Old 02-16-2012, 08:54 PM   #85
T13R
Drives: MKV GTI
Sorry for the confusion guys, I still have my original non-DS3 pad. I use it when my DS3 is not charged. I don't know if it really makes much of a difference to have the rumble or not, just figured I would be specific.
Thanks for the clarification dsgerbc, I guess I need to try harder like you said, although at the moment .4 or .5 is the most I can expect to gain. I'll have to look at your replay to see where I'm going wrong. I still say yours is a fast lap!
T13R is offline   Reply With Quote
Old 02-16-2012, 10:33 PM   #86
dsgerbc
Drives: BRZ(sold), STI
^I should be able to hit 41s @Laguna, but so far I can't put decent sectors together.
dsgerbc is offline   Reply With Quote
Old 02-17-2012, 02:32 PM   #87
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I'm in complete awe at the times you guys are posting for the top gear test track. I've literally seen every episode of top gear and I've only just now bothered to unlock the top gear test track (VW van race was way too boring). It's just now that I'm realizing how technical this course is. It really makes you HAVE to hit every corner just perfectly.
For Wilson I think I go a little bit tighter than the racing line would suggest Chicago is where I'm losing most of my time. Hammerhead is tricky but I think I know how to hit that right. For followthrough I give it just a dab of brake in 4th gear and then power through it while trying to stay close to the cones and then flat out through Bentley while nipping that little corner just the way you're supposed to. And then the rest of the track I'm pretty much good.
Maybe I'm losing time by using the 6MT instead of paddles but since I have the 350mm steering wheel the paddles are a bit of a hassle to use. Any advice guys??
Here is a picture of the track for those unfamiliar with turn names.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 02-17-2012, 03:48 PM   #88
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Import and watch our ghost replays for tips if you haven't.
Paddles + left-foot braking = faster than clutch.
I stay on the throttle during the followthrough.
I turned off the racing line over a month ago and I'll never use it again. Note that it's disallowed, but I'm OK with changing that restriction if others want to use it (it doesn't provide any sort of advantage anyway... it's just a crutch). Anyone else want to weigh in on this?
BTW, I raced more yesterday and beat my time, but not by enough to bother submitting it (1:22.865). I had two runs where I was ~0.250 faster, but I pushed it too much and blew the last corner. Then came the yelling and cursing.
I'm confident that 1:22.4xx (and maybe even faster) is possible on this track, but I'm not consistant enough to get anywhere near it.
Deslock is offline   Reply With Quote
Old 02-17-2012, 06:46 PM   #89
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Turning off the racing lines might be turning people away from entering this competition (at least it kept me away, initially). I practiced with them on first to get an idea of how to attack each corner then realized I could brake later at some points so I turned them off and shaved seconds off my best times.
Old 02-17-2012, 07:06 PM   #90
Deslock
Deslock's Avatar
OK, I updated the rules to allow it.
Old 02-17-2012, 07:51 PM   #91
dsgerbc
Yeah, I did like 22.5x yesterday after being down .1x after the first sector, so it's possible. I doubt I'm even gonna try to hit it though.
Gonna post my replay over the weekend.
Old 02-20-2012, 04:42 PM   #92
switchlanez
Top Gear Test Track
1:23.742 - switchlanez - DS3 - MT
Laguna Seca
1:43.455 - switchlanez - DS3 - MT
Old 02-21-2012, 12:18 AM   #93
T13R
Drives: MKV GTI
Laguna Seca
1'42.878 - T13R - SixAxis - MT
I'll have the pic up tomorrow and ghost lap replay is saved. I still see another .3 seconds to reach my new ideal lap. This is becoming ridiculously addictive, an hour passed by so quickly tonight...
Old 02-21-2012, 07:50 PM   #94
dsgerbc
Spent some more time w/o improvement, so I think I'm done with this. Can't break into 41s
Top Gear
1:22.553 - dsgerbc - CSRE - Paddles
Laguna Seca
1:42.123 - dsgerbc - CSRE - Paddles
Also tried stock gt86, restricted to 200hp in speed test. Best I can do is 6.1x in 0-60 and 14.9x in 1/4 mile.
Old 02-21-2012, 10:22 PM   #95
T13R
Drives: MKV GTI
Top Gear
Laguna Seca
Another 0.2 off on Laguna Seca is pretty good with what your previous time was. I'm glad I had you as a reference or I would have stopped trying long ago. I don't think I'll be able to match your time, but a 42.5 is what I'd like to get before the month ends, another 0.3 to go.
Old 02-23-2012, 12:07 AM   #96
T13R
Drives: MKV GTI
Laguna Seca
1:42.516 - T13R - SixAxis - MT
Another .250 to go get!
Old 02-27-2012, 08:22 AM   #97
Deslock
Deslock's Avatar
The March poll is up: http://www.ft86club.com/forums/showthread.php?t=3917
Sorry about posting this so late. I've been mindful to keep the February thread times updated, but was neglectful in starting next month's poll: I've been busy and the end of the month crept up on me (because it's a short month and I've had pneumonia). But as they say, excuses are like rectums
I haven't even had time to play Laguna Seca, never mind playing either track with the clutch. Judging by the weak turnout this month, it seems others have been busy too.
Old 02-27-2012, 05:16 PM   #98
Gadflyii
Drives: Cleaned out the garage!
Send a message via AIM to Gadflyii
I have no problem with leaving suggested lines on, it does not give anyone an advantage at all, in fact if you follow the suggested lines, you will loose a lot of time.
I have improved my Top Gear track time and will post it later when I get home from work.
Originally Posted by Scion FR-S View Post
Hey, this is ft86club! Bitchiness, snide putdowns, and one-upmanship come with the territory!
Gadflyii is offline   Reply With Quote
8 different GT5 Nordschleife leaderboards with the Toyota GT86 (stock, tuned, drift) RaceR Other Vehicles & General Automotive Discussions 56 11-21-2012 09:56 PM
TAS 2012: Photos of BRZ Black Edition by Prova, GT86 TRD and Modellista TheAsgard BRZ Photos, Videos, Wallpapers, Gallery Forum 15 01-17-2012 09:11 PM
TAS 2012: Photos of BRZ Black Edition by Prova, GT86 TRD and Modellista TheAsgard FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 01-17-2012 09:11 PM
Official GT86 GT5 Stock Lap Times merlin2111 Scion FR-S / Toyota 86 GT86 General Forum 193 01-05-2012 11:56 PM
$125 track day at Willow Springs-Big Willow Track-February 5th in SoCal Louie Southern California 3 01-07-2011 10:26 AM
