Old 01-20-2015, 05:02 PM   #9535
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by Hotrodheart View Post
Flux capacitor?
When this thing hits 88 Miles Per Hour, you're going to see some serious drift!
USB charger + light from ThinkGeek. It fit perfectly so I figured I'd leave it in. It has an on/off switch too, which is great compared to other ones I've seen that just drain the battery if they're left in.
The Following User Says Thank You to LucidMomentum For This Useful Post:
wtrxprs007 (01-21-2015)
Old 01-20-2015, 05:06 PM   #9536
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Welcome back from banned camp Koa.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
The Following 2 Users Say Thank You to Defuser For This Useful Post:
Koa (01-20-2015), Tcoat (01-20-2015)
Old 01-20-2015, 06:11 PM   #9537
Koa
Thanks a learned a lot😳
Old 01-20-2015, 07:09 PM   #9538
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Originally Posted by Koa View Post
Subarupartsdepot! Got both the connector and oil cooler assembly. Used 1/2 inch and 3/8 inch hose for the lines and tapped into the throttle body. Had a bit of headaches and torn up hands from running those stupid lines but all in all love what I'm seeing- oil temps stay below 215F and coolant temps hold at 190-194 even under sustained, hard pulls
First off, WELCOME BACK FROM BANNED CAMP!!!
2nd, and forgive my ignoracnce, I thought the benefit of oil coolers was moot when not running FI. Having no indication you are FI, is it true, then, this would be best used in a track environment where you are running harder pulls more frequently vs a street situation where "Standard driving conditions" apply?
Old 01-20-2015, 07:43 PM   #9539
Jrryjms07 (01-21-2015), Koa (01-20-2015), wtrxprs007 (01-22-2015)
Old 01-20-2015, 08:08 PM   #9540
Koa
the name 'oil cooler' implies cooling the oil, yes, but perhaps "oil temperature regulator" is a more fitting name because of the benefit of bringing oil temps up to speed significantly faster, which is real important, especially if the car experiences a lot of short (<20 min) trips
Am real excited for upcoming track days here in rainy WA!
Temps do tend to rise in stop-and-go traffic, though, and this little guy keeps both coolant and oil closer together. I like that once I do go FI when the powertrain warranty drops, it will be there and ready to play. Can always upgrade it
The Following User Says Thank You to Koa For This Useful Post:
Celadrielas (01-21-2015)
Old 01-20-2015, 08:16 PM   #9541
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Installed a whiteline heavy duty 18mm adjustable rear sway bar in about 30 mins, set to maximum stiffness! Time to test out dat oversteer :P
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
Old 01-20-2015, 11:07 PM   #9542
Koa
Installed FT86V2 catback todaaayyyy
Old 01-20-2015, 11:15 PM   #9543
2much
I wanna go fast
Drives: 2013 FR-S 6MT
what do you think of it? I love single exits on this car, and this is one of few options. I've always had my eye on the ft86 piece, also togue factory, and ive considered a track pipe. I have a nameless muffled track pipe coming but I fear it will be too loud and droney.
2much is offline   Reply With Quote
Old 01-21-2015, 12:06 AM   #9544
Koa
I love it- manageable at less than 3k rpms/lower loads, opens up nicely at higher RPMS and WOT. Looks real beast too! Love the canister and double walled tip. Got mine for a steal. Will see how it holds up on the 100 mile commute tomorrow
Old 01-21-2015, 09:41 AM   #9545
UniversalThree4
UniversalThree4's Avatar
Drives: #1061 10 Series A/T
15k service, at Expressway in Dorchester MA, service guy said that the car's oil is different? And that it is not due for another 4k, but the sticker says 15k....?
Your thoughts?
Exact number on sticker is15820, last service was 10820
UniversalThree4 is offline   Reply With Quote
Old 01-21-2015, 10:18 AM   #9546
Jrryjms07
Jrryjms07's Avatar
Drives: 2013 Firestorm
Your thoughts?
When in doubt just do it. Can never go wrong with getting it done early and having fresh oil.
Jrryjms07 is offline   Reply With Quote
The Following User Says Thank You to Jrryjms07 For This Useful Post:
Ganthrithor (01-22-2015)
Old 01-21-2015, 11:16 AM   #9547
Defuser
Remember
Defuser's Avatar
Looks like you installed it in the middle of a road!?! That's some Mad Max skillz there...
Old 01-21-2015, 12:01 PM   #9548
Koa
welcome to my driveway ;(
