Old 12-29-2012, 12:26 AM   #85
OrbitalEllipses
Drives: Attitude
Originally Posted by Racecomp Engineering View Post
Most won't do that and I understand why. Perhaps someone will release a non-adjustable bushing for that location. Still sucks to install but you don't have to worry about adjusting it and save some money and you're alignment guy won't hate you.
- Andrew
http://www.whiteline.com.au/product_..._number=W63225
Ask and you shall receive. That appears to be a race durometer (black color) non-adjustable bushing for that location. Even links to the same install guide as the camber-adjusting bushing.
Old 12-29-2012, 12:37 AM   #86
whataboutbob
AutoX-10/10ths every run
Correct!
Build thread:Here
Old 12-29-2012, 01:56 AM   #87
robispec
Drives: Black frs project
this all looks good
robispec is offline   Reply With Quote
Old 01-03-2013, 05:59 AM   #88
Jetscape
Jetscape's Avatar
Drives: Toyota GT 86 Red AT
Thanks for the great technical info. I would like to ask how changing to 18x18.5(front and rear) square set up or 18x.8.5(front), 18x9.5(rear) staggered setup affects total ride dynamics of the 86. This on stock height and springs. This seems to be a popular setup in most 86. Thanks.
Originally Posted by Moto-P View Post
Increasing, or changing tires sizes both in width and diameter has consequences that change many different variables, and simply raising the contact patch should not be taken lightly or be treated as a fix-all solution. Increased tire contact patch also means less ability for the tires to reach proper temperature, and reduced grip over loose surface as rain and snow, and even dirt.
I think to keep the inherent balance of power and handling of the FRS/BRZ, the tire size change should be minimal, regardless of going with 16", 17" or 18" to keep the same diameter, and relatively small widths. 225's and 235 width should be plenty for a light FRS, to be fun and agile as universal car. Going beyond this only if there is a specific purpose in various field of REAL racing.
Jetscape is offline   Reply With Quote
Old 05-28-2013, 03:46 PM   #89
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Why isn't this thread a sticky?
Old 05-28-2013, 09:55 PM   #90
normanb21
Drives: black frs
Sticky this mofo!!! I have an frs and I just bought some 17x8 xxr 527 wheels(19.1lbs) and went with a 245/40/17 94xL(23lbs)michelin pilot super sports all the way around. I also just installed the subaru camber crash bolt. The car rides much better which was a surprise to me, I was expecting a firmer ride. As for performance, the car feels much better during turn-in and holding mid corner but it does feel like the car kinda snaps loose now instead of a controlled slide. Its not a huge difference, its still a controlled slide, just a little harder to figure out when those rears will break loose. Any ideas why? I also need to lower the car a bit but want to keep that little oversteer. What kind of springs,spring rates, and drop am I looking for to keep the stock suspension characteristics with these new wheels and tires on my car?
normanb21 is offline   Reply With Quote
Old 05-28-2013, 09:57 PM   #91
ATL BRZ
ATL BRZ's Avatar
RCE Yellows and RCE Sways. 22mm drop, 250 lbs front and rear and they put the OEM struts in the 65% critically damped sweet spot. Sways set stiffer in the rear and softer in the front. Oversteer is still there at the limit of adhesion and is predictable. Body roll is gone. Turn in is razor sharp. Ride height is perfect for practicality and performance.
Old 05-28-2013, 09:58 PM   #92
normanb21
Drives: black frs
Forgot to add a pic of my car. It looks a little taller but according to the wheel size and tire size, its still the same. Name:  ImageUploadedByTapatalk1369792631.160267.jpg
Old 07-17-2013, 11:09 PM   #93
Iamthebatman
Drives: Black Subaru BRZ
Bump for a thread I think everyone needs to read! Thanks Moto-P and ATL BRZ!
Iamthebatman is offline   Reply With Quote
Old 07-18-2013, 12:35 AM   #94
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
yup ordered swift springs with my 17x9 rpf1's with 245 tires.
bkblitzed is offline   Reply With Quote
Old 07-24-2013, 12:29 AM   #95
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
anyone have thoughts on these? http://ft86speedfactory.com/tein-s-t...rings-118.html
Wilso is offline   Reply With Quote
Old 07-25-2013, 11:33 AM   #96
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Originally Posted by Hanzo View Post
What springs do you recommend if I just want lower it slightly with stock shocks (btw I have a brz).
RS*R just came out with economical Lowering Springs that work fine with the stock shock absorbers too
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
Old 07-25-2013, 11:38 AM   #97
Moto-P
Moto-P's Avatar
Originally Posted by Bmore_Raven86 View Post
Hey Moto what brand would you recommend if you just want a lowering springs?
RS-R has lowering springs for the FR-S and BRZ, it's called the Super-Down Sus, and it drops the cars about 30-40mm. They work with stock shock absorbers, and have different rate sets of progressive spring matched with different part# and rates for the FRS and BRZ to match to even the slightest difference in the two cars OEM shocks.
Moto Miwa
Old 07-28-2013, 04:56 AM   #98
SurfAndSand
8SiX
Drives: FRS 10series
Do you mean lower the car and maintain handling capabilities?
Or
Lower car for aesthetic purposes and at least not destroy the suspension?
SurfAndSand is offline   Reply With Quote
Remotely lower windows with key fob? Kido1986 BRZ First-Gen (2012+) — General Topics 25 07-16-2012 10:11 PM
Lower car 1.5 - 2.0 inches F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-23-2012 09:30 PM
BRZ spotted in lower mainland! kidgogeta CANADA 21 04-29-2012 02:20 PM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
