01-04-2017, 10:26 AM | #85 | |
Drives: Fr-s
What you state in your second paragraph is what the spring on the cae shifter does, keep it centered or add force side to side. It's a torsion spring.
01-04-2017, 11:00 AM | #86 |
Drives: 2018 Golf R
I had the Billet Pro Shop shifter in my car, and the IRP (installed last night) requires less effort than that. It feels almost stock, just...better.
I do have the rattle though, and it seems to be coming from the reverse lock out button. If I lightly press the button, the noise will cease. I'm trying to figure out a way to isolate it a bit better. Aside from that, I love the shifter. It feels great and the height is perfect for me. Quick note for others - if you have a one piece driveshaft, you'll need to remove it to make the installation easier. I managed to get the old upper support bracket out of the tunnel by lowering the transmission. But when it came time to attach the shift rod to the shifter, there wasn't enough room in the tunnel to get pliers in there to slide the shift rod onto the shifter. Pulling the driveshaft gave me the room to do it easily.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post: | The Racers Line (01-07-2017) |
01-04-2017, 11:20 AM | #87 | |
Drives: Toyota GT86
As for side to side, I wouldn't want any more spring force than what MTec springs already provide. The IRP shifter centers very fast and accurately with the MTec springs. Even with the stock springs, it centered more than sufficiently that you wouldn't miss a gate. So what's the point of making an even greater barrier to go into 2nd or 5th? Of course, you save the bother of installing the MTec springs, but they are around €$30 and take 10 mins to change when you are down there anyway.
The Following User Says Thank You to Tor For This Useful Post: | Crazypinoy9 (01-10-2017) |
01-04-2017, 01:36 PM | #88 |
On the want list. Very nice shifter
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
01-07-2017, 11:55 AM | #89 |
Super short comparison of OEM vs. IRP in our new 86. Full install coming soon on our Youtube channel.
https://www.instagram.com/p/BOqRnWPA...86speedfactory |
01-08-2017, 06:26 AM | #91 |
Drives: Toyota GT86
See the video in post 61: http://www.ft86club.com/forums/showp...0&postcount=61. As you can see my rattle is gone without the aluminum plate covering the hole in the transmission tunnel. Some kind of vibrations occurs between the rubber boot, aluminum plate, and shifter (on my car at least). Are you sure yours come from the reverse lock out and not from the base of the shifter? It can be hard to pinpoint the origins of vibrations.
I changed the rubber boot with a softer one and it improved a lot. I am not driving the car at the moment (winter, salty roads), but the next thing I'll do will be to change the aluminum plate out with a piece of carbon. I haven't been in a rush to do so as it is much less noticeable now and only at high rpm now that it doesn't bother me that much. If yours really originate in the reverse lock out mechanism, maybe an idea could be to tighten the wire a notch? Didn't look if it's feasible, but just an idea. A good thing is that after first install everything can be done from inside the car. I had the shifter out at least 10 times, doing diagnostics. Now that I'm in practice I can have the shifter out and back in, in 5 mins, not counting removing the center console.
The Following 2 Users Say Thank You to Tor For This Useful Post: | 86Tony (01-08-2017), civicdrivr (01-09-2017) |
01-09-2017, 11:37 AM | #92 | |
Drives: 2018 Golf R
Thanks for your response!
Parting out HERE
01-09-2017, 01:33 PM | #93 |
Drives: Toyota GT86
I have been working on mine, and now the center console was out again, I made this short video demonstrating the centering force with the upgraded gearbox springs.
[ame="https://www.youtube.com/watch?v=TCS7pO55kwE"]IRP Germany shifter for the GT86/BRZ/FR-S - centering spring force - YouTube[/ame]
The Following 4 Users Say Thank You to Tor For This Useful Post: |
01-09-2017, 02:19 PM | #94 |
Drives: '13 LAVA - lightly modded
New RACING short shifter from Individual Racing Parts
It makes me happy knowing there is someone as conscientious and yet with such childlike enthusiasm making videos like this for our car parts perhaps it's the charm of Germanic thoroughness to a lazy American 👍👏🏻🙏
You are going to be condemned to live out the consequences of your taste - TM
The Following 3 Users Say Thank You to TeutonicShift89 For This Useful Post: |
01-10-2017, 04:27 PM | #95 |
Drives: Toyota GT86
Danish child, in Germany for 8 years now. There are too many great racetracks here, all within 2 hours reach (Nürburgring, Spa, Zolder). I'll probably never escape.
The Following 2 Users Say Thank You to Tor For This Useful Post: | Crazypinoy9 (01-10-2017), TeutonicShift89 (01-10-2017) |
01-12-2017, 07:11 PM | #96 |
Well thanks to this thread I just ordered mine today! 🤣
02-05-2017, 10:15 PM | #97 | |
What did you use / where did you source the rubber? I just installed mine and there is a highly annoying rattle starting around 2500 rpm, which is cruising speed, and only gets louder as you accelerate. Sounds like the reverse lock out initially but when you grab the lever you can feel the rattle is Coming from the base. It's bad enough I'm not sure I'll be able to deal with it 😱 Sent from my iPhone using Tapatalk
02-05-2017, 10:30 PM | #98 | |
Drives: Toyota GT86
http://www.ebay.com/itm/VW-Shifter-B...-/172251473979 You need to cut it a bit to get it to fit (there is an internal part that need to be removed. Also, you need to cut down the boot that came with the shifter. That way the ebay boot rests on the remains of the IRP boot, wherein it becomes two piece. Two more things to check/do, before bothering with the boot: - That there is no slack in the reverse cable (losen the screw on the base, and pull it tight to take up any slack that could cause the button to vibrate). - Wrap a thin piece of foam around the cable where it passes through the lever. So that the cable won't vibrate against the handle.
The Following 3 Users Say Thank You to Tor For This Useful Post: |
Similar Threads | ||||
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
WTB: Megan Racing Cat-Delete pipe And short shifter | AZ_Racer_1 | Want-To-Buy Requests | 1 | 01-25-2015 12:54 AM |
kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
Short Vid about Okinawan Street Racing | vividracing | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 03-03-2014 10:29 PM |
TOM'S Racing Parts, First from Vivid Racing! | vividracing | Exterior Parts - The Rest | 4 | 09-11-2012 04:20 PM |
