Old 03-26-2013, 12:57 PM   #85
reeves
Originally Posted by swift996 View Post
Sort of a simple question, but how much louder is the catted version with the rest of the exhaust OEM? Also, does this work with the OEM airbox? It's hard to see if it would.
Not the best video/recording.. but it was the only clip I took.. and the audio of the exhaust is fairly accurate in it.. http://s965.photobucket.com/user/pdx...024b6.mp4.html
If I come across anyone with a better recorder, I'll try to post more clips.. but I've said before, I'd rather spend money on mods than an expensive recorder.
I'd describe the sound similar to a good quiet aftermarket exhaust.. definitely a little louder than stock, but not by much.. and definitely not raspy.. unless you consider that clip (at the very END, driving away) on the raspy side. You hear how it sounds on WOT.. sound is so subjective, you can judge for yourself. It's not a boxer "rumble" either but I like the subtle aggressiveness of the sound now.
I had a resonated front pipe installed along with the header, so if you keep your stock front pipe (with the 2nd cat) it might even be quieter.
reeves is offline
Old 03-26-2013, 01:09 PM   #86
swift996
swift996's Avatar
Originally Posted by FA20Club.com View Post
fits with every intake ive come across just fine its allot lower than what you think.
Ok, I saw in the dyno video. The one pic angle makes it look like it's a close fit.
EDIT- Do you offer thermal coating? (I saw you do w/ the turbo kit)
I see it on the website. How long of a delay would it take? I'm interested in the black thermal coating or are they ready to ship? Also, will it bolt to the OEM over-pipe? I'm ready to order, just want to confirm.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 03-26-2013, 02:43 PM   #87
FA20Club.com
Drives: 2013 White Out FR-S
coating will add another week tot he order. we are build some end of this week. just have to cut these PIA collectors for the headers and turbo kits we sold this past weekend. and they are time consuming LOL. i would never coat anything ahead of time just like our intake i coat them after the order is placed even when they are instock. fits the factory over pipe just fine. thats how we designed it so you can bolt it onto a stock car.
FA20Club.com is offline
Old 03-26-2013, 02:44 PM   #88
FA20Club.com
Originally Posted by reeves View Post
Na it's got plenty of room.. in fact I'd say it's the exact opposite in terms of heating up.. the header works so much better [than stock] in moving air through the engine (and intake), once you get going, the intake cools down just fine.. it's always within 2-4 degrees of the ambient air temps when I'm driving (monitored with Torque Pro app). The harder you drive, the faster it cools down.. and stays cool!
this angle give a much better view of how far away this thing is from the intake tubes.
Old 03-26-2013, 03:34 PM   #89
swift996
swift996's Avatar
I just ordered mine!
swift996 is offline
Old 03-26-2013, 05:00 PM   #90
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Is the the cat metallic or ceramic core? And is the Cat warrantied?
Mobius357 is offline
Old 03-26-2013, 05:04 PM   #91
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by fenton View Post
Is a tune required with this header? I have Visconti stage 1, im very interested in these long tube headers. It seems like everyone is jumping on this after Nameless posted their results. I know FA20 club tuned a set of P&L long tube headers, are these the same(they sure look the same)?
Not to make this a pissing contest, but we had the P&L dynos up a week before Nameless posted their dynos.
http://www.ft86club.com/forums/showp...postcount=1022
VS
http://www.ft86club.com/forums/showp...21&postcount=1
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 03-26-2013, 05:19 PM   #92
FA20Club.com
Metal Core....50K warranty
Old 03-26-2013, 06:14 PM   #93
fenton
VS
True. Nameless design is different than both of these though. Nameless dyno looks very different while p&l and this look.....identical.
Nameless posted teasers a couple weeks before if I remember correctly. Showing the vband connection and whatnot. Either way all these options are good for us
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline
Old 03-26-2013, 06:14 PM   #94
swift996
swift996's Avatar
Would you mind sharing your overpipe/front pipe setup/specs? I ordered the header and might want to do the same. The clip sounds great, exactly the type of sound I'd want.
swift996 is offline
Old 03-26-2013, 06:33 PM   #95
fenton
VS
This is what I'm referring to.
http://www.ft86club.com/forums/showthread.php?p=703197
fenton is offline
Old 03-26-2013, 06:42 PM   #96
Mobius357
Please! Please! This is supposed to be a happy occasion! Let's not bicker and argue about who killed who.
Old 03-26-2013, 07:04 PM   #97
Hawaiian
That guy
Hawaiian's Avatar
Those photos show the 4-2-1 header and not the 4-1. The reason for the similarities between the fa20club and P@L headers is they are both designed with a front mounted turbo upgrade in mind, however the Vband placement is different for both products. For the Fa20club it's right after the merge, while the P&L is after the initial bend.
It looks with the placement of the Nameless Vband it was mainly so they could test 2.5" and 3" setups, letting them change the outlet to the overpipe. There is little functionality they can get out of a Vband located there.
Ultramarine mt FR-S
P&L stage 1 turbo
Hawaiian is offline
Old 03-26-2013, 07:17 PM   #98
FA20Club.com
I tried a 3" exhaust when i was NA after i did my first tune and the damn thing lost 9whp. i was able to retune and get it back but see any real gains. I only went 3" cause i was gonna build a turbo kit. the exhaust is still on my auto car thats part of the reason i dont test certain products on the auto anymore cause my baseline would be low.
swift996 pm sent
header, turbo manifold
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
FA20CLUB Power Pack #1 Tested FA20Club.com Engine, Exhaust, Transmission 31 01-16-2013 03:32 PM
Borla cat-back w/ UEL header tested at the track BeltedBiscuit Engine, Exhaust, Transmission 17 12-30-2012 02:57 AM
Turbo FR-S Tested For Drift Reportedly Spotted DanPO Scion FR-S / Toyota 86 GT86 General Forum 123 01-24-2012 01:25 AM
