View Poll Results: If you had the option of V6 or Flat 4 on the FRS/BZR what would be your choice?
V6? 37 21.64%
Flat 4 Boxer? 134 78.36%
Voters: 171. You may not vote on this poll
Old 09-23-2012, 04:53 PM   #85
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
The torque curve isnt the cause of snap oversteer, dont know why you keep mixing power with handling.
The power thing is an ongoing debate i suppose; its just that the platform has so much potential.
At least you recognize turbo curves can rival NA, or thats what i took the no comment as.
chulooz is offline   Reply With Quote
Old 09-23-2012, 05:31 PM   #86
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Thunderchicken View Post
BMW designed the motor with help from there F1 designers so lots of money was involved.
I personally think 151 torque is great from a 2.0 no other 2.0 that is N/A has more, Honda had 143 from the KA20A2.
I don't know why I waste my breath with people who don't drive, never driven and probably with never own this car and just don't understand that a car doesn't need to have gobs and gobs of power to be fun to drive, so just go back to playing your GT5 or Forsa.
I own a 2.0L car with 140tq+ and mods and weigh 2700 lbs so I guess I don't have a fucking clue? Why so bent out of shape for? Just because one thing feels great for you it must feel great for someone else? You might think another car doesn't have enough torque and I might like it. Its just preference and I am not hating on the FRS or BRZ.
Also the S2000 2.0L had a smidge more torque fyi.
SUB-FT86 is offline   Reply With Quote
Old 09-23-2012, 05:47 PM   #87
Thunderchicken
Drives: 2008 STi
Turbo curves of what you call flat are from small turbos and aren't that flat, in fact as the turbo reaches its peak the torque begins to drop off.
Snap oversteer is induced from how well the chassis handles sudden inputs from the brakes and throttle. If the chassis is setup neutral and you give the car a big braking input followed by a big throttle input the car will oversteer, but if the sudden on set of torque is too much the car can go in to snap oversteer. However in order to prevent this from happening they dial in more understeer.
Yes this chassis has tons of potential but was setup in such a way that it rewards the driver when things are done right. It teaches the new/older driver how to feel what the car is doing and understand what it is doing and how to re-act before you get in to trouble.
Thunderchicken is offline   Reply With Quote
Old 09-23-2012, 05:55 PM   #88
fatoni
that can be a cause of snap oversteer but it isnt snap oversteer. it is the result of a nonlinear suspension response to linear suspension loads. rapid undesired changes in one or more of any particular suspension radically changes the amount of grip at each corner of the car. it can also be cause by steering inputs or road conditions. its not the brakes or engines fault otherwise every car would have what we call snap oversteer
Old 09-23-2012, 06:02 PM   #89
Thunderchicken
Drives: 2008 STi
I'm not bent out of shape. But the S2000 only had 2 more ft/tq more than the FA20 in the AP1 form, but since people begging for more torque, Honda increased the displacement at a loss of horsepower to appease the masses for the need of more torque.
Old 09-23-2012, 06:18 PM   #90
SUB-FT86
86 Member
I thought it was still rated at 240hp with the 2.2? Where did you see lost of power? On a dyno with the two cars on the same day?
Old 09-23-2012, 06:27 PM   #91
Thunderchicken
Drives: 2008 STi
The AP1 was rated at 240/153 while the AP2 was 237/162
Old 09-23-2012, 06:29 PM   #92
Opposed
Drives: 2013 Asphalt FR-S
It was. In fact, the F22's actually made about 5-15whp more than the F20's.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-23-2012, 06:42 PM   #93
fatoni
yeah lets go ask the s2k community how much better the ap2 is over the ap1
Old 09-23-2012, 06:56 PM   #94
SUB-FT86
86 Member
I believe the AP1 was under the old hp system and the AP2 was under the new one. I forgot what they called it? STD to SAE?
Old 09-23-2012, 07:18 PM   #95
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Going off topic? Oh~ add me to the off topic talk lol
Old 03-29-2014, 11:30 PM   #96
Sleeperz
Drives: 1982 Toyota Corolla Coupe SR5
If you need quick acceleration you have to use the transmission, lower gears and higher RPMs.
Road & Track, July 2012 issue, pg. 89.
At 7400 rpm the speeds in each gear are respectively:
1: 35 mph (too much commotion in town)
2: 58 mph
3: 83 mph (you could be in trouble)
4: 105 (you're probably going to jail)
5: 127 (do you have a lawyer?)
6: 135 (estimated at 6000 rpm, so I assume it's drag limited)
RPM at 60 mph in top gear: 2700
Originally Posted by GT-ROKIN View Post
I know many of you have experience the power of a V6.
Today on my way to classes on the highway (Meadowbrook Parkway) i was in the extreme left lane doing about 65mph in my 2000 Nissan Maxima and realized that i was coming up on my exit fast with a few cars in the other 2 lanes parallel to me. Panicked.... i punched the accelerator, the V6 respond with tremendous power, enabling me to cut over both lanes and make my exit.
Then i question my self- will my new car be this fun? its not a V6? what will it be capable of?
only way to find is to ask!
Do you miss the Power of a V6?
Is the Boxer Engine Comparable with a V6?
How Responsive is the engine when trying to pass or cut in and out of traffic?
Whats your take on the Boxer Engine? (Positive or Negative)
Sleeperz is offline   Reply With Quote
Old 03-30-2014, 01:47 AM   #97
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
2: 58 mph
RPM at 60 mph in top gear: 2000 in the A/T version. If you want fuel economy the A/T is the way.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 03-30-2014, 02:07 AM   #98
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Nice resurrection.
Sounded like I had a flat, but I didn't Brett Scion FR-S / Toyota 86 GT86 General Forum 33 01-11-2016 12:13 PM
Flat black BRZ BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 06-27-2012 04:23 PM
Flat Black BRZ Toods BRZ First-Gen (2012+) — General Topics 4 06-20-2012 01:25 AM
Porche boxer vs Subaru boxer Shevon Engine, Exhaust, Transmission 22 08-10-2011 01:43 PM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 08:46 PM
