turbo decides its time to wake up and actually go... Here is crawfords new budget kit... (test runs). I think with tuning it could do a lot better up top. mind you this is BHP but it makes over 200BHP from 3000+ RPM. This is still a long runner manifold but it is a small twin scroll turbo. ![]() Bottom line? To fight compression we use tactics used for high RPM / high HP setups. And people are using larger turbos / intercoolers than needed to get the most pump gas power. And due to the engine design it is difficult to use a small runner manifold as you have two heads to pull from. Your turbo gets super close to the engine & radiator if you bottom mount it.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread Last edited by nelsmar; 08-24-2015 at 12:08 PM. |
#94 |
Ahh, thinking about it that makes a lot of sense.
His curve on that setup looks awesome, I bet that wouldnt make that power as early on 93 though. Even some of the supercharger guys aren't making the crazy down low torque I expected to see. Either way, it looks like Id be happy with the power of a good turbo setup. Slidey when you want it to be. Thanks for the awesome reply! |
#95 | |
Increasing the fuel octane is not going to hurt the lower RPM power. And most of the supercharger guys are running centrifugal superchargers that don't make boost until high RPM. first result on google: http://www.ft86club.com/forums/showthread.php?t=53359 If you want to discuss further create a new thread or toss it in PM's.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#96 |
Drives: Sterling BRZ Ltd
Custom Kit,
GT2860RS .86 Tial housing 12psi, 93 octane 3" down pipe, 2.5" over and front pipe, stock midpipe, 2.5" axle back. stock fuel injectors. Land and Sea Dyno 291hp 240tq, (peak torque at 4500 rpm) (15% conversion to DynoJet numbers , 334hp 276tq) ![]()
The Following 3 Users Say Thank You to mrk1 For This Useful Post: |
#97 |
Drives: 2013 FRS, with boost by ATS Racing
![]() Started as a CX Racing kit, modified by ATS Racing with a billet ball bearing PTE 5558 (with ATS' 3" exhaust housing v-band mod), TiAL wastegate, Greddy BOV, ID1000s, drop-in DW pump, ATS Racing 3" turbo intake and straight pipe exhaust. E85 (310rwhp and 26Xrwtq on 93). Last edited by robr; 01-23-2016 at 11:33 AM. |
#98 |
Fr-s Whiteout
Drives: 2017 civic type R #1353 2017 ss1le,
13 psi E70
Works stage 2, openflash header, Invidia front pipe, Trd exhaust Cam tuning
Turbo Fr-s 2013 Cam Tuning SOLD
http://youtu.be/3vM-2MijcQQ 2017 ss1le 2017 Honda Civic Type R #1353 2002 Rsx Type s Last edited by GhostOp86; 09-08-2016 at 11:22 PM. Reason: Error |
The Following User Says Thank You to GhostOp86 For This Useful Post: | WORKS (02-12-2016) |
Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
