#925 | |
Drives: Blue Subarus
The WG only boosting to 3.5psi doesn't make any sense if you have a higher spring in there. Loose hose?
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#926 |
Great White
Drives: 2013 Whiteout FRS
Went over every hose, did a vacuum/boost pressure test and nothing was leaking, smoke tested and everything.
Sterz' Great White 86 http://www.ft86club.com/forums/showthread.php?t=54533 Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe |
#927 | |
Drives: Scion FRS
There is a fire ring that goes between the wastegate and the flange. If it is not there, it would cause a leak. |
#928 | |
Boosted
Drives: Not a supra....yet
DO NOT GO TO FORMAN ! Sent from my IBrick
#929 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#930 |
Great White
Why do you say that? Dave has worked on all of my previous cars including a WRX and an STi and has done nothing but amazing work. Did you have a bad experience there? He has always treated me with an insane amount of respect and always does his best to help me out including staying 3 hours after closing on a friday night. I am interested why you say that.
#931 | |
Boosted
Had family members build cars over there, both builds that required a month or less took either 5 or 13 Sent from my IBrick
#932 |
Great White
Hmmm...Interesting, he has always been insanely busy and before he expanded his shop had over a month of pushback for his appointments. He had an extremely small shop for the amount of clientele that he has. Since buying out the building next door, he was able to put another 3 lifts in and has gotten my cars out in a very timely manner.
#933 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Sterz, your car has a higher reading map sensor. When we handed it over it was running a speed density tune. It was also making 8psi of boost.
Your car was smoke tested prior to start up and leaving my shop. We had to replace the fittings and the lines for the oil cooler. The original supplied lines leaked at all 4 fittings. The fittings had also damaged the lines internally (during assembly). You have 100% XRP equipment there now (lines and fittings). Those lines were pressure tested prior to install and leak checked post install. If the ECM is puling timing (you mention a base map) then you wont have the load required to build boost. |
#934 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#935 |
Much title. Wow.
I was over 13psi on the base map before seeing even a lick of knock. just saying. Its a safe map.
#936 |
Drives: Mazdaspeed 3
Less advance means that there is more heat and expansion still happening when the exhaust valve opens which means the turbo has more energy to spool. I can get a turbo to spool right off idle on any engine by just retarding the ignition timing enough (of course, the engine will not be making any torque, so the boost won't do you much good).
#937 | |
Great White
#938 | ||
We are installing an upgraded turbo in a BRZ now. On that kit the oil cooler lines are leaking at the fittings too. Oil sprayed from front of car to the cans underneath. This car also has the dreaded fuel vapor lines used for coolant. FAIL. Lines are melted. Coolant was leaking everywhere too. When we went to remove the banjo fitting at the turbo to pull the lines the lines completely separated. Melted rubber inside the fittings gumming them up and completely blocking flow. Another trip to XRP to buy the parts to build new lines. For anyone with an older kit, fuel vapor line CAN NOT be used with coolant. It will melt.
I am not positive what tune you were on (rev wise) as it was simply labeled "use this tune" on the provided thumb drive (from the previous owner). I do know the "base" maps he had were the original base maps as his kit was one of the first sold. Quote:
Something is deff up as I was able to perform multiple back to back pulls with the car (logging via EcuTek) and had no bogging or other issues to note prior to handing over the keys. Did the MAP sensor fail? Quote:
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
