#85 |
Drives: Toyota 86
Did my 15000km service today. Told the service advisor to ensure that the correct spares where available. Even that didn't help as the filter and oil had to be ordered on an emergency. Technician commented that it took more oil than was indicated ... Basically 6l. Also found it very strange that the oil filter was replaced with another Subaru branded unit. Went into the workshop to find the spare just to ensure it was actually replace. My coolant was topped up about 2300km ago with the pink toyota coolant. According to technician that is acceptable and approved by Toyota... Don't quite believe that but what option do we have. No problems experience so probably ok. I noted that the technician also struggled to fit the air filter after cleaning it as was commented elsewhere on the forum previously. Technically one should never blow a filter with air as it can get damaged.
#86 |
Drives: Toyota 86, Pearl White, Manual
i laughed when the technician was looking for the oil filter underneath the car and i had to correct him... but hey they all have their first one... what i liked is that i could stand by while all the work was done... guess what even the muffler box is embossed subaru...
#87 | |
The voice of reason...
Drives: 2012 Toyota 86 6MT Standard
#88 |
and the speakers... trust me when i say they are worse than a yaris... and the guys with the autos at least have a sort of a toyota gearbox.. oh and the key! its a toyota key! if you have a standard...
#89 |
True forgot about the Hilux key!
#90 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Recommendation - find a express Toyota dealership, book for early oil change. This enables drive in and change within 30 min, get charged for 30min labour.
2 days before you go in call the parts, order the 7 bottles of 5w30 and a TRD oil filter, to ensure in stock on your arrival. 7th bottle plus left over of the 6th if any is your top up oil. TRD filter is around R100 more if I stand to be corrected. I also stood and watched, to ensure the mechanic knew what he was doing. In most cases the dealerships are geared up as there are enough 86's in the country now... |
#91 | |
Drives: Red Hachiroku
http://kaizenfactor.wordpress.com/20...e-know-so-far/ Agree that the speakers are bad. |
#92 |
Drives: whiteout FRS
whoops.. wrong spot. Sorry folks
#93 | |
#94 | |
However in Japan you get crazy people pumping their Skylines and Supras up to 1000 HP - that would seem to be a bad idea here
#95 |
Also keep in mind that this car was built to a price as well. In my opinion too much power in this tail-happy car will eventually get you killed.
#96 |
Drives: Toyota 86 std Dark Grey metallic
Went to dealers today ~ they have 5w30 that comes in 5litres for R350 or so ~ I ordered today.
#97 |
Drives: 86 High M Pearl White
Picked up my 86 on Thursday.
Is it recommended to do an oil change after the 1st 1000km? |
#98 | |
Road Warrior
If you require top up during this period, then ensure you use 0w20 synthetic as this is the oil in from production. So we believe.... Run in period is 1600km. Enjoy. |
