#939 | |
Drives: Blue Subarus
I just installed those fittings 2 weeks ago. I didn't see any leakage prior to making the trek down last night, but didn't check after getting here. The original lines Fullblown installed leaked oil everywhere from both sides of the fittings. I spent a few hours cleaning what I could out of the bumper, under trays, oil cooler, and radiator hoses. It was far from perfect though.Good thing I didn't install the fiberglass DP wrap myself and ignite the car
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#940 |
Drives: Scion FRS
Yes, we are aware that the earlier oil cooler fittings had issues. We have since switch suppliers and ship with fragola fittings.
If anyone has the old style fitting. Please contact us and we will send the new ones out. |
| The Following User Says Thank You to FullBlown For This Useful Post: | Nomed Alucard (03-07-2014) |
#941 |
Drives: Scion FRS
What kind of numbers could you see with a gtx3076 and e85? How much later would spool be compared the gtx28?
#942 |
Drives: Scion FRS
Roughly 300 rpm later and capable or 100hp more.
#943 | |
Drives: Mazdaspeed 3
Please don't hit me with "experience." I've been tuning cars and writing EMS software and firmware for just as many years. Either explain in terms of simple physics why several degrees of retard will prevent the turbo from spooling to 8 psi or move on to another theory. |
#944 | |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Back to actually attempting to help the member solve or identify the root cuase of his problem... The car in question does not have a boost gauge. It does not have any aftermarket gauges at all. How is the boost being read? I must assume via EcuTek logging. What parameter is being interpreted as boost? Has the IAM been verified? Has the MAP sensor voltage feedback been verified? If the car is running the speed density map has anyone verified the IAT reading? If the car is now running the blow through MAF tune and not speed density has the OEM MAP sensor been re-installed? Has anyone verified the MAF voltage to the ECM? Has the EBCS been removed and the compressor line tied directly into the wastegate? With the car apparently not having any leaks, has anyone performed any troubleshooting or testing of the electronics? Has a reputable tuner looked at any logs or data? |
#945 | ||
The ability of the turbo to produce boost is proportional to the amount of expanding exhaust gas in the exhaust manifold. A certain amount of air and fuel enter the cylinder. These will produce a very specific amount of heat energy when they are ignited. If you delay the onset of ignition (by pulling timing) there will be less heat expended to turn the crank before the exhaust valve opens and the remaining heat will go into the exhaust manifold to power the turbo (make more boost). This is very obvious if you have spent any time tuning turbocharged engines. When you first start with a conservative timing map, you will see plenty of boost creep on a marginal wastegate set up. As you get a bit more aggressive and advance timing, the boost creep will stop. To make more boost at any load point you can: - Retard timing - Advance the exhaust cam (start the blowdown earlier with substantial heat energy still in the cylinder - Retard the intake cam (lower dynamic compression ratio to reduce the amount of heat energy extracted by the engine during the power stroke) - Lean out the charge (very carefully up to a point depending on the fuel used) which increases the amount of heat produced - Introduce ignition misses to allow raw air/fuel charge to enter and ignite directly in the exhaust manifold (don't do this without adult supervision) All these techniques are used sparingly by knowledgeable tuners to increase spool. They are used in concert by engine management systems to implement anti-lag. So if all that the ECU does when IAM decreases is retard timing, an IAM of 0 will produce more boost. You will be able to tell because boost will be almost instant the second you step on the throttle while acceleration is flat. If the ECU also takes other actions as IAM decreases such as close the throttle or retard the exhaust cam, you may not build much boost. Another reason your statement is incorrect is simply that ignition timing has nothing to do with load. Load is simply a measure of how much air enters the intake manifold. Everything you do after that in the tuning affects how much of the oxygen in that air gets used to produce torque on the crankshaft vs. heat in the exhaust manifold vs. heat in the cooling system (oil and water). It is very simple. There is nothing mystic or magical about tuning engines. You just apply some basic physics to make the most of what the customer brought to the shop. I've taught classes on this. I've had tuners tell me they learned more from two days in my class than they did from 20 years in the field. The truth is that they really knew all this stuff already, they just didn't have the right framework to pull it all into a unified whole. |
#946 | |
Great White
Drives: 2013 Whiteout FRS
Sterz' Great White 86 http://www.ft86club.com/forums/showthread.php?t=54533 Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe |
#947 |
Great White
And unrelated - Anyone who is running full 3" exhaust with our kit, which exhaust pipes did you go with, and how do you like it?
#948 |
#949 |
Drives: Scion FRS
Does it include the overpipe?
#950 |
Boosted
Drives: Not a supra....yet
#951 |
in orbe terrum non visi
Drives: violent
I'm running perrin overpipe with fbm 3 inch dual and like it a lot. Not too loud, no drone.
#952 | |
Drives: 2003 Subaru Outback
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 11:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 04:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 10:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 10:15 PM |
