Old 03-28-2013, 07:57 PM   #85
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Calum View Post
205/177 so they dynod a header?
Don't forget the e85
JoeBoxer is offline   Reply With Quote
Old 03-28-2013, 08:40 PM   #86
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
The gains look to be pretty close to what bullet achieved with their pre-production kit and the figures they're advertising with the retail kit. They made identical gains at 6000rpm but cusco made a bit more down low, the lower gains could be due to the 100ron fuel in japan v's the 98ron bullet/mercury were tuning with.
Apply ~40% to your american base figures and you'll end up in the ballpark of what you can expect on Dyno's over there.
JP is offline   Reply With Quote
Old 03-28-2013, 08:43 PM   #87
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
72% torque increase in the dip eh? That should be interesting to see.
industrial is offline   Reply With Quote
Old 03-28-2013, 09:45 PM   #88
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
here are 205hp and 177ftlbs charts
-Edit- while it says Flywheel, based on the right side chart baseline as pointed out a few posts down, I think its WHEEL-
while I like the early onset of near max TQ-thats cool!!!-, it does drop off rather more than I'd like after 5600 rapidly towards the 7400 (where I want warp speed). Dont see 7400+ as much value based on the direction of chart..
Below it is my Vortech map, for reference, higher final numbers but you can see the twin humps from each screw clearly, leaving sort of a TQ dip in one area while curing one in another- very interesting. It will have more seat of the pants as you start off each gear but as you wind out it will pull less versus mine, where I will have much less TQ down low, but more up high that takes me to redline.
I can see where each kit has its merit
I checked with OP for permission before posting before folks have a cow:happy0180:.
Huehuecoyotl is offline   Reply With Quote
The Following 2 Users Say Thank You to Huehuecoyotl For This Useful Post:
Pete (03-28-2013), swift996 (03-28-2013)
Old 03-28-2013, 10:02 PM   #89
JoeBoxer
JoeBoxer's Avatar
Oh no it says flywheel hp and torque, everybody is gonna freak out.
Old 03-28-2013, 10:05 PM   #90
Huehuecoyotl
If thats the case, is that same as what we call CRANK? So this IF this is before drivetrain losses, so what is that 85% of 205=174.25WHP, and 85% of 177 is 150WTQ
someone check the math...
Old 03-28-2013, 10:14 PM   #91
swift996
swift996's Avatar
So the 210 rumor was true..about what I expected at this point. I'm sure the non-intercooled version makes close to the same. Perhaps with time and tuning they will find a way to get more power from the unit.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-28-2013, 10:16 PM   #92
JoeBoxer
JoeBoxer's Avatar
Flywheel = crank
PS does not equal HP though not sure how all that works.
Old 03-28-2013, 10:19 PM   #93
Huehuecoyotl
Flywheel = crank
I checked the 205HP/177TQ crank math is right in terms of the conversions
Old 03-28-2013, 10:22 PM   #94
R2
I wouldn't read too much into that "Fly Wheel" wording on top of the dyno chart. It's all relative to the baseline curve shown on the same chart. We know that one should be equivalent to 200hp at the crank at standard atmospheric conditions at sea level. Given that, I suspect we are seeing whp, regardless of what the dyno chart says.
Nonetheless I am happy to see the low rpm gains.
R2 is offline   Reply With Quote
Old 03-28-2013, 10:28 PM   #95
Huehuecoyotl
Ya know I think youre right..
Now that I look closely,
based on the red line for base HP, if its 159PS thats like 157HP I think, and if thats the case then yes, this is a WHEEL chart
Not bad ...
Old 03-28-2013, 11:01 PM   #96
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
205 crank hp? Think about this for a minute....
Stock, this car is 200 crank hp. There's no way adding .94L of air will only net 5hp.
The Following User Says Thank You to Draco-REX For This Useful Post:
Huehuecoyotl (03-28-2013)
Old 03-28-2013, 11:11 PM   #97
Pete
Pete's Avatar
Drives: 22 BRZ
I am an idiot sometimes, disregard this post plz.
Pete is offline   Reply With Quote
Old 03-28-2013, 11:15 PM   #98
swift996
swift996's Avatar
That is at the wheels there is no point in debating it. I've seen plenty of dynos say flywheel when they show at the wheels.
Our Silver Bullet - FT-86 SpeedFactory FT-86 SpeedFactory Member's Car Journals 151 10-07-2016 12:57 AM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 11:25 PM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 07:11 AM
Bullet Performance supercharger by Mercury Performance mastertech86 Forced Induction 219 10-24-2012 07:01 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
