#85 |
Drives: 2013 WRB BRZ 6MT
If anyone does know them, could you also post them in this [url href="http://www.ft86club.com/forums/showthread.php?p=2200145"]torque value thread[/url]?
#86 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
#87 |
Drives: None
Finally finished mine! Just need to install the shifter and over pipe to the headers. Speaking of shifters, I installed my trd quick shifter to while I was under there
![]() Sent from my LG-D850 using Tapatalk |
#88 | |
Drives: None
#89 |
Drives: '13 SSM BRZ Limited 6MT
What step(s) take the longest? The OP mentioned it took him 9 hours however the steps don't seem to be that many. Also this video: [ame="https://www.youtube.com/watch?v=CYsW7poYsG0"]Exedy Clutch Overview and How to Install in Scion FR-S - YouTube[/ame] makes it look super simple as well lol. Not being disrespectful, just curious.
#90 | |
Drives: None
| The Following User Says Thank You to Astroboy For This Useful Post: | tracerit (01-04-2016) |
#91 |
Drives:
Also take into account experience level and the right tools.
| The Following User Says Thank You to 08stiguy For This Useful Post: | Astroboy (01-05-2016) |
#92 |
Thank goodness for this DIY guide!
The removal and install was a breeze aside from the one bolt shearing off in my down pipe. The only other thing I really had an issue with was torquing down the two 2 bolts on the transmission. There are so many things in the way, not to mention my bulky AEM strut brace as well, that it created a torque wrench fitment nightmare. |
#93 |
Drives: 2014 BRZ Limited [6MT/SWP]
Just installed mine.. have about 200 miles on it so far. Anybody else have a harmonic rumble when decelerating / coasting in gear? I have it occur between 2.5k and 3.5k rpm, and was told by someone that it's normal it's just usually chatter or gear rattle. While I get that this is a "performance / sport" clutch, it's only a stage 1 and not harsh at all so I wouldn't expect much NVH from it, so I'm not sure about that answer, anybody else have similar issues? Was it an install error?
PS - I have the stock flywheel in
| The Following User Says Thank You to Jhood For This Useful Post: | Astroboy (07-20-2016) |
#94 | |
Drives: None
#95 | |
Drives:
Normal. I have that happening on my stock clutch. Does the noise go away when the clutch pedal is depressed? Sent from my iPhone using Tapatalk |
#96 |
Yes as soon as I put my foot back on the gas pedal, or if I press in the clutch, the noise stops.
#97 |
Drives:
#98 |
Well that video in post #89 pretty much showed me that this is a job that's beyond my driveway mechanic skill set. Bummer...
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 01:11 PM |
| Chase Bays Clutch Line, Full Replacement | Chase Bays | Transmission and Driveline | 1 | 02-11-2013 03:57 PM |
| Clutch/flywheel replacement? | bucket | BRZ First-Gen (2012+) — General Topics | 1 | 11-19-2012 01:25 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
