CANADA Canada
Old 07-18-2019, 03:09 PM   #85
wparsons
wparsons's Avatar
Originally Posted by Jordanwolf View Post
Scary. I just worry about warranty as I'm good under the powertrain warranty for a while, but I also worry about that one day where I decide to produce too much heat.. I've already done it to my brakes lol..
Either way I'll end up getting one, just not sure when. Researching continues.
My dealership didn't care from a warranty perspective, but if it sprung a leak and I spun a bearing because it ran out of oil it definitely wouldn't have been covered under warranty.
The problem with waiting for signs of too much heat is that the symptom is usually a big engine failure because of lack of oil pressure. There's no way to monitor oil pressure stock (unless it drops below like 5psi).
Tracking it without knowing what the temperatures and/or pressures are is playing with fire. If you're going to track it and not going to log temperature and/or pressure, then I'd suggest running 5w30 instead of 0w20 and run high quality oil that can take serious heat. 0w20 gets too thin when the temperatures go up and the pressure falls off.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Jordanwolf (07-18-2019)
Old 07-18-2019, 04:40 PM   #86
Jordanwolf
Rice King
Jordanwolf's Avatar
So basically get an oil temp/pressure gauge in the future. As well as don't play with fire, fire bad.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
wparsons (07-18-2019)
Old 07-18-2019, 04:49 PM   #87
wparsons
wparsons's Avatar
Oil temp you can log with an OBD dongle, ecutek or OFT (AIM solo DL could do it too). Oil pressure requires adding a sensor/sender before you can view it on a gauge.
flickr
2018 Ontario Time Attack Frost CANADA 23 09-28-2018 04:53 PM
Ontario Time Attack Frost CANADA 12 08-21-2017 05:08 PM
Ontario Time Attack (OTA) Schedule and info wparsons CANADA 18 07-08-2015 07:20 AM
[Ontario] - 2013 Time Attack Schedule Flyer CANADA 1 05-12-2013 08:11 AM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
