#85 |
Drives: 2013 FR-S Matte Orange
Yeah, the minis are what you want if you're comfortable going this route.
#86 | |
Just a dude
Drives: Scion FR-S 2013
I've never done these and don't know eff all about them, but honestly looks great IMO I ant to do this!!
#87 | |
SLO NO MO
Sent from my Nexus 5 using Tapatalk |
#88 |
Its pretty bad when you have to resort to external style fasteners to hold the bumper on a brand new car.
#89 |
Yeah, it's a shitty design from factory
#90 |
Are those installed into plastic or some sort of metal brace?
#91 |
Cognite
Drives: 2013 Whiteout FRS
Well. Here is my fix after some person backed out into me and drove off:
Step1: take pliers ![]() put tissue paper on each side as not to scratch the paint. Step2: get hold of the circled metal part and bent it SLIGHTLY away from the tire (thus effectively moving the whole part that the black bracket is sitting on and the bracket up) making the hole between the fender and the bumper smaller. Don't overdo it please. I did this with the bracket off, as it gave me the most leverage. Once adjusted the bumper doesn't snap out any more. ![]() edit: do this if the method with adjusting the screws doesn't work. just play with metal, it's really thin. Worked for me. The dent from the damage is still there thou, so is my shitty do up paint job. Time for that rocket bunny
#92 |
Drives: 13 White MT FR-S
I thought everyone in Canada was nice?
| The Following 2 Users Say Thank You to ML For This Useful Post: | covance (03-24-2016), Dipstik-sportech (01-24-2014) |
#93 |
Drives: Silver 2013 BRZ limited
anyone fix this shit? or has a fix
#94 |
Apparently someone said there are clips at the dealership that you can buy after being complaing about the alignment issue of the bumper. But that person did not reply
#95 |
Drives: 2013 Black BRZ Limited
Haven't taken the bumper off a BRZ yet but have many times on my 4th gen outback. I had this problem as well with the fender not wanting to seal back up around the headlight housing. It took me a bit to figure out what was going on (at least in my case).
I was installing an HID setup so I had to remove the headlight housing as well as the black plastic support frame around the headlight housing. The fender clips into that support frame. When I had buttoned everything back up it turned out that I had adjusted the support frame a millimeter too high. There is some play with the bolts. I loosened it up and let it drop a slight amount before retightening everything. The additional gap let the bumper tabs clip into place nicely. Not sure if this is related at all but maybe. Also, if this is happening to people who haven't touched their headlight housings then I'm completely at a loss for what it might be. |
#96 |
same problem..subbing for possible solution
#97 |
@nos145 any close up shots of the metal tab that you bent? Also, what's the method with the 'screws'? Thanks!
| The Following 2 Users Say Thank You to 1Cor10:23 For This Useful Post: | blackfireball5 (05-28-2014), Simon99 (04-19-2014) |
#98 |
Drives: BRZ MT SWP
Help please
I took the bumper off once, but not sure if it was because of that. ![]() ![]() ![]() ![]() ![]()
| The Following User Says Thank You to 8987846 For This Useful Post: | davebrus (05-14-2014) |
| Front Bumper Black Vinyl | Juanito08 | Exterior Parts (Aero, Lighting, Etc.) | 37 | 09-18-2015 04:09 PM |
| Front bumper holes... | BRZ88 | BRZ First-Gen (2012+) — General Topics | 29 | 08-14-2012 12:19 PM |
| Other than SR front bumper this is the only other one I like | Hanzo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-09-2012 03:30 PM |
| BRZ to FR-S front bumper swap? | r4m3n | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-20-2012 05:29 PM |
| Buy this front bumper for G37 Coupe? | WhatIs86For | Other Vehicles & General Automotive Discussions | 12 | 02-26-2011 02:24 AM |
