06-17-2014, 12:29 PM | #925 |
Drives:
Any installed pictures?
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
06-17-2014, 12:35 PM | #926 |
Grip>Drift
Drives: FRS
Yes yes but no no no no no!
The Following User Says Thank You to BlaineWasHere For This Useful Post: | whataboutbob (06-18-2014) |
06-17-2014, 12:38 PM | #927 | |
Drives: MT WRB BRZ Limited, 2007 911s
I was choosing between the HVT and Raceseng and ended up with HVT. They may not have the sex appeal but they do exactly what I need to for a bit less. |
06-17-2014, 12:45 PM | #928 |
Drives:
I really like the HVT but I'm a bit concerned about them maxing out at 1.8 deg camber.
My STX build thread
06-17-2014, 12:49 PM | #929 |
06-17-2014, 12:50 PM | #930 |
Drives:
Oh that's perfect! I may have to go that route.
My STX build thread
06-17-2014, 12:50 PM | #931 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Currently running WRX camber plates.. set at -3.3 ... I have ALOT of range that I could go like to -5.5 if needed. but isn't necessary for obvious reasons.
Bill
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
06-17-2014, 12:51 PM | #932 |
Drives:
Pictures? Links?
My STX build thread
06-17-2014, 12:53 PM | #933 |
06-17-2014, 12:55 PM | #934 |
Drives:
I've been debating between those and the Ground Control option. Mostly something high quality that won't raise the car.
My STX build thread
06-17-2014, 12:56 PM | #935 |
Drives: '13 BRZ Ltd
Just wondering if any of you guys that are running the KW and have swapped springs are looking to offload the originals. Looking for the stiffer 400/343 rates (obviously).
06-17-2014, 03:27 PM | #936 |
Conedancer
this is a pic of -3.3 degrees.. As you can see I have a ton of adjustment there..
Standard WRX Camber plates..nothing special these are EBAY specials. One word of Caution if you decide to use these. They only come with a 12x1.5 nut..where as most Subaru Fitments are 12x1.25 ... so I used Cusco top nuts that I had from another application. Most Camber plate bearings are the same diameter..so fitting the Cusco Top nuts wasn't an issue. Bill
The Following User Says Thank You to Scooby South For This Useful Post: | MidnightRunner (06-20-2014) |
06-18-2014, 09:58 AM | #937 |
Drives: 2014 BRZ
Looks like I'm finally going to buy some more parts an actually put them on the car. Still have half an STX build sitting in my storage room. I know, I'm lame. But with the ability to drive the SSR Vette, my motivation has been lacking. Also, quiet and comfortable has been quite nice. But I'm finally going to install all the suspension goodies soon after I order a few more things.
So real question here, what's the current thinking on rear lower arms? I know the SPC is the standard go to, but thought I had heard word of those slipping? Probably will get it anyways. Just wanted to get the consensus here. |
06-18-2014, 10:09 AM | #938 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
