Old 01-06-2013, 08:56 PM   #85
Yruyur
Yruyur's Avatar
I swear to god there is a force preventing me from getting this data. I think my obd adapter went bad. It will pair but will constantly drop connection with my phone.
Ill have access to another adapter in a few days.
If some one has acces PLEASE run a full pid scan with the car on but not running. Then unplug the temperature sensor cable and run another scan. Give me the two files and I will take it from there.
Old 01-06-2013, 09:11 PM   #86
Future
Future's Avatar
Drives: BRZ!
i'll have some spare time tomorrow, will try it.
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 01-06-2013, 09:15 PM   #87
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
So the "Gold bolt" switch on the right is the oil temp sensor? I will check on that and see what I can find tomorrow. Can someone who is an expert at wiring trace and see where the wire ends up at?
LeeMaster is offline   Reply With Quote
Old 01-06-2013, 09:22 PM   #88
Yruyur
Yruyur's Avatar
Yes the brass looking one. There is a little release on the plastic to discinnect the wiring. Most likey it goes to the ecu.
Old 01-06-2013, 11:31 PM   #89
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
I have a 4 day weekend so will try this this weekend.
Sent from my flux capacitor using Taptalk
I have an infrared laser thermometer if you need to borrow one
chrisbfrs is offline   Reply With Quote
Old 01-07-2013, 01:42 AM   #90
Yruyur
Yruyur's Avatar
Thanks. I dont think we will need one now. We should be able to het the negative value from when the cable is unplugged and the actual value. These should be enough.
Old 01-07-2013, 09:21 PM   #91
Yruyur
Yruyur's Avatar
Anyone have a chance to grab a scan. I have borrowed a obd adapter and bluetooth usb adapter. My phone and my friends phone dropped the Bluetooth connection not to far into the scan. Its too fricken cold outside so im in for the night. If someone can get some files tonight I have a few hours to check them out.
Old 01-09-2013, 12:17 PM   #92
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I really wish I could help out, I wish there was more people willing to help out, hopefully you can get someone to send you the files or you can get yours to work, appreciate the effort you're making!
Brody
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 01-09-2013, 02:01 PM   #93
Bleevin
Drives: 2013 FRS - Whiteout
On a different topic... I was wondering if anyone else is using the Fuel % from ecu? If so what % off is the torque reading compared to the gas guage?
I'm finding that the there is a 25% - 35% difference between the 2. When my gas gauge reads 50% torque is telling me I'm at 80% full. Which one is accurate or closer to accurate?
Bleevin is offline   Reply With Quote
Old 01-09-2013, 03:48 PM   #94
elrod
elrod's Avatar
Drives: WRB BRZ Limited MT
I have attempted to acquire the requested data but I apparently don't know how. I do have an ELM 327 v1.5 adapter that communicates well with my tablet. I do have the Torque Pro app. I see the Torque Scan on the menu and it gives me the list of working PIDs in green and the others that are not working. The only way that I know to record data is to use the track record off of the Real Time Data on the menu. I feel sure this is not the data you want since it is only what I have specified to record.
Please enlighten me so that I can be of help.
elrod is offline   Reply With Quote
Old 01-09-2013, 04:23 PM   #95
Yruyur
Yruyur's Avatar
I think this depends on the fuel capacity you set in the torque app. Ill compare to what fuel level my ecutek says.
Old 01-09-2013, 04:27 PM   #96
Yruyur
Yruyur's Avatar
Go to plugins. Install torque scan. Open it from the main menu. Hit menu select pid scanner. Try running a normal scan at first to see if that cintains the data we need. Run scan again without the oil sensor plugged in. I would make sure the car has been sitting for a while in case other values change from the first to second one. If the scan does not contain the data then try the full scan.
Old 01-09-2013, 06:48 PM   #97
elrod
elrod's Avatar
OK, I guess I need more help. I have gotten the scan to run multiple times. I don't seem to have a choice in what type of scan. Sometimes they run 5 or 6 minutes. Sometimes they run for over 30 minutes. I seem to have no control. I have captured one 'short' scan and emailed it to myself.
