Old 04-28-2013, 06:05 PM   #85
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ayau View Post
@Dave-ROR, what do you mean by this statement?
"These dampers don't have as much rear bump as I would like, the rear dampers are about halfway from fall droop to bumpstops currently."
You mean there's not enough bump compression, or there's not enough bump travel?
I'd like more bump travel. There's probably enough, I just like having more.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2013, 06:08 PM   #86
ayau
Drives: Some rust bucket
Is your bump travel reduced b/c you have more preload set? I remember talking with someone from Eibach and they said there's about 3" of bump travel for these dampers (forgot if he was referring to the front or rears). Also consider we're running 650 rates instead of 350.
Old 04-28-2013, 06:08 PM   #87
xwd
What are your current comp/rebound settings? I set mine at 3 comp and 2 rebound right now, needs more rebound I still, maybe one more comp click too, I need to mess with it more but it handles the rates good so far.
I lowered the car about 10mm or so... a little less up front, need to corner balance it eventually.
How long are the bumpstops? Can you use shorter ones? I've used the ziptie trick before just to make sure I was hitting the bumpstops.
Old 04-28-2013, 09:00 PM   #88
ayau
Lowered it one inch. I wonder what's the lowest before the geometry is all messed up. I looked at the rear lower control arm and it's almost flat with the road lol.
The Following User Says Thank You to ayau For This Useful Post:
Hanakuso (04-29-2013)
Old 04-28-2013, 09:53 PM   #89
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I didn't measure, but I'd guess ~3/4"
I lowered the car about 10-15mm (depending on which corner you measure from) on 600lb springs and there's about 1.5" of bump travel pre bumpstop. My concern is a mix of bump travel plus droop. Lifting a rear would suck. I may have to lower more to avoid that (or stiffer via swaybar) but then I start using bumpstops at Sebring. I have to account for the least smooth track surface I've ever driven on
The guys lowering these cars 2" or more have to be riding on the bumpstops all the time. It's also possible the bumpstops slid down a bit making it look worse than it is. I didn't spend much time on it, had to get the car done so I could take a nap before my hockey game tonight.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2013, 09:55 PM   #90
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
More preload would increase bump and decide droop travel. Initially I had the car higher than stock (about 25 threads under the locking collar). It had probably 3/4" droop travel.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2013, 09:59 PM   #91
ayau
Is it that easy to ride the bump stops even with 500/650 springs? I won't be on r-comps, just Direzza II street tires.
Old 04-28-2013, 10:02 PM   #92
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Depends on height and surface. Sebring is HELL on dampers. I'm still happy with them though, they are handling the rates great so far, just need to get some track time to tune them
I'll check with Eibach tomorrow though, I'm sure there's enough travel, I just wouldn't mind having an extra inch (that's what she said).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2013, 10:52 PM   #93
robispec
Drives: Black frs project
might want to look into these
STREET no sheetmetal triming
Adds 2" rear travel
RACE requires rear sheetmetal trimming
Adds 3" rear travel
robispec is offline   Reply With Quote
The Following 2 Users Say Thank You to robispec For This Useful Post:
Hanakuso (04-28-2013), JDKane527 (04-28-2013)
Old 04-28-2013, 11:41 PM   #94
Hanakuso
Street no cutting of the sheet metal added travel is 1.75" at the damper
Race stock rear travel at 3" lower rideheight
Will these fit the R1 and R2?
Hanakuso is offline   Reply With Quote
Old 04-28-2013, 11:50 PM   #95
robispec
yes
Old 04-28-2013, 11:54 PM   #96
Hanakuso
yes
Sweet! I have a few other questions. Cost? Durability? Noise? Any protective paint or something to keep it from deteriorating? I'm mostly interested in the street model
Old 04-29-2013, 12:02 AM   #97
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
This is getting interesting.
TouchMyHonda is offline   Reply With Quote
Old 04-29-2013, 12:05 AM   #98
robispec
Pillow ball bearing = loud just like front camber castor plates.
streets pm for pricing
they are so thick they wont wear out due to "deterioration".
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Eibach Multi-Pro R2 Coilover Review donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 254 05-08-2016 11:56 AM
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
