Old 09-18-2019, 10:32 AM   #85
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by GrantedTaken View Post
Not really. The pad lays flat.
Another rookie response. lol
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 6 Users Say Thank You to venturaII For This Useful Post:
JohnJuan (09-23-2019), soundman98 (09-18-2019), Tcoat (09-18-2019), Tristor (09-18-2019), weederr33 (09-18-2019), wparsons (09-18-2019)
Old 09-18-2019, 11:48 AM   #86
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just when you think it is done this thread delivers again
Tracking my stock front brakes wore one edge more then the other. Can't remember which for sure, pretty sure it was the leading.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-18-2019), venturaII (09-18-2019), wparsons (09-18-2019)
Old 09-18-2019, 12:25 PM   #87
venturaII
venturaII's Avatar
Leading edge always wears faster due to the torque applied from the rotor, hence most multi-piston aftermarket calipers having smaller pistons at the leading edge.
Pad taper is also common in sliding pin designs due to flex in the rubber bushings in the caliper itself.
The Following 3 Users Say Thank You to venturaII For This Useful Post:
soundman98 (09-18-2019), Tristor (09-18-2019), wparsons (09-18-2019)
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 03:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
Vinyl on driver's seat split open; dealer will replace babydriver Cosmetic Modification (Interior/Exterior/Lighting) 2 12-20-2014 08:55 PM
Why do my Stoptech brakes squeel so loudly? Fix or replace? eikond Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-20-2014 02:17 PM
Help me replace my rear brakes? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-28-2014 03:55 PM
