#85 |
Drives: Toyota GT 86
One other silly question:
The "lever lock" on the connector: does unlatching it mean lifting from the bottom and swinging upwards? I ask because, if that is correct, mine is decidedly reluctant to move, and I'm reluctant to more force into it without being absolutely sure. Ideally, if someone is willing/able to post a photo of the lever in the open position, that would be very much appreciated! |
#86 | |
It says “press” on it right below the Bosch logo. Edit: also you may need to remove a white zip tie holding the assembly together
#88 |
I got my VSC ECU swapped on my 2015 UK car this afternoon, and the difference is pretty awesome.
But just to add some confusion, my car is an early 2015 (manufacture date February 2015, IIRC) which I figured *should* make it a 2014/2015 model year, and I'd need to do the repin. But on closer inspection, I did not. Thanks to all those who put in the legwork on this mod, it's definitely worth doing, in my opinion!! |
| The Following User Says Thank You to cliddell For This Useful Post: | MJones_RB (10-12-2020) |
#89 |
Drives: ft86
I didnt see, how do you activate track mode with 2013 buttons/dash?
#90 |
Drives: 2014 GT86
You activate track mode just like VSC sport, just pressing slightly longer (1s?). And it won't display track but vsc sport on dash obviously.
You can also activate now hill assist, but it won't have it's indicator on older dash. |
#91 |
Track mode wasn't enough to save my ass on wet pavement with cold tires
#92 |
Drives: 13 BRZ, 17 Focus RS
Thanks for this, wish I had seen it months ago when it was first posted! This excites me, as I love to tinker and have never been happy with the stock VSC on my ‘13. I’ve never been able to tell a difference between normal and sport, but they both have always responded way too early and abruptly for me. However, I’ve had the once a year upset on the street usually due to water or debris where it has probably helped me. Due to this, I don’t want to be full off on the street, especially on spirited drives with cliffs past the edge of the road. The only other car I’ve owned with VSC is a Fiesta ST, and even during AX if it’s reacting, it’s doing it so smoothly I can’t tell.
For track and a couple of drift days I’ve done, 3 second off has worked perfectly fine for me. The only thing I don’t like is the lights still flashing on the dash when it thinks it should be helping me. I’m curious if this will still be the case with the newer module? I’ve used the pedal dance a few sessions, but the only thing I noticed was unstable braking. I’m sure different skill level, brake setup, alignment setup could change that. It looks like there’s plenty of these modules on eBay, but quite a range in price. Looks like currently the cheapest is around $250. I think I may have found one elsewhere for around $125. What have you guys been paying for them? |
#93 | |
Drives: 2015 Firestorm 08/05/15
#94 |
Ballpark what this unit will cost plsr thx in advance
#95 | |
But salvages usually sell them together. |
#97 |
hella stock
Drives: BRZ Limited
Welp. So I tugged too hard (
) and managed to pull the wire off with the connector still in the harness. Lesson learned..https://imgur.com/W7V7kvB Anyone know what crimp kit I should get to get a pin back onto this thing so I can insert it back onto the harness?
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR |
#98 |
| Review of "Track Mode" on the MY17+ cars | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 85 | 02-22-2021 10:27 PM |
| FS: Nameless muffled track pipe 2013-2016 | Dave-ROR | Engine, Exhaust, Bolt-Ons | 4 | 05-21-2020 12:27 AM |
| Track mode vs. VSC sport | alex87f | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-30-2018 11:47 PM |
| 2017 Track mode on older model | Bobster | Engine, Exhaust, Transmission | 17 | 12-03-2017 11:34 PM |
