Old 03-06-2014, 11:31 PM   #939
pmccut
Drives: Blue Subarus
Originally Posted by Infamous Performance View Post
We are installing an upgraded turbo in a BRZ now. On that kit the oil cooler lines are leaking at the fittings too. Oil sprayed from front of car to the cans underneath. This car also has the dreaded fuel vapor lines used for coolant. FAIL. Lines are melted. Coolant was leaking everywhere too. When we went to remove the banjo fitting at the turbo to pull the lines the lines completely separated. Melted rubber inside the fittings gumming them up and completely blocking flow. Another trip to XRP to buy the parts to build new lines. For anyone with an older kit, fuel vapor line CAN NOT be used with coolant. It will melt.
Oh no I just installed those fittings 2 weeks ago. I didn't see any leakage prior to making the trek down last night, but didn't check after getting here. The original lines Fullblown installed leaked oil everywhere from both sides of the fittings. I spent a few hours cleaning what I could out of the bumper, under trays, oil cooler, and radiator hoses. It was far from perfect though.
Good thing I didn't install the fiberglass DP wrap myself and ignite the car
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 03-06-2014, 11:40 PM   #940
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes, we are aware that the earlier oil cooler fittings had issues. We have since switch suppliers and ship with fragola fittings.
If anyone has the old style fitting. Please contact us and we will send the new ones out.
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Nomed Alucard (03-07-2014)
Old 03-07-2014, 12:44 AM   #941
dabocx
dabocx's Avatar
Drives: Scion FRS
What kind of numbers could you see with a gtx3076 and e85? How much later would spool be compared the gtx28?
dabocx is offline   Reply With Quote
Old 03-07-2014, 08:44 AM   #942
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Roughly 300 rpm later and capable or 100hp more.
Old 03-07-2014, 09:11 AM   #943
RickyB
Drives: Mazdaspeed 3
Sorry, this is not my first rodeo. I have been building turbo Subarus for over 12 years. If you dont have advance timing you dont build load and you dont meet boost target. Simple as that. If the IAM is not 1.0 you wont be making boost target. Making some boost is easy, yes. But you will not reach boost target without proper load and you wont reach proper load without some timing. If a car was making 8psi and then all the sudden makes only 3.5psi and there are no physical/mechanical issues to cause the boost drop, then it is most likely the ECM or the ECM reacting to false data from a failing sensor/wiring issue/etc. Checking the IAM is fast and easy. Remember the end user in this situation is not sitting in his car hooked up making changes to the tune in an attempt to get some boost. He is running a static map.
Load does not spool a turbo. The heat and expansion of the gasses in the exhaust manifold do.
Please don't hit me with "experience." I've been tuning cars and writing EMS software and firmware for just as many years. Either explain in terms of simple physics why several degrees of retard will prevent the turbo from spooling to 8 psi or move on to another theory.
RickyB is offline   Reply With Quote
Old 03-08-2014, 02:16 AM   #944
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
LOL. So with an IAM of 0 you think the car will make boost target?
Back to actually attempting to help the member solve or identify the root cuase of his problem...
The car in question does not have a boost gauge. It does not have any aftermarket gauges at all. How is the boost being read? I must assume via EcuTek logging. What parameter is being interpreted as boost? Has the IAM been verified? Has the MAP sensor voltage feedback been verified? If the car is running the speed density map has anyone verified the IAT reading? If the car is now running the blow through MAF tune and not speed density has the OEM MAP sensor been re-installed? Has anyone verified the MAF voltage to the ECM? Has the EBCS been removed and the compressor line tied directly into the wastegate? With the car apparently not having any leaks, has anyone performed any troubleshooting or testing of the electronics? Has a reputable tuner looked at any logs or data?
Infamous Performance is offline   Reply With Quote
Old 03-08-2014, 01:22 PM   #945
RickyB
Now you are asking a different question that has nothing to do with your original incorrect statement:
If the ECM is puling timing (you mention a base map) then you wont have the load required to build boost.
