Old 05-28-2014, 05:27 PM   #85
nunonuna
nunonuna's Avatar
Originally Posted by Stormalong View Post
Same thing happened to me in Feb. I had no idea how to stop it, so I ended up taking it to the dealership (just around the corner fortunately) and the service guy managed to stop it by pulling a relay under the hood. After replacing the relay it started working again. He showed me which relay (just in case it happened again) but its been working fine ever since.
I wish it will never happen to me. Mine works fine without any issue so far. I'm hesitating for going back to all those wires and solder. I just wish my t taps are working forever~ lol
Sent from my Galaxy Nexus using Tapatalk
nunonuna is offline   Reply With Quote
Old 05-28-2014, 05:29 PM   #86
nunonuna
nunonuna's Avatar
And btw what happen to all those support from EasyGo?? Do they just ignore our inquiry to lead us to authorized installer? Or they just went out of business??
Old 05-28-2014, 05:52 PM   #87
Chaetagnath
Drives: Whiteout FRS
I have no idea. The last time I tried to contact them was about a year ago, and they got right back to me. I'm pretty sure they are still in business, maybe they only work with authorized installers now.
Chaetagnath is offline   Reply With Quote
Old 05-30-2014, 06:44 PM   #88
sero901
sero901's Avatar
Drives: 2014 Scion FRS
I emailed them from a different email to try and get a response and nothing yet. I still have the old software with a non working remote start, which is one of the main reasons I bought this lol. I ended up disconnecting the connector for the ignition under the steering wheel, turned off right away and then just plugged it back in. Been working perfect ever since.
sero901 is offline   Reply With Quote
Old 05-30-2014, 06:49 PM   #89
sero901
sero901's Avatar
I would NEVER trust t connectors long term. I install avionics for a living and I grabbed some proper connectors from work when I did mine. Did you guys reconnect your ignitions for a back up? I never bothered putting it all back.
Old 05-31-2014, 06:16 PM   #90
TRDCal
Drives: Firestorm MT Monogram
Any concerns that without an immobilizer and steering lock that the car is alot more open to theft, I'm interest in doing this on my 4runner but have always been curious about this.
I feel like some could just smash a window, throw her in neutral and put it on a flat bed. Then buy a new easygo unit, since you've already done the wiring for him, he simply plugs in a new unit and away he goes to Mexico.
Just a thought, anything in the install to prevent this?
TRDCal is offline   Reply With Quote
The Following User Says Thank You to TRDCal For This Useful Post:
nunonuna (05-31-2014)
Old 05-31-2014, 08:43 PM   #91
nunonuna
nunonuna's Avatar
That I thought about it before but I know for sure if someone is trying to steal my car, it doesnt matter really for car thieves. If my car is their target, they can easily get it no matter what kind of security system I have. So why not lol~
나의 SM-N900V 의 Tapatalk에서 보냄
The Following User Says Thank You to nunonuna For This Useful Post:
TRDCal (06-01-2014)
Old 06-01-2014, 12:29 PM   #92
Chaetagnath
Too true. My buddies stock RSX was stolen a couple months ago. The immobilizer and steering wheel lock didn't do him any good. Car was just gone. If they want your car they will get it.
The easy go system does add an alarm in the form of your horn beeping (if you hook it to the horn trigger or a piezo siren if you go that route) if they open the door without disarming. Realistically if you want to prevent theft, always park your car in a secured garage (if you have one), and/or install something like lojack to track the car if it gets stolen.
The Following User Says Thank You to Chaetagnath For This Useful Post:
TRDCal (06-01-2014)
Old 06-01-2014, 10:48 PM   #93
nunonuna
nunonuna's Avatar
Hey OP and others
I just redone all the connections with soldering.
It was never fun because im not really good at soldering
but I guess it is worth trying lol
Now, I just noticed that my car is acting slightly different than before.
After I lock the car, it turns parking lights on for few seconds
and it turns off.
I assume that one of the t-taps wasnt making good connection
(I suspect beige wire in D5 connector but maybe im wrong)
so I was missing it all the time until today.
Is it normal for you guys? or does it look like I did something wrong?
Old 06-02-2014, 07:59 PM   #94
Chaetagnath
Hey OP and others
and it turns off.
That is normal. Should blink once when you lock it and twice when you unlock. It will also chirp the horn.
Old 06-02-2014, 08:24 PM   #95
nunonuna
nunonuna's Avatar
What i mean is it turns parking light on after lock blinker.
What you explain was normal i know but below...
So I lock, it blinks with horn & then second or 2 later it turns parking light on for about 3 seconds and goes away.
Old 06-02-2014, 11:14 PM   #96
Chaetagnath
Yeah that's normal. I'm not sure why it does the longer light. Might have something to do with telling you the alarm is armed.
Old 06-03-2014, 09:44 AM   #97
nunonuna
nunonuna's Avatar
Thanks
Now im really convinced that t taps are not comparison to solder.lol
Old 06-03-2014, 10:10 AM   #98
Chaetagnath
Thanks
Yeah, I think t taps are fine to help set things up initially and make sure everything works, but ultimately they will come loose, which is not a good thing when you need to start your car. Soldering is permanent, and really not that difficult once you do it a few times.
easygo, remote start
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
Q: push button start frs blanco Electronics | Audio | NAV | Infotainment 8 08-09-2013 04:58 PM
BRZ STI push to start button notFRS Interior Parts (Incl. Lighting) 4 04-24-2013 12:24 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
