Old 08-09-2013, 10:28 PM   #939
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Originally Posted by Unichip Jack View Post
Thank for the post.
The car is literally out right now finalizing things... should be posted early next week.
Cheers
Awesome!!! Thanks for pulling through, even though it took a while.
Not really sure if you guys runs baselines, etc, before every tune... Were there any dyno numbers or estimated gains for the FA20club tune?
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 08-13-2013, 02:50 PM   #940
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
IceFyre13th is offline   Reply With Quote
Old 08-14-2013, 12:30 PM   #941
BuBlake
BuBlake's Avatar
Okay I take that back... Post the tune, then I say thank you!!! lol
The Following User Says Thank You to BuBlake For This Useful Post:
Lytheum (08-14-2013)
Old 08-14-2013, 07:09 PM   #942
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
FA20 Club CAI...
... the tuner says he's finished and we just need to drive around for a day or so for final checks. That should be complete tomorrow afternoon and then we'll get the data double checked and post it to the library.
Thanks for your patience!
Cheers
Unichip Jack is offline   Reply With Quote
The Following User Says Thank You to Unichip Jack For This Useful Post:
Lytheum (08-15-2013)
Old 08-14-2013, 08:30 PM   #943
IceFyre13th
Drives: Mazdarati
Cheers
@Unichip Jack, Suggestion, drive around with the AC on, make sure the idle dose not stay high (1000 RPM or more)........if you monitor TPS with the flex and the AC is on it should stay at or below 15-16% at idle, AC off is around 14-15%.
If the idle dose go high with the AC on you can get it back to normal by turning the AC off for a few seconds........then back on and it should stay good.
Personally I think it has to do with the stock tune over compensating for the AC on (adjust to a higher idle to run the compressor), but if you are adding more TPS with the UniChip data you may be adding to much........
Keep in mind I have been using the Perrin CAI / catback tune with a "FA20Club CAI" and catback...........
Old 08-15-2013, 12:30 PM   #944
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
Originally Posted by mtimney View Post
Unichip Jack.....Finding a stable tune for my new header??
I'm running a P&L header, Perrin overpipe, 2.5" Isis pipe/muffler with a 2nd cat delete, and a drop in filter with a Perrin silicone intake tube. I'm uding 93 octane and have tried the appropriate 'all header/all cat-back/all drop-in tunes with fuel+ and fuel-. I've also tried advancing the timing on these. I tired timing- for one run, but I'm not getting anywhere.
I notice very little difference between the tunes. They all seem to run rather well at first, but after a couple hours of driving I start having a rough idle, some hesitation when I hit the gas and an inconsistent engine running up the RPMs.
I had things working well before I added the header, but now....??? Help!
Is this what everyone should expect to experience when upgrading to a header while using a Unichip or is this an isolated problem? Does anyone else run a head with the unichip without a problem?
jordanrw260 is offline   Reply With Quote
Old 08-15-2013, 04:37 PM   #945
IceFyre13th
Drives: Mazdarati
No, you needed to read more.......
Originally Posted by UniChip Jack
Rough running after installing a header isn’t a “tuning” issue… the header’s impact on an airflow based tune is actually pretty minor. It is an emissions issue.
It's not even really the header per se, if you use the same header with a cat (with a stock front pipe cat) you won’t have a problem. That’s why the header companies recommend you keep the cat.
Unfortunately, when you delete one or both cats, the OEM ECU quickly declares a cat efficiency fault (which all street legal vehicles must do) that results in a CEL and poor performance on some vehicles.
Beyond the timing and fueling changes for a header with cat, what the “no cat tune” does is turn off the cat code. Only problem is that’s completely illegal and what cost Edge Products better than 7-figures in fines and penalties… http://www.dieselnet.com/news/2013/01epa.php.
If you use an O2 spacer or spark plug non-fouler on the downstream O2 sensor port, you’ll avoid the fault code and should be golden.
Old 08-15-2013, 08:22 PM   #946
Unichip Jack
IceFyre13th... thanks for the post and observation. As you surmise, that TPS change is from the OE computer, not from the Unichip.
The FA20Club map is done an in final checks to be added to the data base. It should be done by tomorrow evening... sorry it was a long wait.
A couple of guys have pointed out that the K&N maps have vanished from the data base... it appears the file got corrupted at some point. They will be there when the file is updated with the FA20Club maps.
Cheers
Old 08-16-2013, 03:17 PM   #947
IceFyre13th
Drives: Mazdarati
Cheers
Seems there are a few issues with the factory ECU "tune" that Toyota / Subaru need to iron out still, wonder if the dealer could flash me the latest one? Assuming there is a newer one.
Thanks for getting the FA20Club tune out, gives me something to play with this weekend!!!
Old 08-16-2013, 03:54 PM   #948
Lytheum
Drives: 2013 BRZ Premium 6MT
F5, F5, F5......
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
BuBlake (08-16-2013)
Old 08-16-2013, 09:51 PM   #949
Lytheum
Looks like they are uploaded
Old 08-16-2013, 10:21 PM   #950
Lytheum
i get "error creating comport list" when i try to open the update program. i did right click and select run as administrator. then another box pops up saying registry error.
Old 08-16-2013, 10:34 PM   #951
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Ordered my Unichip last night! Jack, thanks for talking with me about my concerns today.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 08-16-2013, 10:42 PM   #952
BuBlake
BuBlake's Avatar
I'm downloading the files right now... FA20Club Unichip tune review underway! )))))))))))))))))))))))))))))))))))))))))))))))) )))))))))))
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
