Old 07-14-2018, 05:35 PM   #85
humfrz
Originally Posted by mrg666 View Post
We cannot neglect the rotating components after transmission since whp is what we are trying to gain. Saving weight from the crank pulley has negligible effect on power compared to all those connected to the crank shaft when it is engaged to wheels. Shown in independent tests, light crank pulley has no effect on whp of our cars. I agree with you though that there might be some power gain if flywheel, transmission shaft, wheels, tires, and rotors are also lightened. Regarding accessory pulleys, I wouldn't touch water pump since engine cooling is more important than 1-2 HP gain, AC pulley is not engaged unless AC is on, alternator pulley might help but the gain is not worth the trouble. I am not reiterating (@humfrz is annoyed when I repeat myself) the vibration damping part of discussion. Enjoy driving your car!
Oh, not annoyed, just concerned. Short term memory loss can sneak up on you
Now, what were we talken about ?
humfrz
Old 07-14-2018, 05:53 PM   #86
humfrz
Or crawling inside of it in the dead of summer to fix a clog.
I have replaced so many flywheel bolts on a baler in the heat I get woozy thinking about it.
You have been there
Yep, sitting on the tractor, when you notice a extra large clump of hay going into the bailer and just know it's gonna choke on it. BAM, the sheer bolt on the flywheel snaps. OK, get in there and pull the clog out of the bailer with your bare hands.
Then, replace the sheer bolt - NOT WITH A CASE HARDENED BOLT!
(I've told that story before)
humfrz
NoHaveMSG (07-14-2018)
Old 07-14-2018, 06:19 PM   #87
mrg666
pessimistic skeptic
mrg666's Avatar
humfrz
I think we were talking about crank
The Following User Says Thank You to mrg666 For This Useful Post:
humfrz (07-14-2018)
Old 07-14-2018, 06:36 PM   #88
humfrz
Originally Posted by FRS Justin View Post
ya im sure a few arms would be missing if they played with that monster.
Hey I will let you try my vape if you put your finger here... smh
Yep, back in those days, on the farm, there were two kinds of kids, the quick, and the ones missing body parts.
I remember my grandfather setting me up on a couple sacks of grain near the big drive pulley on the engine (he was babysitting). I had lots of fun catching grasshoppers and placing them on the drive belt as it returned to the engine. The fun was to try to guess whether or not the grasshopper would jump off the belt before it got squashed by the drive pulley.
About twice a day, my grandfather would have to shut down the machine and scrape all the dead grasshopper carcasses off the flywheel - because they were making it heavy and slowing down the machine -
humfrz
FRS Justin (07-14-2018)
Old 07-15-2018, 07:54 AM   #89
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes for mpg purposes lightened internals help but at a cost. The inertia is lost and performance suffers greatly at the bottom end.
You are the only here with a point and without a childish response and yes performance could suffer in this area. Nevertheless, the FA20 engine has a strong torque at low rpm's and I don't feel my car to have an issue. In fact, after installing a lightweight flywheel and a 3 puck clutch it launches much better than before and with an immediate bite.
The Following User Says Thank You to nikitopo For This Useful Post:
FRS Justin (07-16-2018)
Old 07-15-2018, 11:25 AM   #90
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You are still posting suspect info to support your claims. We are talking about lightweight pulleys. I will say again, the dyno for the kit you posted has an under driven alt pulley.
http://www.toda-racing.co.jp/en/prod...lley-fa20.html
Developed to give lighter and sportier engine characteristic. By reducing the overall weight (and inertia) of the pulleys, and by modifying the alternator pulley ratio to take advantage of the more sporty use, the burden on the engine is reduced helping to improve acceleration performance.
I still don't believe those claims until I see a 3rd party dyno.
Old 07-15-2018, 11:31 AM   #91
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have been there
humfrz
I didn't get to sit on the tractor. I usually jogged ahead with a pitchfork trying to spread out the clumps in the winrows before it happened. Wasn't always successful
Old 07-15-2018, 11:37 AM   #92
mrg666
pessimistic skeptic
mrg666's Avatar
I posted the third party dyno results earlier. There is no HP gain.
Edit: Here you go
https://motoiq.com/fluidampr-the-independent-test/3/
NoHaveMSG (07-15-2018)
Old 07-15-2018, 12:51 PM   #93
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They under-drive only the alternator and this gives a max. of 1hp gain. It is a supplementary change and not the basic change. If you don't trust them it is your problem. I am not a representative of them here nor a seller.
Edit: Here you go
I'll say it again and for the last time. If you do a dyno on 5th gear you won't see any gains. I mentioned this already many times. The rate of the rpm increase is much slower and you'll lose all the advantage of the lighter rotating mass.
Old 07-15-2018, 06:19 PM   #94
humfrz
So, did you get blamed for the baler jams ?
In my younger days, we had our hay custom baled. After digging out Canadian thistle in the field where the first few bails were spit out, I learned to burn the first few bales that came out of a custom baler ..
When I was a teen ager, I decided to go into business for myself, baling hay. So I bought a $200 hay baler. Oh, yes, I soon found out why it sold for so cheap - the twine tying fingers were wore out. So much for the profits the first year -
humfrz
Old 07-15-2018, 07:23 PM   #95
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
humfrz
No, the guys that initially raked the winrows with the tractors got the blame. They would go too fast and it would bunch it up into clumps. We could only do so much running out front trying to fix it.
Old 07-15-2018, 07:29 PM   #96
Somerandom18
Drives: 2017 manual BRZ
Should get the Fluidamper for engine protection not phat gainz.. Was the first mod I did to this car since I plan on keeping it until the wheels fall off.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
Ultramaroon (07-15-2018)
Old 07-15-2018, 07:47 PM   #97
humfrz
There is a clump coming up - now, where did that kid go
humfrz
Old 07-15-2018, 11:28 PM   #98
humfrz
I'm sorry, I'll leave the thread alone now -
humfrz
Do Lightweight Pulleys FREE Power? With Poll NonStopTuning Engine, Exhaust, Transmission 76 09-01-2015 01:03 PM
GrimmSpeed Lightweight Crank Pulleys! RallySport Direct Engine, Exhaust, Bolt-Ons 9 01-27-2015 01:02 PM
Lightweight Pulleys in Turbo application GH05T Forced Induction 8 12-05-2014 05:21 AM
FS: GFB style lightweight pulleys. dj petey Canada Classifieds 8 05-08-2014 10:40 PM
