| CANADA Canada |
#85 | |
The problem with waiting for signs of too much heat is that the symptom is usually a big engine failure because of lack of oil pressure. There's no way to monitor oil pressure stock (unless it drops below like 5psi). Tracking it without knowing what the temperatures and/or pressures are is playing with fire. If you're going to track it and not going to log temperature and/or pressure, then I'd suggest running 5w30 instead of 0w20 and run high quality oil that can take serious heat. 0w20 gets too thin when the temperatures go up and the pressure falls off.
#86 | |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#87 | |
Oil temp you can log with an OBD dongle, ecutek or OFT (AIM solo DL could do it too). Oil pressure requires adding a sensor/sender before you can view it on a gauge.
| 2018 Ontario Time Attack | Frost | CANADA | 23 | 09-28-2018 04:53 PM |
| Ontario Time Attack | Frost | CANADA | 12 | 08-21-2017 05:08 PM |
| Ontario Time Attack (OTA) Schedule and info | wparsons | CANADA | 18 | 07-08-2015 07:20 AM |
| [Ontario] - 2013 Time Attack Schedule | Flyer | CANADA | 1 | 05-12-2013 08:11 AM |
| Ontario Time Attack - TMP July 7th | 7thgear | CANADA | 8 | 07-07-2012 06:14 PM |
