Old 02-07-2012, 04:53 PM   #85
Levi
Drives: Toyota
I'd like to see how the drop was deleted on the EJ25.
Levi is offline   Reply With Quote
Old 02-07-2012, 05:24 PM   #86
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by WingsofWar View Post
^ thats interesting
I have the same kinda scenario with my EJ251 (1999-2001 2.5RS engine). But its a single cam, non AVCS, oversquared engine.
vs Dual Cam, Dual AVCS, Squared engine.
There is quite a bit of difference between the EJ251 and FA20...
Yet we still see that same awkward dip.
Does the EJ20E and EJ204 and EJ254 see similar output characteristics? What about the FB20 and FB25? Id like to see them next to each other.
If the dip is manifold related then it is likely acoustics. It could be more that the manifold runner lengths are more similar (at least relative to the dip's rpm), even if the motors aren't.
But I would think that the AVCS could tune around most of it, compared to the older non-AVCS motors.
Because titanium.
Old 02-07-2012, 05:33 PM   #87
Mr.Black
Drives: 2012 Mustang V6 Premium, 6Manual
Hi everyone, new here. This SAE paper from Toyota has a manufacture dyno chart of the 2ZZ-GE if someone would like to overlay the dyno if possible.
Mr.Black is offline   Reply With Quote
Old 02-07-2012, 05:42 PM   #88
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
That makes me try to visualize what the acoustics are like at the manifolds. Is it the really the length? or could it be the materials? no wait...the intake manifolds on the EJ251 are metal while FA20 are phenolic plastic.
What about the header...yeah very similar. Is it the OEM EL header causing this?
Check this out!
http://www.rs25.com/forums/f5/t48917...o-results.html
OBX header and a bit of tuning to smoothen out that dip quite a bit on the EJ25D.
WingsofWar is offline   Reply With Quote
Old 02-07-2012, 05:57 PM   #89
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Can I get a repost of the S2000 and BRZ on the same graph?
quik1987 is offline   Reply With Quote
Old 02-07-2012, 06:11 PM   #90
JohnnyR
Drives: 04 Evo 8
Maybe they'll do an access port tune for this thing. That would flatten out the rut a little bit at least.
JohnnyR is offline   Reply With Quote
Old 02-07-2012, 06:53 PM   #91
serialk11r
Drives: '06 AM V8V Coupe
Check this out!
It's the length that matters, because the air will pick up velocity and then as the valve shuts a wave starts to travel in the opposite direction at the speed of sound.
Old 02-07-2012, 07:36 PM   #92
Dimman
Kuruma Otaku
Dimman's Avatar
Also transfer from the exhaust negative pulse during overlap.
Because titanium.
Old 02-07-2012, 07:41 PM   #93
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
oOo you and Dim might be right. Im looking at other dyno comparisons of the EJ251 with different headers. Never really paid attention to acoustics until now.
This short OEM EL like this sees that awkward dip at 3000-4000
This longer OBX EL header smoothens out that 3k-4k dip on some dynos im looking at from other members.
Old 02-07-2012, 07:44 PM   #94
Dimman
Kuruma Otaku
Dimman's Avatar
^ Also stock Subaru headers are connected 'wrong' based on firing order (compare with the stock FA20 on the stand). Just made for convenience.
Because titanium.
Old 02-07-2012, 09:10 PM   #95
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by bambbrose View Post
Originally Posted by ahausheer View Post
Do you really feel torque? I thought it was Hp that actually moved the car, if anything you might feel the slight dip in Hp. Am I wrong?
Yes, you are
You feel torque. Horsepower is just a function of torque/rpm.
No, it's torque that moves the car, and that is what you feel. Horsepower is just some complex number: (torque X 5252)/rpm. It is important, but torque is what puts you back in the seat.
Originally Posted by Longhorn248 View Post
Yup! Dynos don't measure HP, they calculate it from the torque measurements.
  1. What you feel comes from force at the wheels, which comes from wheel torque.
  2. Wheel torque != engine torque, though they are proportional for any given gear ratio.
  3. For any given velocity, wheel torque increases if power increases (regardless of engine torque).
  4. The typical dyno plot does not show wheel torque (discussed last November in the FR-S/BRZ vs. Genesis Coupe thread).
Deslock is offline   Reply With Quote
Old 02-07-2012, 09:38 PM   #96
ahausheer
Re-member
Drives: Toyota camry
So basically Hp is an enabler of torque? Torque moves you forward and hp determines how long that torque can be applied. Off topic I know. Ill discuss elsewhere.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-07-2012, 10:20 PM   #97
serialk11r
Basic physics, go to school :P (in jest)
Old 02-07-2012, 10:47 PM   #98
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It's the length that matters.
That's what she said.
old greg is offline   Reply With Quote
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 12:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 03:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
