Old 03-05-2014, 12:26 PM   #925
pmccut
Drives: Blue Subarus
Originally Posted by Sterz View Post
Wastegate is recirculating to its hard to pin point when it opens. Dropping the car off at Forman Performance today to see if we can figure it out and also get these lines checked out again.
The oil cooler fittings are my only real complaint. Definitely see if they're leaking at both sides and get some new fittings if you need. That was a pain in the ass to swap out and clean the oil all over everything.
The WG only boosting to 3.5psi doesn't make any sense if you have a higher spring in there. Loose hose?
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 03-05-2014, 12:35 PM   #926
Sterz
Great White
Drives: 2013 Whiteout FRS
Originally Posted by FullBlown View Post
Are the hoses under the intake manifold clamped?
Went over every hose, did a vacuum/boost pressure test and nothing was leaking, smoke tested and everything.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 03-05-2014, 12:51 PM   #927
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Is it a open dump? If so, with the car idling, put your hand under the dump tube and see if there is any exhaust gas coming out.
There is a fire ring that goes between the wastegate and the flange. If it is not there, it would cause a leak.
FullBlown is offline   Reply With Quote
Old 03-05-2014, 12:53 PM   #928
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
DO NOT GO TO FORMAN !
Sent from my IBrick
Old 03-05-2014, 12:55 PM   #929
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Sent from my IBrick
LOUD NOISES
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-05-2014, 12:56 PM   #930
Sterz
Great White
Sent from my IBrick
Why do you say that? Dave has worked on all of my previous cars including a WRX and an STi and has done nothing but amazing work. Did you have a bad experience there? He has always treated me with an insane amount of respect and always does his best to help me out including staying 3 hours after closing on a friday night. I am interested why you say that.
Old 03-05-2014, 12:57 PM   #931
SmsAlSuwaidi
Boosted
Had family members build cars over there, both builds that required a month or less took either 5 or 13
Sent from my IBrick
Old 03-05-2014, 01:01 PM   #932
Sterz
Great White
Sent from my IBrick
Hmmm...Interesting, he has always been insanely busy and before he expanded his shop had over a month of pushback for his appointments. He had an extremely small shop for the amount of clientele that he has. Since buying out the building next door, he was able to put another 3 lifts in and has gotten my cars out in a very timely manner.
Old 03-05-2014, 07:29 PM   #933
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Sterz, your car has a higher reading map sensor. When we handed it over it was running a speed density tune. It was also making 8psi of boost.
Your car was smoke tested prior to start up and leaving my shop.
We had to replace the fittings and the lines for the oil cooler. The original supplied lines leaked at all 4 fittings. The fittings had also damaged the lines internally (during assembly). You have 100% XRP equipment there now (lines and fittings). Those lines were pressure tested prior to install and leak checked post install.
If the ECM is puling timing (you mention a base map) then you wont have the load required to build boost.
Infamous Performance is offline   Reply With Quote
Old 03-05-2014, 08:12 PM   #934
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Anyone have any ideas as to why my car could only be boosting to 3.5 psi on the basemap? Boost pressure test was done...no leaks. Vacuum test was done...no leaks. Standard 7.5 psi spring in the wastegate. I just can't figure it out. Also came home tonight, after going in the house for a while I remembered I left my phone in the car, came out and there was a good puddle of oil on the ground. Seems to be coming from the oil cooler lines. Could have been leaking like that the whole night I was driving I checked the oil yesterday and it was at full level and now its not even registering on the dip-stick
Sounds like it is definitely the oil cooler. I had issues where mine all of a sudden developed a leak. My leak was out of the back of the AN fitting where the hose goes in on one of the lines connected to the cooler itself. I would pull the bumper and check them out. I don't see anything that could prevent you from pulling over 3.5 psi unless it is some kind of boost leak or something causing your wastegate to open really early. How did you run the vacuum lines to the wastegate?
Old 03-05-2014, 08:30 PM   #935
Deadspool
Much title. Wow.
Deadspool's Avatar
I was over 13psi on the base map before seeing even a lick of knock. just saying. Its a safe map.
Old 03-05-2014, 08:32 PM   #936
RickyB
Drives: Mazdaspeed 3
Less advance means that there is more heat and expansion still happening when the exhaust valve opens which means the turbo has more energy to spool. I can get a turbo to spool right off idle on any engine by just retarding the ignition timing enough (of course, the engine will not be making any torque, so the boost won't do you much good).
RickyB is offline   Reply With Quote
Old 03-06-2014, 03:41 AM   #937
Sterz
Great White
I originally put it on the basemap because on the drive home from the shop. My car was bogging horribly and misfiring. It threw a code within 10 minutes of driving it. I assumed it was because maybe something got mixed up and you installed the OEM map sensor. When I got home I threw on the basemap to see if it ran better and it ran great. The only problem was that it was only boosting to 3.5 pounds. So as a precaution I had it boost pressure tested and vacuum tested. Sure enough there were no leaks, you did a great job with the install. And I don't believe it was a mechanical issue, except for maybe something's up with the wastegate. As for the oil cooler lines, I'm not sure but there is definitely oil leaking where the fittings mate to the cooler.
Old 03-06-2014, 10:31 PM   #938
We are installing an upgraded turbo in a BRZ now. On that kit the oil cooler lines are leaking at the fittings too. Oil sprayed from front of car to the cans underneath. This car also has the dreaded fuel vapor lines used for coolant. FAIL. Lines are melted. Coolant was leaking everywhere too. When we went to remove the banjo fitting at the turbo to pull the lines the lines completely separated. Melted rubber inside the fittings gumming them up and completely blocking flow. Another trip to XRP to buy the parts to build new lines. For anyone with an older kit, fuel vapor line CAN NOT be used with coolant. It will melt.
I am not positive what tune you were on (rev wise) as it was simply labeled "use this tune" on the provided thumb drive (from the previous owner). I do know the "base" maps he had were the original base maps as his kit was one of the first sold.
Saying it is a "safe map" blindly is taking a big leap. You also are running different fuel. CAN91 is by far the worst in the nation. My experience (so far) with the provided base maps is that they are good enough to start the car and drive it onto the dyno to tune it (much like the base maps provided by many companies).
Something is deff up as I was able to perform multiple back to back pulls with the car (logging via EcuTek) and had no bogging or other issues to note prior to handing over the keys. Did the MAP sensor fail?
Sorry, this is not my first rodeo. I have been building turbo Subarus for over 12 years. If you dont have advance timing you dont build load and you dont meet boost target. Simple as that. If the IAM is not 1.0 you wont be making boost target. Making some boost is easy, yes. But you will not reach boost target without proper load and you wont reach proper load without some timing. If a car was making 8psi and then all the sudden makes only 3.5psi and there are no physical/mechanical issues to cause the boost drop, then it is most likely the ECM or the ECM reacting to false data from a failing sensor/wiring issue/etc. Checking the IAM is fast and easy. Remember the end user in this situation is not sitting in his car hooked up making changes to the tune in an attempt to get some boost. He is running a static map.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
