#85 |
Yeah its an auto, deal with it.
#86 |
Peel and Seal from Lowes. I used this on my truck and made a significant noise reduction. Apply with heat gun in colder weather.
http://www.lowes.com/pd_154017-81326...ductId=1018733
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#87 |
I plan on going with Dynamat Xtreme. I don't plan on hardcore deadening but i did want to do the doors, under the rear seats (apparently that's where a lot of road noise comes from) and the trunk area, ill see how this goes.
#88 |
Senior Misanthrope
FYI, Dynamat won't do anything for higher-frequency noise like road/wind noise. You'll need mass-loaded vinyl and maybe closed-cell foam for that.
#89 | |
The Fail Boat
Drives: CWP S.B.
I put some fatmat in my car for exhaust drone..........but it doesn't really stop anything. Can use some hint/help/tip. Thanks~
#90 |
ahhhhh i see, apparently i need to do some more reading, thanks.
#91 | |
#92 | |
Senior Misanthrope
![]() Here's a great place to start. http://www.ft86club.com/forums/showthread.php?t=53511 |
#93 | |
Drives: Specialized Hardrock
#94 | |
#95 |
hey you, yeah you <3
Drives: 2014 37J FR-S
can always change interior carpet. On my ae86 (had no carpet because metal cancer spread to it), I added house carpet (thin one not fluffy) and it helped noise by A LOT!!!~
But gotta watch out when it rains, itll stink it up.
#96 |
Drives: 2013 Grey BRZ / 1995 Trooper
I've used this to dampen vibrations on the sheet metal inside the door panels. This is a real measurable effect due to adding mass... changing the resonate frequency ( lowering ).
#97 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I just use dead hookers in the trunk
#98 | |
Yes, it lowers the resonant frequency, no it does not effectively damp vibration. It also fails after repeated heating and cooling cycles in hot climates. |
| Sound tube mod? | smbrm | Engine, Exhaust, Transmission | 25 | 06-20-2012 07:24 PM |
| Southeast sound OFF! | OldSkoolToys | Southeast | 133 | 05-25-2012 12:31 AM |
| 86 Sound System | Skorov | AUSTRALIA | 25 | 05-09-2012 04:51 PM |
| BRZ exhaust sound! | ilikecars86 | BRZ First-Gen (2012+) — General Topics | 16 | 04-13-2012 03:26 PM |
| What should the FR-S sound like? | 1660 | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 07-31-2011 01:33 AM |
