Old 11-18-2016, 03:06 PM   #85
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Silverfrs86 View Post
Whats up guys! I just ordered the perrin shifter bushing and the whiteline transmission bushing but i ordered it in black; is there a difference between the black and the yellow or is it just looks to add some color to the tranny mount?
Sent from my LGMS631 using Tapatalk
same.....
Old 01-16-2017, 09:29 AM   #86
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Installed these over the weekend and it feels good!
I did the rear sub-frame inserts a couple weeks ago, and this just tightens everything up even more so. I would say its a little more subtle than the sub-frame inserts, but can definitely feels the difference in how solid shifts feel now. Feels more engaged.
Next up is rear shifter bushing, and then possible diff inserts!
Whiteline changed all of their currently produced bushings to black poly a couple years ago, just means you have the "newer" iteration.
Cockatoo is offline   Reply With Quote
Old 06-25-2018, 01:13 AM   #87
Lococholo84
Drives: Celica, Frs
In what directions is the oem bushing supposed to face? I didn’t pay attention and can’t find the answer to this.
Are the arrows supposed to face the diff or the engine?
Instagram @machine_type
Lococholo84 is offline   Reply With Quote
Old 06-25-2018, 01:42 AM   #88
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
Can you do the whiteline positive shift kit along with the Perrin transmission kit? Or is it one or the other?
Sent from my SM-G965U using Tapatalk
SkyeHack is offline   Reply With Quote
Old 06-25-2018, 12:05 PM   #89
Lococholo84
Drives: Celica, Frs
From what I’ve read you can run both of them together.
The Following User Says Thank You to Lococholo84 For This Useful Post:
SkyeHack (07-01-2018)
Old 06-25-2018, 03:20 PM   #90
Lococholo84
Drives: Celica, Frs
Figured out that it only fits in one directions in case anyone wanted to know or had the same issue I did..
The Following 2 Users Say Thank You to Lococholo84 For This Useful Post:
jcw99 (05-07-2021), SkyeHack (07-06-2018)
Old 09-25-2018, 03:33 AM   #91
gpvecchi
gpvecchi's Avatar
I fitted the STi gearbox support, but I get quite a lot of whining noise in the cabin. How does the Whiteline compares to mine?
Old 10-31-2018, 07:54 PM   #92
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
You can install them both BUT you will have to cut the hole in the middle of the Whiteline bushing wider so that the Perrin piece will fit into it.
Note: installing both will add a LOT of vibration and noise.
MJones_RB is offline   Reply With Quote
Old 10-31-2018, 11:03 PM   #93
_kongzilla_
Drives: Raven FRS
I did the perrin/whiteline transmission mount support 2 weeks ago.
used a dremel on the whiteline to make the hole bigger.
there's a lil whine and vibration, but i just got an axleback so i don't really noticed it anymore
_kongzilla_ is offline   Reply With Quote
Old 10-31-2018, 11:44 PM   #94
Decep
Drives: 2013 FR-S Series 10
quite a bit of extra whine, sounds almost like a supercharger
The Following User Says Thank You to Decep For This Useful Post:
MJones_RB (11-25-2018)
Old 04-25-2021, 06:12 PM   #95
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did whiteline insert over the weekend. Sticking a jack under the transmission and lifting it allows you to slide it in by just unbolting the 17mm bolt.
Super easy and takes about 20 minutes. Didn't see it mentioned here all though there's a good YouTube tutorial on it.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
86TOYO2k17 (04-26-2021), MJones_RB (05-04-2021), Ohio Enthusiast (04-25-2021)
Old 04-26-2021, 01:05 PM   #96
86TOYO2k17
Drives: 2017 toyota 86
I did it the same way. Don’t see the point of fully removing the mount.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
RToyo86 (04-26-2021)
bushing, diy, positive shift kit, whiteline
Subaru Dealer Whitelist (positive experiences, truthful dealings) Deslock BRZ First-Gen (2012+) — General Topics 285 05-15-2023 05:35 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 07:45 PM
IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! 10k Redline Brakes, Suspension, Chassis 6 10-16-2012 05:32 PM
which one is positive and negative frs Scion FR-S / Toyota 86 GT86 General Forum 1 08-04-2012 10:42 PM
Speaker wiring. Positive or negative?? |-Goku-| Electronics | Audio | NAV | Infotainment 9 07-28-2012 10:24 PM