Tuning a turbocharger 101:
The ability of the turbo to produce boost is proportional to the amount of expanding exhaust gas in the exhaust manifold. A certain amount of air and fuel enter the cylinder. These will produce a very specific amount of heat energy when they are ignited. If you delay the onset of ignition (by pulling timing) there will be less heat expended to turn the crank before the exhaust valve opens and the remaining heat will go into the exhaust manifold to power the turbo (make more boost). This is very obvious if you have spent any time tuning turbocharged engines. When you first start with a conservative timing map, you will see plenty of boost creep on a marginal wastegate set up. As you get a bit more aggressive and advance timing, the boost creep will stop.
To make more boost at any load point you can:
- Retard timing
- Advance the exhaust cam (start the blowdown earlier with substantial heat energy still in the cylinder
- Retard the intake cam (lower dynamic compression ratio to reduce the amount of heat energy extracted by the engine during the power stroke)
- Lean out the charge (very carefully up to a point depending on the fuel used) which increases the amount of heat produced
- Introduce ignition misses to allow raw air/fuel charge to enter and ignite directly in the exhaust manifold (don't do this without adult supervision)
All these techniques are used sparingly by knowledgeable tuners to increase spool. They are used in concert by engine management systems to implement anti-lag.
So if all that the ECU does when IAM decreases is retard timing, an IAM of 0 will produce more boost. You will be able to tell because boost will be almost instant the second you step on the throttle while acceleration is flat.
If the ECU also takes other actions as IAM decreases such as close the throttle or retard the exhaust cam, you may not build much boost.
Another reason your statement is incorrect is simply that ignition timing has nothing to do with load. Load is simply a measure of how much air enters the intake manifold. Everything you do after that in the tuning affects how much of the oxygen in that air gets used to produce torque on the crankshaft vs. heat in the exhaust manifold vs. heat in the cooling system (oil and water). It is very simple. There is nothing mystic or magical about tuning engines. You just apply some basic physics to make the most of what the customer brought to the shop.
I've taught classes on this. I've had tuners tell me they learned more from two days in my class than they did from 20 years in the field. The truth is that they really knew all this stuff already, they just didn't have the right framework to pull it all into a unified whole.
The Following 3 Users Say Thank You to RickyB For This Useful Post:
alphasaur (04-14-2021), Ironsquid (03-11-2014), jamesm (03-08-2014)
Old 03-08-2014, 01:51 PM   #946
Sterz
Great White
Drives: 2013 Whiteout FRS
Mike, I'm not exactly sure why the tune was running so rough when I left the shop, when I called you and asked you if you had installed the upgraded map sensor, I threw the speed density tune back on to see if I would hit target boost. I do have a P3Cars gauge now by the way. My car is now hitting 8 psi of boost and is running smooth. I am not sure what caused it to run so poorly on the way home from the shop. Sorry for not clearing that up earlier. Now its just the oil cooler I am dealing with again.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 03-08-2014, 02:19 PM   #947
Sterz
Great White
And unrelated - Anyone who is running full 3" exhaust with our kit, which exhaust pipes did you go with, and how do you like it?
Old 03-08-2014, 02:28 PM   #948
Dipstik-sportech
Dipstik-sportech's Avatar
I have @FullBlown s 3" single exit kit. A touch loud but I don't mind.
The Frozen North
Old 03-08-2014, 07:08 PM   #949
dabocx
dabocx's Avatar
Drives: Scion FRS
Does it include the overpipe?
Old 03-08-2014, 07:14 PM   #950
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Nop
Sent from my IBrick
Old 03-08-2014, 07:52 PM   #951
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I'm running perrin overpipe with fbm 3 inch dual and like it a lot. Not too loud, no drone.
Old 03-08-2014, 07:59 PM   #952
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
With a turbo? Videos!
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
