Old 06-24-2013, 07:55 PM   #85
fenton
Originally Posted by PSJohnDoe View Post
I want to know how much weight is being added between the two batteries and the unit itself. Also, I'm interested in where the batteries are being installed.
Only a couple pounds will be added between the cold side of the turbo and the motor controller. The batteries weight about the same as the stock battery, there is just 3 of them. They install in the same spot as stock once it comes out.
Sent from my HTC One using Tapatalk 2
fenton is offline   Reply With Quote
Old 06-26-2013, 10:53 AM   #86
fenton
Update #1
Yesterday we got the unit installed. In total i would put installation time around 30 minutes. Dead simple installation. Remove stock air tube, remove stock resonator and sound generator, install the unit as in the picture.
We connected up the breather hoses and ensured the PCV vent had a check valve in it. After that we pulled my battery out and dropped the new one in and wired to the controller.
For a first installation the fit was bang on.
Now came the moment of truth, what was going to happen when i turned this thing on? I started the engine and it came to life just as it normally did, no drama, AFR's bang on 14.7.
Next i backed it out of the garage and started to take it for a little drive. For the first minute or two, while the engine warmed up, i drove out of boost. Nothing seemed different, throttle response was the same and acceleration was the same.
Finally i tried my luck with a WOT run in 2nd gear. I first heard the click of the switch engaging followed by rushing air and we were off. It has Noticable Torque when it comes on showing a peak of 4psi. I continued bagging around 1st, 2nd and 3rd all whip by pretty fast. Definitely faster than stock.
After getting home i checked the logs, no knock, AFR's seemed good at WOT and MAF airflow was up by over 30% between 3500 and 5500.
We are working to schedule dyno time now to see what numbers we are getting but the torque is definitely noticeable. I tried to take a video last night but it didnt turn out as i was the only one in the car.
I plan on doing before and after GO PRO video's of the acceleration for reference.
MORE UPDATES TO COME: sorry for the crap picture quality and dirty engine bay, ill fix something nice up soon
Here is a picture of it before the controller was installed:
Old 06-26-2013, 10:58 AM   #87
ft_sjo
Drives: GT86
Did the boost pressure drop with rpm?
Old 06-26-2013, 11:08 AM   #88
jamesm
that's awesome! almost looks like it was made specifically to fit there. i really hope this shows good results. could be a nice low-dollar kick in the pants. how much $$$ are you into this thing for so far?
Old 06-26-2013, 11:33 AM   #89
ML
ML's Avatar
Drives: 13 White MT FR-S
wouldn't you want the MAF between the blower and the TB?
Old 06-26-2013, 11:39 AM   #90
Calum
That Guy
Drives: 2013 asphalt FRS MT
Ideally, yes, in case there's a boost leak. But with so few places for it to leak I don't think it's much of a worry.
Old 06-26-2013, 11:42 AM   #91
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I think that motor needs to be bigger, or faster spinning, or geared.
SloS14 is offline   Reply With Quote
Old 06-26-2013, 11:45 AM   #92
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I love how clean the install worked out.
Old 06-26-2013, 12:25 PM   #93
fenton
Yes boost pressure dropped. At redline it was at about 1.5psi.
Key is it is NON-parasitic boost though. that 1.5 psi is actually worth quite a bit.
This was the first installation there is alot more dev that is going to be happening soon!
My baseline with stage 1 was 168hp, we will know exactly how much this thing makes very soon.
Honestly i was trying to get it to drain the battery and i couldn't, not on the street.
The torque dip provides alot of restriction which is why I am getting 4psi at my altitude.
Old 06-26-2013, 12:27 PM   #94
mid_life_crisis
Drives: FR-S 10 #103 AT
Much speculation as to what the electronics are. My 2 cent opinion goes toward a voltage converter. The fan runs on 28 volts: the car on 14. The voltage from the alternator has to be bumped up to support two batteries wired in series to make the 28.
Old 06-26-2013, 12:34 PM   #95
SloS14
SloS14's Avatar
There's also an ESC in there. I'd like to see this run on a 6c LiPo pack.
Old 06-26-2013, 12:42 PM   #96
fenton
Problem with LiPo is it doesnt like to work outside of a certain range, and that range is much smaller than what we are using.
LiPo in the engine bay is also a problem when heatsoaked.
Old 06-26-2013, 01:12 PM   #97
jamesm
putting a lipo in your engine bay is an awesome way to start a bonfire.
Old 06-26-2013, 01:15 PM   #98
tahoward
tahoward's Avatar
Drives: Firestorm FR-S
Really want to see someone pair up some electric motors on that turbo's compressor wheel. Looks like it only reaches 37,000 rpm.
Looking at the comp map here:
http://www.phantomsuperchargers.com/fts-tq25024v.html
50,000 rpms would be about 650-700 cfm @ around 7psi sea level... 7psi on the low end would be crazy fun...
tahoward is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
