Old 01-17-2014, 11:06 PM   #925
mkivsoopra
I noticed that as well but to be honest I have personally not seen anyone with all bolt ons and E85 via OFT post a dyno plot.
I would like too see that.
All bolt ons + E85 + OFT? Right here: http://www.ft86club.com/forums/showthread.php?t=53946
mkivsoopra is offline   Reply With Quote
Old 01-17-2014, 11:10 PM   #926
Marusich
Marusich's Avatar
Loving my OFT. What a change!
Marusich is offline   Reply With Quote
Old 01-17-2014, 11:14 PM   #927
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I was sad when I refreshed the DL page just now and no 1.5. Darn I wanted to play with it this weekend. Lol
Sent from Spaceball 1
Here are some Dynos results you are probably looking for
All 4th gear runs. Expect 4-5whp more in 5th gear.
Old 01-17-2014, 11:57 PM   #928
vynervt
Drives: GT-86
Dear All,
Needed you all pro advice, i'm new with datazap and today have sometime to play with OFT datalog.
http://www.datazap.me/u/vynervt/18-j...log=0&data=1-6
Please share your ideas was i engine running in normal condition, Im using Stage 1 ZA1JA00J 1.42B version. Fuel is Malaysia 97 grade. (I don't what grade of OCT / RON). small modify on the intake duct and stock everything else.
What i see from the graph. My AFR gone from as rich 12.17 to as Lean 20.33 AFR. Is this normal?
vynervt is offline   Reply With Quote
Old 01-18-2014, 12:11 AM   #929
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by vynervt View Post
Dear All,
As long as the AFR is 12 while at full throttle. 20 is normal if you are coasting in gear. I was more shocked at the date of your logs. You are from the future, it's only Jan 17th here lol.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-18-2014, 12:12 AM   #930
Shiv@Openflash
Drives: 2013 FRS
Dear All,
AFR is fine. So are long term fuel trims. The 20.33:1 readings you get is during deceleration when the injectors shut off. That is normal. Once cruising under power, AFR will be around 14.5:1. And under WOT, you should see low 12s to high 11s.
Shiv
Old 01-18-2014, 01:01 AM   #931
vynervt
Drives: GT-86
Hehe.. Thanks for the comment. Im not from Future im in malaysia so is early 16 hours with US time.. Thanks!
Old 01-18-2014, 11:37 AM   #932
Jac
Drives: Fiat Abarth
Shiv
Aside from AFR at WOT what else should i be looking for when reviewing logs?
http://datazap.me/u/jac/brz-oft-stag...1449&mark=1611
Jac is offline   Reply With Quote
Old 01-18-2014, 11:45 AM   #933
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
@Rombinhood@OpenFlash or @shiv@vishnu: Is there any expiration on OFT Dollars? I would like to buy the tablet soon and use the OFT Dollars towards a header at some point, just not sure how long it'll be.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-18-2014, 01:05 PM   #934
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I've been playing with my oft a bit now, it has been great so far but one thing I would like to see is the ability to save multiple data logs instead of always overwriting your previous one. @shiv@vishnu maybe in a future update?
- AdrianG
AdrianG is offline   Reply With Quote
Old 01-18-2014, 02:58 PM   #935
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
- AdrianG
This is the biggest feature I would be looking for at the moment. Even if it could just append it so that the new logs gets tacked on to the end of what is already saved. Super simple to code.
Luckrider is offline   Reply With Quote
Old 01-18-2014, 04:18 PM   #936
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Need logging capability for other parameters like IAT, fine knock, etc.
Here's mine on a post 1.42b stg 1 test rom. Computer is dialing back IAM at low load low RPM conditions.
http://www.datazap.me/u/solidone/1-1...2&zoom=318-634
http://www.datazap.me/u/solidone/1-1...2&zoom=292-739
Old 01-18-2014, 04:35 PM   #937
AdrianG
Word. The Ecuflash guys have found some of this I believe so it should be very easy to add.
- AdrianG
Old 01-18-2014, 04:42 PM   #938
Shiv@Openflash
Drives: 2013 FRS
- AdrianG
Yep... we are currently adding the option to log up to 32 channels (up from 12). So 20 more useful logging channels to come.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
