Old 06-23-2013, 05:26 PM   #85
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Mine has this same sound. It appears to be when the tranny is being loaded at low RPMs ( around 1k or less). I have noticed it for months now and am not concerned. Just checked this thread to make sure I am not the only one. I will report it to the Toyota Dealership at my first oil change. As long as we keep the dealerships aware and they document the complaint. We are all in good shape. Enjoy the driving and don't think much of this. I heard another FRS in my city that had the same sound when he took off btw.
AVodka14 is offline   Reply With Quote
Old 06-26-2013, 06:50 PM   #86
City's Finest
City's Finest's Avatar
Drives: Whiteout FR-S, Black S-Runner
I hear the same rattle as described.
I just got back from the dealership to get the parts ordered to remedy the chirping noise. While I was there, I described this fluttering, or rattling noise, and demonstrated it the shop foreman while we drove around the area. From our observations, it happens under (but not limiting to) these conditions:
-Air Conditioner turned on
-Decelerating from anywhere above ~35 mph
-Transmission in neutral
-Clutch engaged (pedal depressed)
As the RPMs drop, it initially settles around 1000, then dips to ~700. It'll then dip again to ~600 and the rattle happens, only for about a second. When it stops, the RPMs return to ~700. The foreman agreed that it mostly happens when the AC is on and the clutch engaged because of the extra load the engine has to handle. The dealership didn't have a MT FR-S to duplicate at the time so I told him I would monitor the rattling until I return for the high pressure fuel pump replacement.
Grimmspeed license plate relocation - Pentosin MTF2 transmission fluid - TiC solid aluminum steering rack bushings - Kartboy rear shifter stay bushing - Whiteline gearbox positive shift bushing - Whiteline rear crossmember mount insert bushing
City's Finest is offline   Reply With Quote
Old 08-22-2013, 05:11 PM   #87
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Got mine checked by the Dealer twice already and got on the phone with some SOA people and said it is a normal sound the the car makes. The service tech. was even ask try on newer BRZ's in the lot and they to produce the same sound, most of the time slowing down on neutral or going to a stop.
zoth is offline   Reply With Quote
Old 08-22-2013, 07:37 PM   #88
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Originally Posted by Mikem53 View Post
It's gear noise.. And it's normal for lots of cars.. This being rear wheel drive.. The transmission is right there under the stick.. Combine that with minimal noise insulation and you hear the normal sounds of the mechanicals..
I had the same noises in my other sporty type cars.. When u push the clutch in, you disengage the gears in the tranny , so no noises.. When youu start off at low rpms.. U get that bouncing ball bearings noise in a can sound..
No.
Pushing the clutch pedal in does not disengage any gears. It decouples the clutch plate (transmission) from the flywheel (engine).
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
Old 08-22-2013, 08:12 PM   #89
Mikem53
Drives: FR-S 6MT
Originally Posted by JonnyRocket View Post
No.
oh here we go.. another internet scientist..
it stops the input shaft of the tranny doesnt it.., it stops any gears from being able to spin.. so back to my point.. it stops the noise from the tranny.. geezz
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
|-Goku-| (09-06-2013)
Old 10-23-2013, 02:31 PM   #90
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
The same problem happens here when I brake in neutral.
I think might be the transmission. When the car slow down, the shift knob might shake and the shift might touch the gears inside. It will also happen when you touch the shift without push in the clutch.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-23-2013, 04:24 PM   #91
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
has anyone had this fixed by subaru/scion? I'm dropping mine off on wednesday for this issue amongst others
abutterman is offline   Reply With Quote
Old 10-23-2013, 08:52 PM   #92
topazsparrow
Drives: slow
Most people are just hearing the flywheel rattle. So far as i know it's a dual mass flywheel and as such has a resonant frequency that causes the respective components to vibrate or shake - this is particularly evident in the 1600 - 1900 rpm range with low to moderate load on the engine (coasting in 2nd gear through a parking lot). This shaking causes the springs within the flywheel to create noise.
topazsparrow is offline   Reply With Quote
Old 03-01-2014, 10:00 AM   #93
theseloaded86hips
theseloaded86hips's Avatar
Drives: Firestorm FR-S MT
I have the rattle noise as well. My car is at the dealer now getting a few other things fixed. They don't know what the noise is. I couldn't duplicate it for them so I showed them a video. Has anybody got this fixed or been told what the issue is?
theseloaded86hips is offline   Reply With Quote
Old 06-24-2014, 12:04 PM   #94
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
Bringing this back up as I'm noticing the exact same rattling on my car, It is brand new and the break in hasn't happened yet. I am reassured by the posts of much more experienced people on this thread but I was wondering if Subaru/Toyota have said/found anything about the issue or came out with a fix?
meh.
NJ10 is offline   Reply With Quote
Old 07-08-2014, 04:51 PM   #95
AzBRZ
Drives: '13 DGM BRZ with 4 pedals, '11 WRX
I have it too, exactly as described by others, rolling to a stop in neutral.. Please keep this thread posted if a solution is found.
AzBRZ is offline   Reply With Quote
Old 07-30-2014, 12:33 PM   #96
JRD3D
Drives: 2015 Scion FR-S
Just in case it contributes to the thread, I just got a brand new 2015 Scion FR-S and it too has the rattle noise when coming to a stop in neutral.
JRD3D is offline   Reply With Quote
The Following User Says Thank You to JRD3D For This Useful Post:
pLaydEad86 (07-10-2015)
Old 07-30-2014, 12:53 PM   #97
cookiesowns
Drives: WRB BRZ Series.Blue
I do also get the same noise. After talking to a few different twin owners, they say the noise just comes with the car.
Look at where the transmission is mounted!
The 1st gear "thump" due to the diff is also normal.
cookiesowns is offline   Reply With Quote
Old 08-08-2014, 11:01 PM   #98
Michael Victim
5-TIME CHAMPIONS!
Michael Victim's Avatar
Drives: 2015 Subaru BRZ Series.Blue
I just picked up the 2015 Series.Blue on 7/31. Had to drive across state afterwards to attend a funeral. I put up 650+ miles during the trip, & noticed this rattle mostly when slowing in idle, but also a similar noise occasionally when shifting gears, so it's still happening w/ 2015 models.
Good to know that it's probably normal, but I'm going to mention it to the dealer anyways for documentation sake. It is quite annoying.
Past Rides: '02 Acura RSX Type S, '04 Acura TSX, '13 Harley Davidson Sportster Iron 883
"San Antonio is the city where I come from so run-run!"
Michael Victim is offline   Reply With Quote
flywheel, rattle, transmission
Interior rattle frsinpa Issues | Warranty | Recalls / TSB 132 03-23-2015 04:09 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
