Old 08-18-2013, 12:38 AM   #85
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by tonystewart View Post
King Tut
Have you experienced any leaks?
How did you remedy the situation, if you had leaks?
The only leak I have noticed was from the oil filter adapter, but I did not torque it down initially. I removed everything and cleaned it up and applied new oil to the seals and torqued it down. I haven't removed the bumper to take a good look at the oil cooler fittings though. I can see one of them through my brake duct though.
Old 09-19-2013, 11:55 PM   #86
nix
nix's Avatar
Drives: AVO BRZ
I had a leak in one of the hose end fittings on my kit.
Edit. Also custom fabricated brackets since the one included angled the core at a different direction to what we found optimum.
nix is offline   Reply With Quote
Old 09-20-2013, 12:02 AM   #87
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We had some fittings that were bad. We have since changed suppliers. Please pm me if you have issues and we will replace them.
FullBlown is offline   Reply With Quote
Old 09-20-2013, 01:08 AM   #88
BRZ NA
Drives: WR blue
Any NA version?
BRZ NA is offline   Reply With Quote
Old 09-20-2013, 08:45 AM   #89
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by BRZ NA View Post
Any NA version?
Our kit will still work with NA
Old 09-20-2013, 10:15 AM   #90
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I still haven't pulled my bumper to really look at mine again, but I don't think they are leaking still.
Old 09-20-2013, 12:36 PM   #91
BRZ NA
Drives: WR blue
The engine might run too cold w 19 rows for NA, isn't it?
Old 09-20-2013, 12:39 PM   #92
M1K3
M1K3's Avatar
Drives: vrooom...
Doubt it, sandwich plate has a T-Stat in it.
M1K3 is offline   Reply With Quote
Old 09-21-2013, 01:50 PM   #93
charged86
charged86's Avatar
this is a great location for vortech users because of placement of the washer tank.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 01-29-2014, 02:30 PM   #94
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
going to order this soon
Old 03-03-2014, 12:53 PM   #95
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
Can anybody chime in that might be running this with the Vortech kit? It looks like it should fit, but I just want to see if anyones running it already before I go ahead and order it.
reyruiz191 is offline   Reply With Quote
Old 05-17-2014, 03:40 AM   #96
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Hearing nothing but great things about this kit. Might get this over the Perrin oil cooler.
Carlitoz3 is offline   Reply With Quote
Old 06-12-2014, 08:21 PM   #97
deange
Drives: Black 2013 BRZ Limited Automatic
I've got the FBM kit on my car along with a Vortech supercharger. I trimmed the hoses slightly shorter and put 90 degree ends on the hoses where they connect to the sandwich plate. I'll admit that the install wasn't quite as easy or seamless as the Perrin kit (took it off because of a major leak) but it is solid and doesn't block the airflow over the intercooler / radiator. I didn't have the Vortech when I installed the Perrin kit though, so it isn't exactly an apples to apples comparison. Either way I'm happy with it after 5,000 miles on the cooler.
deange is offline   Reply With Quote
The Following User Says Thank You to deange For This Useful Post:
reyruiz191 (06-13-2014)
Old 06-13-2014, 01:52 PM   #98
reyruiz191
reyruiz191's Avatar
I've been contemplating running this oil cooler along with my Vortech kit for awhile now but I didn't know of anyone that had actually done it so I was worried about the fitment. Thanks for the review, makes my choice a lot easier.
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
You want it, you got it: PERRIN Oil Cooler GB JoeBoxer Groupbuys 96 06-16-2013 03:10 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
