Old 02-04-2016, 01:11 PM   #85
jam0o0
Drives: 2013 FR-S, hot lava
forgot about this update:
got pissed off at the windows not working. happened to press the window child lock button very hard and something popped and everything works now. it must have gotten stuck somehow, cause that button did nothing when everything was screwed up.
jam0o0 is offline   Reply With Quote
Old 08-08-2016, 07:56 AM   #86
lizbrayan
Drives: '15 Scion Frs Steel
So I had my doors replaced recently, (long story) and the panels were switched from one set to another. After I got the car back from the body shop I noticed my windows didnt auto up nor could I lower the passenger side down from the drivers side. Tried the button thing and nothing. Took it to the body shop and they couldnt figure it out either. Really don't want to go to the dealership and deal with them. Any help? How hard is it to take these panels so I can check the wire connections?
lizbrayan is offline   Reply With Quote
Old 08-08-2016, 09:45 AM   #87
Did you check the fuses? Doubt there is a separate fuse for each door but you never know.
Old 08-08-2016, 09:50 AM   #88
lizbrayan
I could see why the fuse would be a problem but if the fuse was bad wouldnt the windows not go down or up at all?
Sent from my SGH-T999N using Tapatalk
Old 08-08-2016, 09:52 AM   #89
No it shouldn't. I miss read you statement that it wouldn't work from the drivers side as not working at all. Fuses not likely the issue.
Old 08-08-2016, 09:54 AM   #90
lizbrayan
No problem, im thinking it has to be a connection in the master switch, but i just find it so odd that i still have constant power to both windows
Old 08-08-2016, 09:57 AM   #91
Disconnect the battery for 5 minutes and let the BCU reset. It just may not recognize the new doors yet.
Old 08-08-2016, 09:59 AM   #92
lizbrayan
Ive had the battery disconnected before and still nothing, think i should take the panels off and disconnect the harness and reconnect it?
Old 08-08-2016, 10:32 AM   #93
Doubt it will do anything but worth a shot. There may be something not quite connected someplace.
Old 08-08-2016, 12:00 PM   #94
FX86
did you try turning the knob faster?
Old 08-08-2016, 12:21 PM   #95
lizbrayan
Is that what comes with the high trim Fr-z?
Old 08-08-2016, 12:25 PM   #96
FX86
nope...the ft-86
Old 08-08-2016, 01:11 PM   #97
humfrz
Well, lizbrayan, I reckon you will have to take the doors apart and find out what is not connected.
Have you tried that "hold the button down/reset" move ... ??
humfrz
Old 08-08-2016, 01:21 PM   #98
lizbrayan
humfrz
I also reckon im going to have to take the door off and yeah tried for 30mins the other day
Passenger's Auto Window Scroll Bonburner Issues | Warranty | Recalls / TSB 204 04-17-2018 07:34 PM
Window auto close module..? luv85 Scion FR-S / Toyota 86 GT86 General Forum 1 11-18-2012 01:05 PM
Passenger window mystery FRiSson Scion FR-S / Toyota 86 GT86 General Forum 6 09-07-2012 02:30 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 12:32 AM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
