Old 02-22-2018, 11:38 PM   #953
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Originally Posted by Twinz View Post
They mentioned considering the 2017+ models for the class. The gearing would probably introduce course-dependency and I think that goes against the "all about the driver" element of the class.
SSC 1 and SSC2? That would make sense.
dowroa is offline   Reply With Quote
Old 02-22-2018, 11:43 PM   #954
edj
edj's Avatar
Drives: 2022 Toyota GR86
Originally Posted by Imp View Post
13) How often do the konis need to be serviced? Exact same shock internally as the street car shock, expect to be 100k miles. If they feel funny, or adjuster no longer works, koni can fix.
18) The way the shocks are sealed, and such, if the shocks die, not rebuildable... will not open them up to adjust or tweak internally. Must be replaced with a new certified unit.
these two are incompatible unless Koni is going to replace the shocks free of charge. hopefully somebody will clarify this?
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 02-23-2018, 06:24 AM   #955
Open Loop
2013 FR-S Whiteout / SSC
Thank you for the summary of the Town Hall. Just to confirm no. 9, center caps included in wheel weight?
Thank you again.
Open Loop is offline   Reply With Quote
Old 02-23-2018, 08:15 AM   #956
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Thank you again.
He said the cap that came with the wheel (rather than a home-made chunk of lead I guess) but I have not seen it in the actual rules.
Twinz is offline   Reply With Quote
Old 02-23-2018, 08:26 AM   #957
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Originally Posted by iLuveKetchup View Post
I don't remember this. Was this in context of contingency?
It was recorded too so should be available. Duck and I were also messaging back and forth, it was said. Parts are not to be interchanged although they may be the same parts.
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 02-23-2018, 08:27 AM   #958
Imp
Bring out your dead
Yes and no. They mentioned it (yes), but said it's not under consideration at the time (no). They believe they have a good set to work from. In the future, they may, but not going to be soon.
--kC
The Following User Says Thank You to Imp For This Useful Post:
dowroa (02-23-2018)
Old 02-23-2018, 08:30 AM   #959
Imp
Bring out your dead
Not really. Koni stands behind the quality of their work. Common sense prevails.
If you notice issues with your shocks, contact Koni.
Still under warranty? You get a new one (not a rebuilt).
Out of warranty? You buy a new one. (Not feasible to be rebuilt).
They say koni builds these to last 100k miles or so (i.e., it's a GOAL they wish to achieve, not an absolute).
--kC
Old 02-23-2018, 08:31 AM   #960
Imp
Bring out your dead
Thank you again.
Correct. Centercaps that came with the wheels. (Common sense prevails here too, don't go adding weight or making new centercaps out of lead).
--kC
Old 02-23-2018, 12:42 PM   #961
tony_r
tony_r's Avatar
Drives: '15 STX
--kC
I don't know how you police that at all, aside from the obvious bits like appearance, etc.
tony_r is offline   Reply With Quote
Old 02-23-2018, 03:07 PM   #962
TMF
TMF's Avatar
Drives: '14 FRS TT5
I think common sense applies here too - don't put FRS headlights on your BRZ. But if you need crash bolts, it shouldn't matter whether they came from Toyota or Subaru.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 02-23-2018, 04:27 PM   #963
Imp
Bring out your dead
They don't police it at all.
We police it as competitors.
--kC
Old 02-23-2018, 05:11 PM   #964
tony_r
tony_r's Avatar
Drives: '15 STX
--kC
Yes, I know. The question was how. Not who.
Old 02-24-2018, 12:48 PM   #965
DaWorstPlaya
Drives: 2016 FR-S
Originally Posted by steverife View Post
2) Anybody plan on running the car in a PAX class this year? I don't anticipate anyone else local running/prepping an SSC car and I don't love the idea of pretty much being guaranteed last in "Pro" every event.
No way Jose! James Darden, 2016 ESP National Champ, and one of the top drivers in our region recently drove a fully prepped SSC car at a local time attack auto-x event and was raw timed by a decent ES driver in a MR2 (mid pack at Nats). James was saying the PAX for this car needs to been in the GS/HS territory.
I didn't realize the Falkens were that bad.
I'm sure Rick Ruth isn't going to listen tho ...
DaWorstPlaya is offline   Reply With Quote
Old 02-24-2018, 09:26 PM   #966
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I was supposed to co-drive that car with James and Kinch at the SCCA event but as you know it was cancelled and I decided to skip the Time Attack. I am very curious as to how well that car was set up being that it had only been out to one previous event. I have a hard time believing that most SSC cars (or any car for that matter) are going to be set up optimally after being driven at only a few events unless the driver(s) are set up/testing experts and knowledgeable in the chassis. While the PAX number may still be off once the cars are developed and driven to their full potential, the possibility of a tune is still on the table which could also help bring the car closer in line to the current number. If I were Rick Ruth, considering those factors, I would take a wait and see approach before announcing any changes.
Briankbot is offline   Reply With Quote
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
