Old 12-15-2015, 01:26 AM   #9759
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
For all the current ESC owners with the procede, where do you guys have it mounted at?
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 12-15-2015, 01:45 AM   #9760
TM
TM's Avatar
Drives: DGM BRZ 6MT
Passenger side right next to the throttle and rpm signals that I tapped.
TM is offline   Reply With Quote
Old 12-15-2015, 01:21 PM   #9761
PantsDants
Drives: Scion FR-S A/T, Whiteout
I have mine sitting on the shelf behind the dash; there's a lip that will keep it from falling down. It's really close to the access hole on the side with the cover on it. I can actually reach my fingers in there and turn it to plug a USB cable in, makes changing the tune pretty easy.
PantsDants is offline   Reply With Quote
Old 12-15-2015, 07:59 PM   #9762
rhythmM
rhythmM's Avatar
I finally finished my install. Did the ESC the first day, and PROcede the next day (ended up putting it right next to the ECM/ECU next to door).
Took it for a spin last night with just the wot switch installed. And it felt great! Can really feel the pow kick in. At one point I heard a "pop noise" in the back. Wasn't sure what it was.
Installed the procede today. Took it for another spin. Didn't really get to test it out much but I did notice the power is more consistent. Will need more time with it, but I can say now, that, I'm going to really enjoy this
Also, that "pop noise" happened again in the rear during wot. I've never heard this on my car before. Is this exhaust backfire?
Old 12-15-2015, 09:50 PM   #9763
Gums
Drives: SWP BRZ
Have mine attached to the back of the steel knee airbag plate with velcro, no rattles.
Gums is offline   Reply With Quote
Old 12-15-2015, 10:09 PM   #9764
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Hi guys, I have a question for Fenton, Rob, and any other of you guys with some longer term experience with running this system. I'm starting to wonder if I have'nt reached the end of my battery packs life cycle. I have noticed that the regular voltage level has dropped from 28.7-8V to 28.4-5. It also is much harder to "condition" the batteries to give a good hit of boost. Now my first hits are really weak, it takes 5-6 re-charge cycles to get any kind of a decent pull. I inheriteted the original set of batteries that Fenton tested with, and have now put two years of use into them.
What is the expected lifetime of a set of battery packs, and what sort of deterioration would indicate they are past their good performance envelope?
They are lead-acid batteries, they do have a cycle limit. Is this what I'm seeing right now? It started fairly quickly, over the last month or so.
silent runner is offline   Reply With Quote
Old 12-16-2015, 10:19 AM   #9765
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I wish i can just go ahead and install!
how long did you take? seems like pretty straight forward. probably wire through sound delete hole into passenger side would take long time
Old 12-16-2015, 10:21 AM   #9766
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I haven't had issues with my batteries but I noticed when it's cold it takes a lot longer to get a good hit off the batteries.
Installed Mods:
Old 12-16-2015, 10:22 AM   #9767
Sojhinn
Sojhinn's Avatar
Congrats
Installed Mods:
Old 12-16-2015, 11:49 AM   #9768
fenton
Its winter now, the batteries cannot give the same juice when it gets cold. The catch 22 with this is although you will get less boost(psi) you will need less because the charge air will be so cold.
Thanks,
fenton is offline   Reply With Quote
Old 12-16-2015, 01:20 PM   #9769
rhythmM
rhythmM's Avatar
I think it's pretty straight forward. Spent half a day(daylight) installing the ESC one day and another for the PROcede. Most of the time spent was prepping, trying to retrieve a couple things that fell into the engine compartmen or got stuck, and figuring out my wiring harness for the PROcede. The actual install was easy.
I'm just glad this thread is so comprehensive. And I was able to find answers to my delemna on here using the find feature and control+F.
Old 12-16-2015, 02:15 PM   #9770
DAEMANO
Time Traveller
Congrats indeed!.
Yes that was probably a backfire, nothing to worry about unless you notice very rich, or lean conditions in your logs (check your AFR). Make sure to log the first few days with your kit to ensure everything is healthy. If no anomalies, just enjoy them occasional backfires.
Old 12-16-2015, 07:37 PM   #9771
silent runner
Thanks,
Ok, I understand this, but I'm pulling out of a heated garage in the morning, In cold weather I have been used to getting the benefits of both worlds: cold air, warm batteries. I'm going to upgrade to the new higher current batteries regardless, but I'm getting the distinct impression that after a couple of years of running time, there just is not the same speed being spun-up by the compressor. I could hear the (high pitched) sound of a turbo spooling at lower speeds before, and it just never gets to that range now. Two years plus, is not bad for beating up a set of lead acid batteries, so I'm not disappointed or concerned, but I am wondering. The car has 360K Km. on it now, but it hasn't shown any signs of burning oil, or getting weaker off of boost.
Old 12-16-2015, 09:20 PM   #9772
Gums
Drives: SWP BRZ
Use a length of cable (or similar) tape the plug/wires to one end and carefully feed it through.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
