Old 07-28-2014, 05:42 AM   #85
s2d4
s2d4's Avatar
Originally Posted by akahenry View Post
Just out of curiosity, is it recommended to install a brand new header (UEL in this case) along with an overpipe at the same time? If not, would it be fine to simply install an aftermarket catless header while keeping the stock overpipe? I know for a fact an aftermarket overpipe isn't going to give any significant or noticeable horse power improvement over the stock overpipe, but is it worth it to upgrade to an aftermarket overpipe (performance wise)? Is it worth it to spend a couple hundred bucks on an overpipe for slightly better flow- is my real question. (I feel like this second question is redundant and voids my aforementioned question lol) Comments, suggestions, and opinions are greatly appreciated!
Are you going with E85 or FI later?
Old 07-28-2014, 05:51 AM   #86
akahenry
akahenry's Avatar
Drives: '18 STi
I'm just going to stay N/A and play with E85 once I receive my OFT later on in the Fall. For me, I just want to have that deep boxer rumble, while not having an outrageously loud exhaust set up (my cat back as of right now, is quite loud with everything else being stock in the exhaust department). I know that by replacing the overpipe will give me slightly better flow (probably not even butt noticeable), my worry is whether it'll add too much noise and perhaps "drone" to my future exhaust set up: UEL Headers, stock overpipe, stock front pipe, unresonated cat back.
akahenry is offline   Reply With Quote
Old 07-28-2014, 08:23 AM   #87
s2d4
s2d4's Avatar
Chuck the stock cbe back on, problem solved.
Old 10-02-2014, 01:00 AM   #88
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'll attempt this installation myself when the header arrives. What size is the sensor socket?
Also, does anyone use gasket sealant/maker together with oem gaskets? Or is it not necessary if using brand new oem gaskets? I've got a tube of hi-temp ultra copper gasket sealant and wanted to know if I could coat the gaskets with these?
Fizz is offline   Reply With Quote
Old 10-27-2014, 11:49 AM   #89
Cop
Cop's Avatar
Drives: 2013 FRS
The o2 sensor is a 7/8th. I used this socket in my install:
http://www.harborfreight.com/3-8-eig...nch-97177.html
Cop is offline   Reply With Quote
Old 11-25-2014, 08:47 PM   #90
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
One more question.....is the OEM manifold-to-engine flange bolt an M8 or M10?
Old 01-29-2015, 06:24 PM   #91
deletedbilly
Drives: 04 BMW 330ci, 90 180sx, 13 FRS
thank you for an amazing write up. lots of details and most definitely written by a true tuner and builder. if you happen to have a 2015 model lying around and would like to do another write up for our exhaust and diffuser, let me know - would love to work something out with your club email me at billyb@borla.com thanks guys!!!
deletedbilly is offline   Reply With Quote
Old 08-18-2017, 11:33 PM   #92
Mchilese
Mchilese's Avatar
Drives: '14 BRZ Limited
Originally Posted by F1point4 View Post
Finally. Thank you all for being patient
20130323-BorlaUELHeaderDIY-001 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-002 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-003 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-004 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-005 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-006 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-007 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-008 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-009 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-010 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-011 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-012 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-013 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-014 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-015 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-016 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-017 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-018 by VictorN07, on Flickr
I goofed and forgot the supplied 2 black bolts and nuts. Instead I used some grade 5 nuts and bolts supplied by Phastek. Thanks Chris@Phastek!
20130323-BorlaUELHeaderDIY-019 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-020 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-021 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-022 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-023 by VictorN07, on Flickr
20130323-BorlaUELHeaderDIY-024 by VictorN07, on Flickr
Thanks for putting this up. I got a JDL header, and man, this write up just made it smooth sailing. Many, many thanks!
Sent from my Moto G (4) using Tapatalk
2014 BRZ
Mishimoto intake tube/TSW Nurburgring 18x8/Firestone Firehawk Indy500s/PLM muffler delete/JDL catted UEL headers
Mchilese is offline   Reply With Quote
Old 05-10-2021, 04:06 PM   #93
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
Is the header-to-overpipe gasket the same as the front pipe-to-catback gasket? Should I replace the front pipe-to-catback gasket at the same time?
jkamelo is offline   Reply With Quote
borla, header, unequal length
Borla UEL Header - Pics / Videos / Dynos - FT-86 SpeedFactory Review FT-86 SpeedFactory Engine, Exhaust, Transmission 533 04-01-2015 12:10 AM
>>>>Rev Works UEL (Unequal Length) Header - Specs, information, & Customer Review<<<< Rev Works Engine, Exhaust, Bolt-Ons 917 08-04-2014 11:52 PM
BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! NJA Announcements, Contests, Giveaways 6 04-03-2013 05:47 PM
unequal length headers 001BRZ Engine, Exhaust, Transmission 10 07-21-2012 01:20 AM
