Old 10-25-2016, 01:55 AM   #85
MeisterR
MeisterR's Avatar
Drives: BNR32
Originally Posted by fuddbutter View Post
Changing the rear LCA's to something like Parts shop Max will drop the car 25-40mm without changing the suspension set up.
Think there are a few others too which will do this.
give you more room to move!
Yep, but when you design a suspension you can't always say an aftermarket LCA is required.
I always design function over form when working on suspension.
Because a suspension that hit the bump stop all the time and provide an extremely choppy ride is not something I would want to ride on at all.
Therefore, it isn't something I would want to provide to the community.
Lowering is good, but only to a point where the car still remain a car that you want to get in and drive.
No one want to wake up in the morning, clinch their teeth on the way to the garage, because they know the journey ahead is going to be painful.
Jerrick
MeisterR is offline   Reply With Quote
Old 10-25-2016, 02:12 AM   #86
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Good luck primo
mswbrz is offline   Reply With Quote
Old 10-25-2016, 08:44 PM   #87
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Jerrick
I agree, you can't tell them that an aftermarket LCA is required, but if someone is wanting to get low, then it's kind of a requirement, there is not much travel in the rear as it is, you lower it more than 20-30mm, then you are going to have issues.
If you want to slam it, and still have somewhat of a nice ride, then LCA's that will lower the car, not the strut is just common sense.
putting in PBM LCA's drops the rear up to 40mm without changing your suspension.
These go in the same basket as the subframe/diff risers, or higher rated drive shafts, they are supporting mods so other things don't break or won't cause problems.
They are things you don't necessarily need, but if you want to play with the big boys...
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
Conflicted with TINT%! babylobster Cosmetic Modification (Interior/Exterior/Lighting) 75 06-06-2014 04:54 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
I'm conflicted FR-S now or BRZ later? Evil86 Scion FR-S / Toyota 86 GT86 General Forum 6 05-09-2012 08:45 PM
