Old 01-03-2013, 06:24 AM   #85
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I'm thinking the V8 in the M3 (S65). 440 hp at 8300 rpm. Yes please.
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
Wes B. (01-03-2013)
Old 01-06-2013, 03:04 PM   #86
Wes B.
Automotive Enthusiast
Wes B.'s Avatar
That would most certainly do the trick!
Wes B. is offline   Reply With Quote
Old 01-06-2013, 05:07 PM   #87
cruzinbill
Drives: Argento 6spd FR-S
1LR-GUE with the baby LFA body kit. Would be pretty sweet.
cruzinbill is offline   Reply With Quote
Old 01-06-2013, 09:26 PM   #88
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Originally Posted by Wes B. View Post
Jaguar AJ126 -- 3.0l Supercharged V6 that puts out 375hp @6,500 rpm and 340 lb-ft of torque @ 3,500-5,000 rpm. I believe this engine is near perfect for the FR-S/BRZ because of its small displacement, its high relative power output, and the song it sings when the throttle is wide open.
Whats the weight difference between the 5.0L S/C V8 model and the 3.0L S/C V6? Can't find much on it...
Can't wait to see the F-type on the road, such an interesting car with two very good engine choices...not so sure about the 8 speed automatic though.
Old 01-07-2013, 08:37 AM   #89
Wes B.
Wes B.'s Avatar
I wasn't able to find any engine weight numbers, but the weight difference between the V6 F-Type and the V8 F-Type is 150 lbs (3,520 vs. 3,670). Both engine choices are fantastic, and the car should come with a manual trans option.
Old 01-07-2013, 08:42 AM   #90
Wes B.
Wes B.'s Avatar
Mazda's 4.0l W12 -- This engine was shown at the 1989 Tokyo motor and was intended for Mazda's Amati luxury brand that never materialized. The engine was limited to 280hp and 274lb-ft of torque because of the Japan's gentleman's agreement, but keeping in tradition of Mazda's unique engine design history (rotary, Miller cycle, etc) they decided to go with the W-configuration for their 12 cylinder. While the block is aluminum, the rest of the engine is mostly magnesium. Arguably the most interesting design feature were the ceramic cylinders and aluminum-ceramic valves. Very ground breaking for the time.
Old 01-31-2013, 07:08 PM   #91
Shadowsong6
Shadowsong6's Avatar
Drives: 2014 Ford Mustang
The Katech KV4-RR. I want it so bad. No, it's not the Motus V4
http://www.katechengines.com/engineering/katech-v4/
Shadowsong6 is offline   Reply With Quote
The Following User Says Thank You to Shadowsong6 For This Useful Post:
Wes B. (02-04-2013)
Old 02-27-2013, 01:54 PM   #92
Sebaflex
Drives: 3
i really think K24/K20 or an F20/F22C would really go with the character of this car..
Sebaflex is offline   Reply With Quote
The Following 2 Users Say Thank You to Sebaflex For This Useful Post:
rice_classic (08-20-2013), Wes B. (02-27-2013)
Old 02-27-2013, 02:23 PM   #93
Wes B.
Wes B.'s Avatar
Lotus 910 from a 1993 Lotus Esprit Sport 300 (2.2l I4 turbo'd) -- 300 hp @ 6,400 rpm and 287 ft-lbs of torque @ 4,400 rpm.
Old 02-27-2013, 02:40 PM   #94
Wes B.
Wes B.'s Avatar
True, but how easy are they to adapt to a RWD configuration?
Old 03-04-2013, 11:13 AM   #95
Sebaflex
Drives: 3
Well F20/22c are from S2000 so its already rwd. K20/24 swaps have been done in S2000 also so it is possible.
Old 03-08-2013, 11:08 PM   #96
mobybrz
Drives: White 2013 BRZ
Yeah, because that would be street friendly...
I do like the idea of using an F1 motor though. Personally, I would detune the motor to around 500-600hp and have it redline at 8,000-9,000rpm.
Zytek 3.4L A1GP motor
520-550HP ... NA
~9k redline
120 KG
Lasts a whole season of single seater racing
You can get the old KVs for <$30k
and it sounds like this:
[ame="https://www.youtube.com/watch?v=ZrMToRajxjU"]PURE SOUND of V8 3,4l Engine with 550HP - Auto GP Worldseries at Monza - perfect sound! - YouTube[/ame]
or this:
[ame="http://www.youtube.com/watch?v=4TrP_6L8w1U"]Zytek KV on the Dyno - YouTube[/ame]
mobybrz is offline   Reply With Quote
Old 03-09-2013, 12:05 AM   #97
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I love the 4g63 as well. Great engine.
But I was thinking something more along the lines of this V12....
Or maybe the engine outta one of these!
Chewie4299 is offline   Reply With Quote
Old 03-09-2013, 12:11 AM   #98
Chewie4299
Spaceman
Chewie4299's Avatar
I take it back.... ultimate power and ultimate efficiency with this bad boy!
Designed to provide the motive force for a variety of supertankers and container ships, it comes in 6 cylinder in-line through to a whopping 14 cylinder version. The cylinder bore is 38 inches and the stroke is just over 98 inches. Each cylinder displaces 111,143 cubic inches (1820 litres) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 litres) for the 14-cylinder version.
At a length of 89 feet and a height of 44 feet, the total engine weight is 2300 tons - the crankshaft alone weighs 300 tons.
The RTA96C-14 can achieve a maximum power output of 108,920 hp at 102 rpm and astonishingly, at maximum economy the engine exceeds 50% thermal efficiency. That means, more than 50% of the energy in the fuel is converted to motion. Its Brake Specific Fuel Consumption (BSFC) at maximum power is 0.278 lbs/hp/hr
5.0l v8, engine swap, lexus is-f, mustang gt
Engine Swap: Which Would You Choose!?? EvoFanatic Engine Swaps 149 08-08-2017 03:34 AM
Another engine swap topic! PRORICAN Engine Swaps 13 08-07-2012 10:43 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
4U-GSE: the new engine swap for old Toyotas no_name Engine Swaps 17 12-19-2011 09:50 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