I suggest you PM me with an email address that I can send it to. I have to eat now and go somewhere. I will try to get another try in tonight when I return home. BRZ is sitting in the garage due to nasty weather so it will still be 'cold.'
Command: 2100 response:6100BC000001
Command: 2101 response:
01F
0:610100000000
1:5564463E643F00
2:000000000D2B55
3:2120004306CD09
4:632FC93E000000
Command: 2103 response:61030180878000
Command: 2104 response:
00F
0:610476ED8000
1:46648000800000
2:80800000000000
Command: 2105 response:
008
0:610506154DDF
1:01900000000000
Command: 2106 response:
00F
0:61068107E500
1:0303000077E5E5
2:00220000000000
Command: 2120 response:6120EC0022D1
Command: 2121 response:
00E
0:612101008000
1:00000000000000
2:00000000000000
Command: 2122 response:6122020700
Command: 2123 response:61230100
Command: 2125 response:
008
0:612500000000
1:00200000000000
Command: 2126 response:
008
0:612606180440
1:80200000000000
Command: 2133 response:
009
0:613306040080
1:09138800000000
Command: 2137 response:
014
0:613763708000
1:80008000000000
2:2006CD04003E06
Command: 2139 response:61390000000001
Command: 213a response:
00B
0:613A00000000
1:00000000000000
Command: 213c response:
012
0:613C00000000
1:0000000000000F
2:A4020000000000
Command: 2140 response:6140DC00D801
Command: 2141 response:
014
0:61412C2B0909
1:2B000027242120
2:2B552B1E000D2E
Command: 2142 response:
00C
0:614279DB025E
1:2E660000440000
Command: 2144 response:
026
0:614423330000
1:80002333000080
2:00233300000000
3:23330000000080
4:00800000000000
5:00000000000000
Command: 2145 response:614500000000
Command: 2146 response:614611B400
Command: 2151 response:
01F
0:615100000000
1:00FFFF3F4B3E3F
2:3A3A000007F403
3:4E80007FEF8000
4:80000000000000
Command: 2152 response:
00A
0:615280808080
1:80280000000000
Command: 2154 response:
00C
0:615400000000
1:00000000000000
Command: 2155 response:
00A
0:6155808D8080
1:8E8D8B82000000
Command: 2160 response:616000000001
Scanning finished
[short version doesn't look like enough to worry about.]
Old 01-09-2013, 08:01 PM   #98
Yruyur
Yruyur's Avatar
01F
0:610100000000
1:5564463E643F00
2:000000000D2B55
3:2120004306CD09
4:632FC93E000000
00F
0:610476ED8000
1:46648000800000
2:80800000000000
008
0:610506154DDF
1:01900000000000
00F
0:61068107E500
1:0303000077E5E5
2:00220000000000
00E
0:612101008000
1:00000000000000
2:00000000000000
008
0:612500000000
1:00200000000000
008
0:612606180440
1:80200000000000
009
0:613306040080
1:09138800000000
014
0:613763708000
1:80008000000000
2:2006CD04003E06
00B
0:613A00000000
1:00000000000000
012
0:613C00000000
1:0000000000000F
2:A4020000000000
014
0:61412C2B0909
1:2B000027242120
2:2B552B1E000D2E
00C
0:614279DB025E
1:2E660000440000
026
0:614423330000
1:80002333000080
2:00233300000000
3:23330000000080
4:00800000000000
5:00000000000000
01F
0:615100000000
1:00FFFF3F4B3E3F
2:3A3A000007F403
3:4E80007FEF8000
4:80000000000000
00A
0:615280808080
1:80280000000000
00C
0:615400000000
1:00000000000000
00A
0:6155808D8080
1:8E8D8B82000000
Scanning finished
That does look pretty short. When you select start scan you have a check box for full scan.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
