Old 06-06-2019, 08:31 AM   #953
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by Ichima View Post
In my case, I wouldn't be as skeptical as I was pulling a P0017 code after the recall which happens to be on the passenger side of the motor I believe. Which is for the Camshaft sensor, and now I'm pulling P000B and P000A for slow camshaft response. I'm giving the benefit of a doubt and will replace the OCV as they stated I needed to only replace Intake Side Bank 1 and "all my issues will be solved".
You're authorizing them to fix that on your dime?!?!?!? It is pretty evident they either messed up the sensor, or the install of certain parts to throw that code with as much as your engine has been apart.
They should have just given you a longblock long ago and sent you on your way.
Old 06-06-2019, 10:07 AM   #954
Ichima
Drives: 13' Lightning Red Brz
I had an OCV sitting around in my house so I installed it myself as they tried to charge me $300 to replace an OCV. Funny thing is, I never replaced it and when I did bring it back to them saying I did with the light still on. They diagnosed it and no light came back. 600+ Miles now and it's driving fine. I agree with the longblock though, they've quoted me $13,000 to rebuild my motor before being held at fault after this recall. I also asked the service manager why he didn't just replace the motor instead of rebuilding it as I thought it would be cheaper and also safer process since it's clear that his techs are not knowledgeable enough to even put a motor back together.
Ichima is offline   Reply With Quote
The Following 2 Users Say Thank You to Ichima For This Useful Post:
maslin (06-06-2019), Summerwolf (06-06-2019)
Old 06-06-2019, 12:41 PM   #955
Gunman
Drives: 2019 Mazda Miata RF
Lack of longblocks in Subaru's U.S. inventory, is what I was told back in March, and the reason in my case.
Old 06-06-2019, 03:33 PM   #956
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
For both those who’ve had issues after the recall and those that didn’t.. do you mind sharing what sealant was used based on your invoice? Recently got my car back and I know you’re supposed to be using tb1217 for fa20’s but Toyota fipg 00103 was used on my repair throughout. No issues as of yet but it’s only been a couple days.
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 06-07-2019, 06:14 PM   #957
Nivikus
Drives: '13 Subaru BRZ
Originally Posted by Nivikus View Post
Signed up for the forums just to thank everyone here for the information and what they're experiencing at the dealerships.
I took my BRZ in and they had no problem doing the recall despite having the Edelbrock supercharger. They either weren't aware of the recall issue or they were playing dumb. Hopefully it just means they've had zero people come back with issues.
I've only had it back a few days and put about 100 miles on it. Engine seems better than ever so far. I'm going to be nervous for the next thousand miles or so.
Just reporting back with an update. A little over 1,300 miles later, everything still seems fine. No CELs, fluids levels are still fine, no rough idle/starts, etc.
Not trying to rub it in. I feel for the people here.
Originally Posted by Zadkiel View Post
Just dropped mine off at Faulkner Subaru in Harrisburg, here's hoping no surprises on 500 miles.
This is where I got my recall done. Surprisingly small dealership for the Harrisburg area. I'm no mechanic but so far it seems like the car was in good hands.
Nivikus is offline   Reply With Quote
The Following 2 Users Say Thank You to Nivikus For This Useful Post:
caus (07-13-2019), humfrz (06-07-2019)
Old 06-07-2019, 06:59 PM   #958
Zadkiel
Drives: CBS BRZ Limited 6MT
I get mine back tomorrow or Monday, depending on how much sleep I want to get(Nightshift all this weekend.) Only issue I had was that I was quoted the 3 days(5/28/19), but they didn't take it in to work on it until the following Monday(6/3/19), and they didn't have the plugs and grease for the TOB until Thursday(6/6/19).
I'm definitely going to keep all the paperwork and see if I can get something to hold Subaru accountable if the engine grenades.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 06-07-2019, 11:50 PM   #959
Oh, I hope they REPLACED the TOB with the new improved version and just greased the clutch fork. You may wish to ask them that -
Zadkiel (06-08-2019)
Old 06-08-2019, 07:48 AM   #960
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Failure After J02 Recall - Discussion Threads
TOB needs grease too, where it slides on the input shaft snout
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
humfrz (06-08-2019)
Old 06-08-2019, 03:06 PM   #961
Point well taken -
Yoshoobaroo (06-08-2019)
Old 06-08-2019, 10:36 PM   #962
Zadkiel
Oh I made sure it was the new part #, and the car was actually delayed because they didn't have the new plugs or the grease. My only thing is that it seems like the idle occasionally dips a bit in neutral while driving, not the AC dip either. No strange noises yet.
Old 06-08-2019, 10:52 PM   #963
Since the battery was disconnected, that idle situation just may be the ECU relearning. I'd give it a few days/miles to settle down.
Old 06-10-2019, 11:27 PM   #964
KABAR432
Drives: 13' FRS
so hello I am new here.
I have a 13 FRS that is in need of the J02 valve spring recall.
Car currently has 67xxx miles and is bone stock except for an Invidia N1 catback.
Is the best move to just wait this one out? How many cases of valve spring failure were there to bring about the recall? I looked at the sheet and saw 70 cars failed after the recall and knowing my luck I would be number 71.
KABAR432 is offline   Reply With Quote
Old 06-10-2019, 11:59 PM   #965
WELCOME to the forum -
I understand that about 90 some cases of failed valve springs brought on the recall (90 some out of many, many cars built.)
Yes, several cars have reported failing after the recall work.
I have a 2013 FR-S with 25,000 miles and it's subject to the recall. However, my present position is that I wont have the recall work done until it needs new plugs or a new TOB (or both). Even then, I may not have it done.
My thought is "if it ain't broke, don't let em break it".
The Following 5 Users Say Thank You to humfrz For This Useful Post:
alan.chalkley (06-11-2019), PWBRZ (06-11-2019), Rampage (06-11-2019), Teseo (06-11-2019), why? (06-11-2019)
Old 06-11-2019, 07:03 AM   #966
Gunman
Could be a cam sprocket, some of the original ones had issues, which would mess up the timing adjust.
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
