| DIY (Do-It-Yourself) Guides For all DIYs. |
#85 | |
Drives: SWP BRZ
same.....
#86 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Installed these over the weekend and it feels good!
I did the rear sub-frame inserts a couple weeks ago, and this just tightens everything up even more so. I would say its a little more subtle than the sub-frame inserts, but can definitely feels the difference in how solid shifts feel now. Feels more engaged. Next up is rear shifter bushing, and then possible diff inserts! Whiteline changed all of their currently produced bushings to black poly a couple years ago, just means you have the "newer" iteration. |
#87 |
Drives: Celica, Frs
In what directions is the oem bushing supposed to face? I didn’t pay attention and can’t find the answer to this.
![]() Are the arrows supposed to face the diff or the engine?
Instagram @machine_type
#88 |
Drives: 2018 BRZ tS
Can you do the whiteline positive shift kit along with the Perrin transmission kit? Or is it one or the other?
Sent from my SM-G965U using Tapatalk
#89 |
Drives: Celica, Frs
From what I’ve read you can run both of them together.
| The Following User Says Thank You to Lococholo84 For This Useful Post: | SkyeHack (07-01-2018) |
#90 |
Drives: Celica, Frs
Figured out that it only fits in one directions in case anyone wanted to know or had the same issue I did..
#91 |
I fitted the STi gearbox support, but I get quite a lot of whining noise in the cabin. How does the Whiteline compares to mine?
#92 | |
Note: installing both will add a LOT of vibration and noise. |
#93 |
Drives: Raven FRS
I did the perrin/whiteline transmission mount support 2 weeks ago.
used a dremel on the whiteline to make the hole bigger. there's a lil whine and vibration, but i just got an axleback so i don't really noticed it anymore |
#94 |
Drives: 2013 FR-S Series 10
quite a bit of extra whine, sounds almost like a supercharger
| The Following User Says Thank You to Decep For This Useful Post: | MJones_RB (11-25-2018) |
#95 |
Drives: 17 Asphalt 86
Did whiteline insert over the weekend. Sticking a jack under the transmission and lifting it allows you to slide it in by just unbolting the 17mm bolt.
Super easy and takes about 20 minutes. Didn't see it mentioned here all though there's a good YouTube tutorial on it. |
| The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
#96 | |
Drives: 2017 toyota 86
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | RToyo86 (04-26-2021) |
| Tags |
| bushing, diy, positive shift kit, whiteline |
| Subaru Dealer Whitelist (positive experiences, truthful dealings) | Deslock | BRZ First-Gen (2012+) — General Topics | 285 | 05-15-2023 06:35 PM |
| Whiteline Positive Shift Bushing? | wootwoot | Engine, Exhaust, Transmission | 20 | 11-05-2012 08:45 PM |
| IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! | 10k Redline | Brakes, Suspension, Chassis | 6 | 10-16-2012 06:32 PM |
| which one is positive and negative | frs | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-04-2012 11:42 PM |
| Speaker wiring. Positive or negative?? | |-Goku-| | Electronics | Audio | NAV | Infotainment | 9 | 07-28-2012 11:24 PM |
