02-24-2018, 01:38 AM | #85 |
Drives: Q5 + BRZ + M796
02-24-2018, 01:41 AM | #86 | |
02-24-2018, 01:50 AM | #87 |
Drives: '15 BRZ RA
Why do you think everything should be done by software from the factory? Building a motor is basically a mechanical engineering subject, not a software engineering subject. If you cannot understand the latter difference we cannot discuss.
02-24-2018, 01:52 AM | #88 | |
02-24-2018, 01:53 AM | #89 |
Drives: '15 BRZ RA
02-24-2018, 01:54 AM | #90 | |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
The Following User Says Thank You to cyde01 For This Useful Post: | justinco (02-24-2018) |
02-24-2018, 02:17 AM | #91 |
Drives: Crapcan
I'm an illiterate dumbass sometimes......
02-24-2018, 02:30 AM | #92 | |
02-24-2018, 02:31 AM | #93 | |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Hades (03-02-2018), Irace86.2.0 (02-24-2018) |
02-24-2018, 02:59 AM | #94 | |
Drives: 2013 Toyota 86
In another thread on here all they did was punch out the internals of the cat in the headers and the torque dip was gone. The torque dip is caused by the cat in the headers. The cat was needed to meet emissions. Why dont they revise it in a later model, because emissions are a MASSIVE pain and very expensive. Once it has passed, just leave it alone. |
The Following User Says Thank You to Harey For This Useful Post: | Hades (03-02-2018) |
02-24-2018, 03:21 AM | #95 |
If you have a NA car with standard sensors you can only use the inputs provided by those sensors regardless of if your uding opensource tuning ecutek or motec. Your also limited by the engine dynamics ie intake pirt runner sizes valve sizes, cam lift combustion chamber design etc. So theirs only so much you can tune. The factory engineers also have constraints of fuel economy emissions and noise vibration harshness and more. Aftermarket tuners dont need to consider some of those. Removing the cat in the header is a big advantage.
Dyno below is a uel header, stock cars do about 100-105kw on same dyno |
The Following User Says Thank You to steve99 For This Useful Post: | Irace86.2.0 (02-24-2018) |
02-24-2018, 11:28 AM | #96 |
Drives: 2013 frs red
So I'm wondering if something that lessens the torque dip from the top of the motor ie power blocks will have the ecu pull timing after a while?
02-24-2018, 12:28 PM | #97 |
I think it was the MR2, Supra, Corrola and Celica, and from Lexus, the LFA, LC500, ISF, GSF, RCF, SC Soarer and SC430 and from Scion the tC which is a stretch.
02-24-2018, 12:36 PM | #98 |
Similar Threads | ||||
My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 04:09 PM |
Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
