06-06-2019, 08:31 AM | #953 | |
Panda Trueno
Drives: No twin now.
You're authorizing them to fix that on your dime?!?!?!? It is pretty evident they either messed up the sensor, or the install of certain parts to throw that code with as much as your engine has been apart. They should have just given you a longblock long ago and sent you on your way. |
06-06-2019, 10:07 AM | #954 | |
Drives: 13' Lightning Red Brz
The Following 2 Users Say Thank You to Ichima For This Useful Post: | maslin (06-06-2019), Summerwolf (06-06-2019) |
06-06-2019, 12:41 PM | #955 |
Drives: 2019 Mazda Miata RF
Lack of longblocks in Subaru's U.S. inventory, is what I was told back in March, and the reason in my case.
06-06-2019, 03:33 PM | #956 |
Drives: 2013 Scion FRS
For both those who’ve had issues after the recall and those that didn’t.. do you mind sharing what sealant was used based on your invoice? Recently got my car back and I know you’re supposed to be using tb1217 for fa20’s but Toyota fipg 00103 was used on my repair throughout. No issues as of yet but it’s only been a couple days.
2013 Firestorm Scion FRS 2005 Civic SI Sedan- Sold 2004 Impreza WRX - Sold 1992 Civic Hatchback - Parted, RIP |
06-07-2019, 06:14 PM | #957 | |
Drives: '13 Subaru BRZ
Not trying to rub it in. I feel for the people here. This is where I got my recall done. Surprisingly small dealership for the Harrisburg area. I'm no mechanic but so far it seems like the car was in good hands. |
06-07-2019, 06:59 PM | #958 | |
Drives: CBS BRZ Limited 6MT
I'm definitely going to keep all the paperwork and see if I can get something to hold Subaru accountable if the engine grenades.
Back in (Crystal) Black.
06-07-2019, 11:50 PM | #959 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Zadkiel (06-08-2019) |
06-08-2019, 07:48 AM | #960 |
TRACKBREAD
Failure After J02 Recall - Discussion Threads
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | humfrz (06-08-2019) |
06-08-2019, 03:06 PM | #961 |
The Following User Says Thank You to humfrz For This Useful Post: | Yoshoobaroo (06-08-2019) |
06-08-2019, 10:36 PM | #962 |
Oh I made sure it was the new part #, and the car was actually delayed because they didn't have the new plugs or the grease. My only thing is that it seems like the idle occasionally dips a bit in neutral while driving, not the AC dip either. No strange noises yet.
06-08-2019, 10:52 PM | #963 | |
humfrz |
06-10-2019, 11:27 PM | #964 |
Drives: 13' FRS
so hello I am new here.
I have a 13 FRS that is in need of the J02 valve spring recall. Car currently has 67xxx miles and is bone stock except for an Invidia N1 catback. Is the best move to just wait this one out? How many cases of valve spring failure were there to bring about the recall? I looked at the sheet and saw 70 cars failed after the recall and knowing my luck I would be number 71. |
06-10-2019, 11:59 PM | #965 | |
I understand that about 90 some cases of failed valve springs brought on the recall (90 some out of many, many cars built.) Yes, several cars have reported failing after the recall work. I have a 2013 FR-S with 25,000 miles and it's subject to the recall. However, my present position is that I wont have the recall work done until it needs new plugs or a new TOB (or both). Even then, I may not have it done. My thought is "if it ain't broke, don't let em break it". humfrz |
The Following 5 Users Say Thank You to humfrz For This Useful Post: | alan.chalkley (06-11-2019), PWBRZ (06-11-2019), Rampage (06-11-2019), Teseo (06-11-2019), why? (06-11-2019) |
06-11-2019, 07:03 AM | #966 |
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
