#85 |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
I think a lot of autocrosses (I am one) think the track is boring mostly because in their slow cars that have crap loads of time between the turns...insert BRZ/FR-S looking at power to weight but I'll be fixing that.
Having done FSAE back in college and being one of the drivers, I find Auto-x so boring that I want to cry...unless I'm in an FSAE, XP or well prepped SM/SM2 car. |
#86 |
I'm a Carcissist
Drives: JERRV , 11 STI, 07 FJ
I'd like to give autox a go.. never hurts to try i guess.
I am Ron Burgandy?
#87 | |
Site Moderator
Drives: Stuff
To me, autocross is great at teaching car control at low speeds, but that's about it.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#88 | |
Site Moderator
Drives: Stuff
Earlier you said "learn more", but here you said "not exciting and competitive". Which did you mean? I can certainly agree with the competitive part (one is a competition, one isn't). Exciting, well that depends on your personal taste. I get bored with autocross but then I'm anywhere from 1.5-3 seconds faster than the 2nd place guy in my class. I don't do many HPDEs anymore (W2W instead) but when I do them I have fun doing them. Learn more.. I think you learn at both, you just learn different things. I do things on the autocross course that I would NEVER consider doing on track.
-Dave
#89 |
Drives: 05 Nissan Sentra Se-r Spec V
The BRZ/FRS should be in STX, since it has a torsen LSD, rather than a viscous type...That is where I plan on running it! Street tires for the win!
#90 |
Drives: 128i, Z3 Coupe, Fiero GT
Autocross is a fantastic place to learn basic car control in a controlled environment. It also teaches you to read the road and adjust very quickly. It is the best place to start, ASSUMING that you have some experienced guys ride with you and give you tips!
From there, instructed HPDE is the way to go to advance the skills that you built a foundation with in autox. If you're not having fun on track, then you're probably not pushing yourself very hard. If you've become a student in the most experienced run group, then you should start looking at competition / club racing schools, and/or private coaching. Your eyes will be opened by this! Once you make the move to go w2w, find a class that has lots of competition ("spec" classes are great for this) with little focus on out-spending your opponents. Spend that "mod" money on private coaching. Then you have Endurance racing, which is a whole 'nother breed that must be experienced to be appreciated.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT 2017 Pirelli World Challenge TC Rookie of the Year 2012 NASA SpecE30 National Champion www.DriveFasterNow.com |
#91 |
Drives: Subaru BRZ Limited
100% positive that i will be auto crossing this baby
#92 |
Drives: 2005 Honda Civic
I'm going to auto-x this baby for sure! can't wait for the actualy release date.
#94 |
Drives: honda civic si 08
The only reason why I'm eyeing this over the focus st is because I want to autox and I feel this car will be better for it. However the ST just looks so damn practical.
#95 |
Drives: 2013 Whiteout FR-S
Like i said my plan before.
Buy it on a Friday, Friday night strip out interior. Sat Drift into a Lightpost! Can't wait. |
#96 |
Drives: ND2, formerly BRZ (MT/CBS)
FR-S or BRZ for SCCA Stock / Factory Service Manual Availability
So under SCCA stock category rules, you are limited to whatever camber adjustment is available in the stock suspension plus any adjustment you can get from factory offered 'crash' bolts.
According to the motoiq article (link), there is no camber adjustment built-in to the FR-S knuckle to strut bolts. According to the 2005 Scion TC service manual (available at scionlife.com), two factory crash bolts can give up to 1.5 deg. of adjustment from a spec value of -0.5 deg. According to the 2009 Impreza service manual (available from dirtysubie.com), the stock subaru cam bolt gives a total adjustment range of 1.5 deg with a spec value of -0.17 deg. So assuming Subaru and Scion follow through with different methods, we might have to choose between: 1) the BRZ with 'stiffer' front springs and maybe 1 deg. of static camber or 2) the Scion with 'softer' front springs and maybe 2 deg. of static camber Any thoughts on which would be better with the latest Hoosier DOT 'stickies'? (Keeping in mind the factory shock tuning won't be a factor since dampers are free and one sway bar is also free.) Any thoughts on when we'll see factory service manuals to really nail down the camber issue? |
#97 |
Site Moderator
Drives: Stuff
They have the same suspension, so I highly doubt the max neg camber out of the stock car will vary between the two. It's basically an Impreza suspension so I'd suspect it'll be similar to an Impreza.
-Dave
#98 |
I fully agree that the max neg camber out of the stock car will be the same for both cars if the same strut to steering knuckle bolts are used on both.
Unfortunately, the SCCA will only allow what is documented by the OEM. While it seems like a Subaru suspension and Subaru engineering, I think the lack of a cam bolt as noted by motoiq throws the adjustment method into question. Open questions in my mind until we can see some production cars delivered or see the FSMs: Will there be cam bolts (per normal Subaru practice) on all final cars (Scion and BRZ) and it was just missing on the car motoiq reviewed? If so, Scion/Toyota technicians will be doing alignment the Subaru way instead of what they are used to. Perhaps there won't be cam bolts on any cars and it will be the Subaru techs that will have to do alignment the scion/toyota way with various diameter bolts? Perhaps the two makes will keep their procedures similar to their past practices and the cars will actually have/offer different bolts? |
