Old 03-08-2021, 09:16 AM   #85
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Originally Posted by macuser27 View Post
I have the dreaded bumper gap on my 2013 BRZ. I bought two of these metal pieces (57722CA030 - $11 each from the dealer) and new bumper brackets (57707CA050 & 57707CA040). The fix was successful for one day and now have the gap again. Is there no permanent solution?
Similar happened to mine. The clips just ripped more of the plastic off so now there is even less. I just bit the bullet and went the quick-release route. The color match isn't too bad though. You can see them in this pic.
BigTuna is offline   Reply With Quote
Old 03-16-2021, 07:36 PM   #86
Jstyle
Jstyle's Avatar
Drives: 2020 86
@BigTuna where did you get that tire rack for your garage?
Jstyle is offline   Reply With Quote
Old 03-18-2021, 09:29 AM   #87
BigTuna
BigTuna's Avatar
Lowes, $40
https://www.lowes.com/pd/MaxxHaul-Ma...ack/1002943720
Old 03-30-2021, 10:16 AM   #88
Jstyle
Jstyle's Avatar
Drives: 2020 86
Awesome. Thank you sir!
Old 04-11-2021, 06:11 PM   #89
macuser27
macuser27's Avatar
UPDATE: I decided to give this one more go. I took the bumper off and bought two more of those metal pieces. I glued those metal pieces (using GOOP Automotive Adhesive) to the bumper and also taped them for good measure. ie. I have two of these metal pieces on each side of the bumper, closest to the headlight.
I reassembled everything, and popped these things into the bumper brackets last. Put about 200 miles of street driving and one track day, and so far so good - touch wood!
macuser27 is offline   Reply With Quote
The Following 3 Users Say Thank You to macuser27 For This Useful Post:
sato (05-11-2021), Trap63 (09-25-2021), twasd (11-28-2022)
Old 07-02-2021, 12:44 PM   #90
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Can someone clarify how many of these do I need? 2 or 4?
The instructions in the first post say quantity 4, but it looks like people are just doing the very front clip on each side of the bumper?
Old 07-02-2021, 06:31 PM   #91
Mike_ZN6
Mike_ZN6's Avatar
Also, what is the "dual glue" that is being suggested to attach these to the bumper?
I see macuser27 suggested using GOOP and some others have used E6000 230022 Industrial/Automotive glue.
Old 07-04-2021, 01:30 PM   #92
macuser27
macuser27's Avatar
Hi there,
In my personal experience, using two (one on each side) and no glue did not cut it. With four (two on each side) and using GOOP, my bumper is still attached correctly, with no sag, after 1,000 miles and 3 track days.
Your experience may vary.
Cheers.
Mike_ZN6 (07-04-2021), Tatsu333 (07-02-2025), twasd (11-28-2022)
57722ca060 plate bmpr sd, brz, subaru, zc6
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017 Trap63 Issues | Warranty | Recalls / TSB 10 06-04-2018 12:33 AM
SB18-077 *BRZ ALL, Flywheel assy and ball bearing Trap63 Issues | Warranty | Recalls / TSB 0 05-29-2018 04:26 AM
Someone recognizes this rear spoiler? pepe Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2016 06:57 AM
USB flash drive for mp3's, only recognizes 61 songs per folder? Suparu Electronics | Audio | NAV | Infotainment 6 08-22-2015 03:15 PM
