Old 03-04-2013, 09:59 PM   #85
2forme
Originally Posted by qtwre View Post
Sorry to hear that. Especially because of the increased price for that imaginary feature compared to the other listings.
I just order the Appradio 2 today based on your recommendation. I got it and the android adapter kit along with the metra wiring harness, dash kit and antenna adapter for $418. All from Amazon. My plan is to find a used compatible Android phone and leave it permanently in the glove box.
I have an HTC evo 3d that looks and runs like new. Already rooted with S-Off. I'd be willing to let it go for ya for a decent price. Works great with the App Radio 2.
Old 03-04-2013, 10:00 PM   #86
2forme
Originally Posted by Skorov View Post
Could they have sent your the wrong model by mistake? They do look identical.
No, they mislead the seller. He sent me a message telling me the supplier lied to him and he's giving me a full refund including shipping once I return from Hawaii
Old 03-08-2013, 07:48 PM   #87
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
As per my question earlier about the TV antenna. THIS
is what i went with. At first i thought i needed an adapter because it didn't seem to fit in the receiver(phrasing?), but i just didn't push hard enough.
I haven't tested it beyond getting some barely recognizable static in my garage, but atleast it picked something up. I'll update after a few days.
Trashed675 is offline   Reply With Quote
Old 03-08-2013, 10:27 PM   #88
xjohnx
Grip>Slip
xjohnx's Avatar
wouldn't you need a digital tuner for the TV to work now that the old style has be decommissioned?
Old 03-09-2013, 11:09 AM   #89
Trashed675
Trashed675's Avatar
Best answer i could come up with is maybe. Documentation on this unit is basically none existent so i'm working under the assumption that it had a DTV tuner built in, which may be why i was only getting one very staticy channel. But as of yet, its only cost me $10 so its not a huge heartbreak if it doesn't work.
I'll do some more research and report back.
Old 03-09-2013, 11:20 AM   #90
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
i just got mine in yesterday and wired it all up, but im having an issue getting the black trim piece snap back in to place around the HU. it doesnt seem to have enough space to fit it anymore. Anyone have any tips to get it back on?
Note: ive tried with and without the metra dash kit and same problem, it just seems to not fit over the HU
ph0en1xtk is offline   Reply With Quote
Old 03-09-2013, 05:55 PM   #91
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
I had the same problem - you need to angle the radio correctly by bending the metal brackets for it to fit. It's a bit of a pain getting it perfect.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-09-2013, 11:43 PM   #92
ph0en1xtk
ph0en1xtk's Avatar
any tips on doing so? i tried bending them a little bit, but it didnt help.
It seems that the head unit needs to be further recessed than the stock brackets will allow it to be. I tried just setting it in the dash, and putting the trim piece on, and the end result had the head unit sitting further back than it does when i have it bolted down. I cant seem to find a way to bend them that would accomplish this.
Also, for 2forme, or anyone else who has this unit, theres a couple things im trying to wrap my head around.
1. When watching a dvd, is there any way to set the view mode to full screen rather than the widescreen w/letterboxes? I can zoom in with the remote, but it leaves a prompt on screen that says zoom 2x that i cant get rid of.
2. Where do you guys have the GPS antenna mounted? I put mine on the metal dash bar that runs across the inside of the dashboard, but im not sure if this is an optimal location. Id like it to be on top of the dash in the center by the defrost vents, but i cant find a way to route the wire.
3. Are there any alternative apps to run ipods? The stock one doesnt allow folder stacking like "artist>album>song" it just goes "artist>song" or "album>song" A minor inconvenience, but one that id like to figure out regardless.
4. When i turn the car off, my ipod doesnt stop playing. On the fr-s stock HU, it cut off and resumed my music at the same location when it came back on. This one will have played the whole album if the car was off long enough. Any fix for that?
I know its a lot lol, but im trying to get everything on this working as perfectly as possible.
Old 03-10-2013, 03:32 AM   #93
sav
sav's Avatar
I've had a couple of different units in my car, each requiring different mods, but this is what I've done to date:
-Flattened the top of the bracket in a bench vice
-Drilled the holes out slightly to give it more movement
From there it's just a lot of trial & error with the angle of the brackets on the radio and pushing the tabs in and out until it fits just right.
As for the GPS, my radio is not exactly the same but I've got it under the dash and reception seems to be good.
95RON SAV Tuned
Old 03-10-2013, 10:21 AM   #94
2forme
I just shaved off the plastic rim around the head unit itself. Dremel works wonders. That way I didn't have to modify the brackets or stock trim piece.
It's only really the top and bottom. But I did the sides to for shits and giggles.
Old 03-10-2013, 03:17 PM   #95
bobpuffer
bobpuffer's Avatar
Drives: FR-S Hotlava 6-speed
I've had good results using longer screws and stacking tight rubber grommets over the screws after they've been threaded through the mounting bracket.
bobpuffer is offline   Reply With Quote
Old 03-12-2013, 10:38 PM   #96
ph0en1xtk
ph0en1xtk's Avatar
anyone using this got any other apps that will play dvd's or run ipods that i can use? winamp, mx player, and the others dont support dvd/ipod, and i dont particularly care for the ones that come installed with this unit
Old 03-12-2013, 11:01 PM   #97
privfaith
Drives: RX8 -> 2013 FRS
http://www.wondershare.com/dvd-tips/...vd-player.html
Still looking for ipod reader
privfaith is offline   Reply With Quote
Old 03-12-2013, 11:12 PM   #98
2forme
I'm going to be trying to design an iPod reader app myself. I think I also have a copy of the ca fi one too. Its a bit nicer but I don't know if it works yet.
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
