Old 04-09-2023, 10:33 AM   #85
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
We need more open hood videos. It honestly sounds like it could be something belt tensioner related. Just an uneducated guess.
I mean I can rev it like crazy, from 1k to 4k or above. Zero popping/knocking or strange noises. Even let it fall from 4k to 3k and rev back to 4k over and over and over. Nothing.
Plus the fact that @fredzy's 23 does it is an interesting data point. Hopefully he can make a video for us when he has time.
For those that shared logs, were you guys actually logging what the car was doing when blipping the throttle from idle, and has tomm looked at the behavior in that instant? Probably a lot different than the typical inspection of the params during a pull through the rev range.
I watched the clip of the DI seal pop, it is similar in a way. I don't think the same thing though. What mine does is very much the same as NFS's from this post, if a bit less prominent. Very instant with the throttle blip. I will make a video today
https://www.ft86club.com/forums/show...2&postcount=37
I'm bone stock so can't log or really do anything about it aside from asking for more current SW (something I did A LOT with my WRX - get latest OEM SW in hopes of making the car drive better lol.) I will watch the thread to see where it goes.
fredzy is offline   Reply With Quote
The Following User Says Thank You to fredzy For This Useful Post:
Clipdat (04-10-2023)
Old 04-09-2023, 10:43 AM   #86
tomm.brz
Drives: brz 2017 hksv2
i did, there is nothing out of ordinary in those stationary blips from idle
there are though no misfire logged in those
I linked to Clipdat a stg1 91oct with a little modified transient table, i m curious if he feels something different with that when he gets a chance to try it
The Following User Says Thank You to tomm.brz For This Useful Post:
Old 04-09-2023, 10:54 AM   #87
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
Will that tune work with any ecu? I saw that the OFT websites have multiple different tunes for different years.
Nfsundrgrnd is offline   Reply With Quote
Old 04-09-2023, 11:00 AM   #88
tomm.brz
Nope with oft you have to match the calid or hack it, which calibration do you have that i make you one?
Old 04-09-2023, 11:56 AM   #89
Nfsundrgrnd
Got a log with the stock tune reflashed and with misfires being recorded. Although I didn't see any misfires, even with the first throttle blip giving me the same knocking noise.
https://www.dropbox.com/s/l9wnp2g4b0...drive.csv?dl=0
Old 04-09-2023, 11:57 AM   #90
Nfsundrgrnd
The CAL is ZA1JA00C
Was using the Stg-1-v4.03-LC-FSS-Z Tune provided by oft. Had to retrieve it online since it didn't autogenerate when plugging in the oft.
Old 04-09-2023, 12:00 PM   #91
Nfsundrgrnd
The first log I uploaded was of the Idle knocking noise. Logged with the video that's there.
Old 04-09-2023, 12:50 PM   #92
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Nfsundrgrnd View Post
The CAL is ZA1JA00C
Curious to see if Tomm's map helps, likely transposed transient ignition retard map from a newer ROM
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 04-09-2023, 12:55 PM   #93
tomm.brz
not really 100% , it s just some removed retard at 800-1000rpm, and well some added retard at higher rpm like newer rom as it is safer
i m curious to see if they feel less bogging when stabbing at idle, as we can then blame the stock settings for it
Old 04-09-2023, 01:06 PM   #94
tomm.brz
here v2 stg1 91 oct with some transient mod
Stg1 A00C V2 91oct
it surely also more suited than stock tune if you only have access to 91oct
Do a proper flash: after flashing keep dash on/engine off and press accel pedal for 3-4 times slowly to 100% and release it slowly
then turn engine on and let idle for 2 minutes with no throttle
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Clipdat (04-10-2023), Nfsundrgrnd (04-09-2023)
Old 04-09-2023, 01:14 PM   #95
Nfsundrgrnd
Stg1 A00C V2 91oct
Awesome thanks! I'll get another log done once I have the tune updated.
Old 04-09-2023, 01:18 PM   #96
tomm.brz
while warming the engine driving around, try to go to 5000rpm with low throttle, if you keep it in closed loop while going up in rpm, it learns LTFT faster
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
Clipdat (04-10-2023), Nfsundrgrnd (04-09-2023), Ultramaroon (04-09-2023)
Old 04-09-2023, 01:38 PM   #97
fredzy
Mebmer
fredzy's Avatar
Not sure where this was mentioned, but that has been an annoyance of mine since I got the car. Very difficult to blip just the right amount of throttle when heel-toeing. Almost always not enough, and then when I give it that little bit more its way too much. Bogging is a perfect word to describe it.
I thought it was just how the throttle is mapped, different from WRX and Corolla and I'll just have to get used to it. They were/are very easy to get the right amount of blip which is funny considering they're turbo (a turbo FA even!) and this is NA. And everyone says the GR86's throttle is too touchy.
I'll have a video in a little and then I actually think I'm gonna reset the ECU after a fresh tank of 93..
Old 04-09-2023, 01:55 PM   #98
tomm.brz
it s a mix of how throttle is mapped and some timers that trigger between closed loop and open loop, and some ignition retard
Blipping with clutch pressed for example you can notice it bogs even more
Best solution is to get a custom tune, many tuners get it right with the tune and mod the thottle and becomes more reactive and sensitive.. the downside is it feels like reduced travel from min to max, but not necessarily all the time
But realisticaly eventually most people like a reduced excursion of the pedal specially when it's Naturally aspirated
fredzy (04-09-2023)
Rough idle leads to stall, runs well under load, no engine response on throttle blip gensch Issues | Warranty | Recalls / TSB 8 09-01-2021 09:26 AM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 09:42 AM
Throttle Blip Hiss Wepeel Issues | Warranty | Recalls / TSB 29 05-31-2014 12:56 AM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 05:37 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 11:52 AM
