Old 11-02-2015, 11:25 AM   #85
ort895
ort895's Avatar
Originally Posted by TOOSTUBBORN2FAIL View Post
Well, I guess this is the best place to first post this, since its a site reference thread for deadening.
I'm new here. I don't have my 86 yet, but have lurked through a lot of information and figured I should pay it forward on the subject of my expertise.
If you have ever been to DIYMA, you might be aware that I have been objectively testing vibration damping materials for a while now. I'm hoping to finish up by the new year and post full results, but this will serve as a teaser of sorts.
This is going to ruffle some feathers, but subjective opinions of the performance of damping materials are pretty much useless. No offense meant towards anyone, but it is a fact. In order to post a useful subjective review, one would need to have SEVERAL materials on hand, and use them in a controlled environment to determine effectiveness. Even then, ears can easily be tricked. A product that works well at high frequencies may be horrible at low frequencies that effect bass response, but your ears wouldn't know it.
My test set up uses REW, and a calibrated measurement microphone to get data. The test panel is 16 gauge steel, a 12"x12" sheet clamped on all sides with an 11"x11" exposed area. The panel is excited by a pair of 7" speakers, which are sealed off on both front and back from the room. I will dig through photobucket a little later or tomorrow to find the set up pictures.
For now, here are the results of a few products that seem to be popular here.
This is GTMat's 80mil product. It is asphalt based, and does have a smell. It is a modified asphalt, but still not one I would trust to withstand heat on the roof, which is one of the most important parts of the car to use vibration damping on.
It performs below what I would consider acceptable.
This is Stinger Roadkill Expert. A very heavy product, but butyl based, with minimal smell, and acceptable heat tolerance.
It is at the bottom end of what I would consider acceptable. I would not personally use this as there are better performing AND lighter products.
Next up is Dynamat Xtreme. This is before the product changed to black foil, I am unaware at this time if the change affected performance. The silver product is the LIGHTEST product that gives decent results. This is THE product you want to use for a lightweight sports car, if weight is important to you. Nothing lighter than this product performs well enough to spend money on, period.
This is KnuKonceptz Kolossus. It is the current budget leader for all out performance. It is within a hair of the absolute top performer that has a heat resistance great enough to use in a car. It is heavy. That said, 25% coverage of this product performs better than 100% coverage of peel n seal, at the same total weight.
More to come
any updates?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 11-02-2015, 02:43 PM   #86
stevesnj
stevesnj's Avatar
Peel and Seal from Lowes. I used this on my truck and made a significant noise reduction. Apply with heat gun in colder weather.
http://www.lowes.com/pd_154017-81326...ductId=1018733
My 2016 Build thread
Old 11-02-2015, 04:34 PM   #87
ort895
ort895's Avatar
I plan on going with Dynamat Xtreme. I don't plan on hardcore deadening but i did want to do the doors, under the rear seats (apparently that's where a lot of road noise comes from) and the trunk area, ill see how this goes.
Old 11-02-2015, 06:11 PM   #88
kch
Senior Misanthrope
kch's Avatar
FYI, Dynamat won't do anything for higher-frequency noise like road/wind noise. You'll need mass-loaded vinyl and maybe closed-cell foam for that.
Old 11-02-2015, 06:45 PM   #89
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Where to get those?...... (cheap if possible..)
I put some fatmat in my car for exhaust drone..........but it doesn't really stop anything. Can use some hint/help/tip. Thanks~
Old 11-02-2015, 10:57 PM   #90
ort895
ort895's Avatar
ahhhhh i see, apparently i need to do some more reading, thanks.
Old 11-02-2015, 10:58 PM   #91
ort895
ort895's Avatar
still shopping around looking for the best pries, ill keep you updated though
Old 11-03-2015, 01:04 AM   #92
kch
Senior Misanthrope
kch's Avatar
not sure. sorry.
Here's a great place to start. http://www.ft86club.com/forums/showthread.php?t=53511
Old 11-03-2015, 06:22 AM   #93
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
I'll post results from peel n seal later. You'll see that any benefits from peel n seal are from the placebo effect, ie you know you put it in so it "has to be working". The ears are a poor reference for this kind of thing.
TOOSTUBBORN2FAIL is offline   Reply With Quote
Old 11-03-2015, 12:26 PM   #94
ort895
ort895's Avatar
not sure. sorry.
thank you sir!
Old 11-03-2015, 02:39 PM   #95
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
can always change interior carpet. On my ae86 (had no carpet because metal cancer spread to it), I added house carpet (thin one not fluffy) and it helped noise by A LOT!!!~
But gotta watch out when it rains, itll stink it up.
Packofcrows is offline   Reply With Quote
Old 11-03-2015, 05:30 PM   #96
Breeeep
Drives: 2013 Grey BRZ / 1995 Trooper
I've used this to dampen vibrations on the sheet metal inside the door panels. This is a real measurable effect due to adding mass... changing the resonate frequency ( lowering ).
Breeeep is offline   Reply With Quote
Old 11-03-2015, 05:33 PM   #97
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I just use dead hookers in the trunk
Old 11-03-2015, 11:37 PM   #98
TOOSTUBBORN2FAIL
I've been laid up the last two days, but I'll get the measurements up tomorrow.
Yes, it lowers the resonant frequency, no it does not effectively damp vibration. It also fails after repeated heating and cooling cycles in hot climates.
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
Southeast sound OFF! OldSkoolToys Southeast 133 05-25-2012 12:31 AM
86 Sound System Skorov AUSTRALIA 25 05-09-2012 04:51 PM
BRZ exhaust sound! ilikecars86 BRZ First-Gen (2012+) — General Topics 16 04-13-2012 03:26 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
